New blades for a cub cadet I 1042 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 04-15-2012, 01:43 AM Thread Starter
I just recieved a new set of blades for my 2008 Cub Cadet I purchased used a week ago. I do understand how the timing blades work and how to set them for replacement. The blades on it have the star pattern, the new ones I want to put on have a different shape and they do not seem to go on properly. I was assured this pattern will work just as the star does, is there a trick to using this type. Please let me know if I should use them or not Thanks.
Mike Bice is offline
post #2 of 5 Old 04-15-2012, 10:06 AM
Re: New blades for a cub cadet I 1042
Get the right blades or you will continually have problems with this deck. Roger
rhenning is online now
post #3 of 5 Old 04-15-2012, 10:38 AM
Rog02's Avatar
The "star pattern" is the standard MTD spline and if the blades do not simply set in place then you have the wrong blades. Since the deck on the i-xxxx series are belt drives there is no "timing". The blades will coast when the PTO is dis-engaged so timing them is of no use.
I got a set of "gator blades" last summer from my CUB dealer and they had a CUB part number stamped on them.
My post on the topic:
bending blades?
Roger
Old, Tired, and Grumpy
Rog02 is offline
post #4 of 5 Old 04-19-2012, 11:54 PM
aquist06's Avatar
Mike, you will need the correct blades with the star on it. With a timed deck, you will have to set the blade 90 degrees to each other, one going north/south and the other east/west. Like rhenning said, if they don't just bolt up to where they are supposed to, then they are wrong. If you go to a dealer, make sure to bring your model and serial numbers, plus the date code since timed decks were only used for a couple of years.
2014 1025R, 54" AutoConnect Deck, H120 Loader, 14 Bushel Bagger, 60" QH Blade, 49" Kuhn Tiller, 47 snowblower, 54 rotary cutter
2005 X575, 54" mower, QH, three point hitch
aquist06 is offline
post #5 of 5 Old 04-21-2012, 11:31 AM
markwb's Avatar
Home Depot and TSC have the correct blades for your machine. Cub Cadet Part # 942-04217.
Mark
IBEW Local 261 Groton, CT
2008 Cub Cadet ZTT i1042
1997 Lawn Boy Silver Series Model 10227
PreciseFit 42" Lawn Sweeper
Echo SRM-2100 Trimmer/Brush Cutter
"My Other Vehicle Is a Nuclear Submarine"
markwb is offline
