aerator/spreader conbo opinions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 02-26-2012, 10:09 PM Thread Starter
nkaust's Avatar
Location: Berkeley Springs West Virginia, Hello My Name Is Nkaust And I Am Addicted To Garden Tractors
aerator/spreader combo opinions
i was just wondering what you all thought about these. i would like to have a drop spreader and i need to get more grass seed in the yard to get it nice and plush. so i was just wondering how well they have worked for you guys pro's/cons etc etc. i know that the the spikes have to be turning in order for the drop part to work. does this work good in the garden?
thanks
kaust
78 Sears GT/14
78 Bolens G14
57 Farmall Cub
I'm Sure Theres Others Somewhere Lol
Common Sense And Caution Are factors which Cannot Be Built Into Any Product.
These Factors Must Be Supplied By The Operator.
nkaust is offline
post #2 of 5 Old 02-26-2012, 10:39 PM
mbrun's Avatar
Re: aerator/spreader conbo opinions
I own one of the combo units. I do not see any benefit whatsoever to having the spike aerator on the seeder. Conceptually the idea is good, but in practice it offers little or no additional benefit in my 5 years or so of using it. If I were to replace it I would get one with wheels. Less maintaince.
Last fall I core aerated 4 passes plus, then seeded. Now that made a difference and it was evident in 3-4 weeks. That worked because the core aerator brought up plugs of dirt that mixed with the seed and encouraged germination.
If you are comparing one with wheels against one with spike aerator and they are the same size and price, then it's a coin toss. If the spike version is more money, go with the wheel version and save your money for a core aerator.
BTW, I have to straighten 4-8 spikes after each use. The spikes on the brinly unit are very soft steel.
~~~~~~~ 2010 JD x500 ~~~~~~~~
..Brush Guard, 48" Snow Blade, Electric Blade Lift
..Custom Blade Squeegee & Dollie
..P796 Halogens
..JP Electric Sleeve Hitch
..RimGuard Loaded Tires (+92lbs extra, each)
..DR Power Grader
..Dual 50lb Wheel Weights, Chains
..PrecisionFit/Agri-Fab 45-0299 48" Core Aerator
..Brinly Aerator/Seeder, Moldboard Plow,
..Box Scraper, Dethatcher (On Loan)
..Craftsman 48" x 18" Roller
..Brinly 25-Gallon Tank Sprayer
mbrun is offline
post #3 of 5 Old 02-26-2012, 11:23 PM Thread Starter
nkaust's Avatar
the biggest thing i am going for is to get the yard more plush, lol some people call me nuts for wanting more grass to cut but it drives me nuts because my yard is patchy. i have a broadcast spreader and a roller but i want to get the seed in the ground and i am trying to figure out the best way. would i need to get a plug aerator, then plug, seed, fertilize then roll? i see these yards with thick plush grass, i don't let my grass get tall enough to reseed itself or should I? but i was wondering if one of these units was what i needed. maybe lol this needs to get moved to yard care?
thanks
kaust
78 Sears GT/14
78 Bolens G14
57 Farmall Cub
nkaust is offline
post #4 of 5 Old 02-27-2012, 07:55 PM
mbrun's Avatar
Originally Posted by nkaust View Post
the biggest thing i am going for is to get the yard more plush, lol some people call me nuts for wanting more grass to cut but it drives me nuts because my yard is patchy. i have a broadcast spreader and a roller but i want to get the seed in the ground and i am trying to figure out the best way. would i need to get a plug aerator, then plug, seed, fertilize then roll? i see these yards with thick plush grass, i don't let my grass get tall enough to reseed itself or should I? but i was wondering if one of these units was what i needed. maybe lol this needs to get moved to yard care?...
The experts discourage use of rollers except where a roller is absolutely needed to solve a specific problem. This is because a roller achieves its flattening effect by compacting the soil. But compacted soil impedes the growth of grass. So if your object is to help your grass to grow, rolling helps to achieve exactly the opposite effect. I think one of the only times a pro uses a roller is when they are seeding a freshly tilled and seeded lawn. Running the roller over the soil after the seed has been raked-in helps to achieve better soil to seed contact, which expedites initial germination and growth.
Compacted soil is what a core aerator is intended to fix. When you core aerate you are cutting (removing) cores out of the soil and depositing them on the top. These openings then allow moisture to get down to the roots better and they also make room for the soil to expand so that roots can grow more easily. A good yearly core aerating can also control thatch.
If you have real need to roll your yard to smooth out things like mole tunnels and winter earth heaving, then you should follow it with several passes with a core aerator to counter the compaction you just caused.
If you want your seed to grow, you absolutely have to get it on complete contact with the soil and keep it moist. You are correct that you need to get the seed "in the ground". You can get it in the ground by tilling the soil and raking it in. You can get it in the ground by using a slit seeder, which slices the earth and places the seed in the slit before it is closed up. You can spread the seed on the ground and rake fresh dirt over the top of it. Or, as some have figured out, you can core aerate really good, seed and fertilize and then rake or otherwise drag the yard to break up the cores and mix it with the seed. The core openings are also your friend as they provide a place for some of the seed to fall into.
I have never heard of anyone letting their yard go to seed just so they did not have to buy seed. Personnaly, I am not certain that I would want to let my yard look like heck for a year just so I did not have to purchase seed.
I have learned that the best time of all to core aerate and seed is late August into mid September. Last year I aerated the yard 6 times, seeded, fertilized and dragged the yard multiple directions during the week following labor day. By October grass was growing everywhere. By November I had mowed 3 times or more.
I know spring is approaching and you might be tempted to aerate. Me too! And I will. If you are in need of grass badly, go ahead and core aerate really good, seed and fertilize your troubled areas in mid-late March or very early April. This will get you going for the year. Thereafter, core aerate and seed in early September. You will get the most bang for your effort and $.
This spring, I will be core aerating the lawn in mid-late March early April. Then putting a pre-emergent down to keep the crabgrass at bay. And since I am putting a pre-emergent down I will have to wait to seed again till fall.
In the end, my recommendation to you is that if you are going to spend money to own an implement you can pull with your tractor to help with you lawn, purchase a core aerator. It will give you the most bang for your buck IMO since you already own a spreader.
..P796 Halogens
..DR Power Grader
mbrun is offline
post #5 of 5 Old 02-28-2012, 08:23 PM Thread Starter
nkaust's Avatar
i am not being cheap by letting the grass grow it develops a good root system plus i already bought a 50 pound bag of seed. i already planted grass there last year and it is patchy so i want to thicken it up and you answers my question here
78 Sears GT/14
78 Bolens G14
57 Farmall Cub
nkaust is offline
