Agri fab 42" snowblower throwing auger belt - Page 4 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #46 of 107 Old 02-10-2013, 09:21 PM
Re: Agri fab 42" snowblower throwing auger belt
part # 27280 is quite possibly either bent, or loose. Have you hit anything? Got anything stuck in the impeller?
McDerry is offline
post #47 of 107 Old 02-10-2013, 09:23 PM
now over 12,000 posts
Whirly's Avatar
have u checked that lower spring to see if it has streached any....if it hasn't then I suggest also that u try a spirng that is a lil shorter...just b carefull that u don't get it too tight tho..
Whirly is online now
post #48 of 107 Old 02-10-2013, 09:26 PM
Whirly's Avatar
wat part is this......??
post #49 of 107 Old 02-10-2013, 09:59 PM
The part that the two idler pulleys are hooked too. Its bolted to the back of the snow thrower housing by 4, 5/16 bolts. Its only function is to align the pulleys. If the lower bolts have worked loose it would allow the pulleys to cant away from the housing when under tension. The heavier the load, the more tension.
A bolt, stud/nut should be visible in the picture where I have the red circle.
I wouldn't be surprised if a nut or two backed off and fell into the snow.
I use the 42" version of this blower. It works really well. This will be season 7 on the original belts. Chewed right through the 30 inches that nemo just dumped on me, not to mention the 5' drifts. With the 6 speed in 1st it will cut through a good foot without bogging and launch it 70 so feet if thrown with the curve. On a hydrostatic unit where you can just creep into the deep stuff it should have no problem.
McDerry is offline
post #50 of 107 Old 02-10-2013, 10:34 PM Thread Starter
I will check that part as soon as i can. I doubt it would be damaged, something could be loose though. I have not hit anything at all and havent sucked anything into the augers.
The missing bolt/nut is missing because the manual said to remove it. What does it do?
This blower is a 42" btw.
1953 Ford Jubilee
2012 Craftsman GT6000
42" 2 stage snow blower-$1200 paper weight
48" Blade
Sleeve hitch
Agri-fab box-blade
55 pound wheel weights plus tire chains
Ohio Steel utility tray
RAND81 is offline
post #51 of 107 Old 02-10-2013, 11:13 PM
Whirly's Avatar
I would do a check to see ifany of the lift assembly will hit that nut...if it is clear....I would reinstall the nut..
I think u should have a mile of room in that area...
post #52 of 107 Old 02-11-2013, 12:35 AM
You remove the height limiting nut for the Garden tractors, not the nut that holds that plate on.
McDerry is offline
post #53 of 107 Old 02-11-2013, 06:31 AM
Whirly's Avatar
havin that nut off can let the pully flex the unit enuf to let the belt fly off
post #54 of 107 Old 02-11-2013, 09:34 AM Thread Starter
I only removed the height limiting nut, what plate do you mean?
1953 Ford Jubilee
48" Blade
Sleeve hitch
Agri-fab box-blade
RAND81 is offline
post #55 of 107 Old 02-11-2013, 12:40 PM
FWIW, I agree that your mule drive is installed correctly. The head of the spring does need to come out for the auger belt.
Trust me, there is a way to screw that up, if you start with the pulley on the wrong side of the belt...
I think they're onto something with the alignment of the front end.
If all else fails, since this is a new unit, I might be looking to get it repaired or replaced by Sears.
Mike
mikeinri is offline
post #56 of 107 Old 02-11-2013, 01:08 PM Thread Starter
Mike
I didnt want to say anything but i do have a sears service guy coming on thursday. I didnt want to say anything because i didnt want people to stop trying to help me figure this out. I dont think the repair guy will be of much help.
I have a warranty on the blower, i didnt want the warranty but it kinda just happened, long story.
Anyways i doubt this repair guy will be much help. I bet all be is going to do is put a new belt on it. I dont see what more he could do. Like i said, the belt, pulleys and the whole blower is put together perfectly.
1953 Ford Jubilee
48" Blade
Sleeve hitch
Agri-fab box-blade
RAND81 is offline
post #57 of 107 Old 02-11-2013, 08:00 PM
Oo-v-oO's Avatar
Originally Posted by RAND81 View Post
Ya sears wants $90 plus shipping. So i googled the belt model number and came up with vbeltsforless.com, $20 plus shipping.
I still doubt its the belt though, the belt looks fine.
Im also not sure how someone could mount the belt the wrong way, there is only one way it can go on.
FWIW, I have used blue Kevlar Vbeltsforless auger belts on two different Craftsman blowers and had nothing but good luck with them. Off the top of my head they are #B111K.
I use their A series Kevlar belt for the mule drive, too.
-Lee, KB1GNI
"Felix qui potuit rerum cognoscere causas"
[Happiness is understanding how things work]
Oo-v-oO is offline
post #58 of 107 Old 02-11-2013, 08:39 PM
Pie R Round
BillB's Avatar
I'm a little late to the party, but I had the same symptom with mine once. The belt would stay on for a few feet, then the tractor would just spit the belt off. This happened when I tried using a belt that was the correct size, but the wrong construction. It was a fractional horsepower belt that I bought because I was tired of paying $70+ for the belts from Sears. For this application, you must use a Kevlar wrapped belt. I have to wonder if you were supplied the wrong belt - fractional horsepower belts are usually black, like yours, and have no continuous cloth wrapping. The OEM belts from Sears that I've seen (and I've seen several) have been a light gray color. And I've recently started using the blue Kevlar belts from vbelts4less without issue at one-third the price.
Bill
2012 JD 2320 w/FEL, 54D MMM, 54" Snowblower
2000 Craftsman GT 24HP, 50" Deck, 46" Snowblower
2001 Craftsman GT3000, 48" Deck w/mulch kit, 46" Snowblower, 42" Sweeper, 16 Cu Ft Dump Cart
1973 Cub Cadet 108, 42" Deck, Snow/Dirt blade and Dump Cart
BillB is offline
post #59 of 107 Old 02-11-2013, 08:40 PM
Whirly's Avatar
RAND81
have u checked ur blower where McDerry has the lil red circle to see if there is a nut missing in the photo....this nut is holdin the plate that has ur pullies mounted on to the back of ur blower...if it is missing the 2 lower pullies can b out of alignment with the blower pully & that is wat causin ur belt to come off...
post #60 of 107 Old 02-12-2013, 08:52 PM Thread Starter
Apparently you cant cancel your order from Vbeltsforless so i ended up getting it anyways. I didnt think twice about ordering to begin with since all the reviews i saw for it everyone loved it and said its a fantastic belt for this application. Im not going to install it until the repair guy comes though, i wanna see what he has to say first.
Im not very hopeful he will be much help anyways, ive been through the manual a million times, ive removed and reinstalled almost the entire blower and pulley system, i cant see anything wrong with it at all and if i cant, i dont see how he will be able to either.
But at least i will have some kind of paper trail and if i have to get my money refunded it will be easier to do so, at that point i will just get a snowblade for the tractor.
Bill
Yup ive seen alot of people say the same thing about this belt, sounds like a good belt for an amazingly low price.
RAND81
Yes, i thought we covered this, maybe i wasnt clear about it. That bolt has to come out for garden tractors, if you dont you cant lower the blower down enough.
Im not sure what plate your talking about though, that has me thinking, i saw no plate in that area during assembly. Maybe i missed something? I dont see anything in the manual either though.
1953 Ford Jubilee
48" Blade
Sleeve hitch
Agri-fab box-blade
RAND81 is offline
