Snow blower mod for gravel driveway (Pictures) - large caster installation - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 11-23-2011, 09:57 PM Thread Starter
TECH Exchange Contributor!
Alan Lloys's Avatar
- - - or how to watch me make the mistakes so you don't have to
As many people with a gravel driveway I have been experimenting with different methods to reduce the amount of gravel being picked up by the tractor snow blower.
Last year I tried installing wheels on the blower to make it float over the gravel and leave about 1-2 inches of snow cover. You can find my results over here.
The results were actually excellent but it was hard to steer without picking up the blower every time. So this year I wanted to improve and install caster wheels instead to see if it would work better. When I found some nice 8" pneumatic caster wheels on sale for $ 12 each I figured I would give it a try.
First here are the materials. $ 10 worth of steel pre-cut from Metals Supermarket. 2 caster wheels at $ 12 each at Harbor Freight and $ 3 worth of hardware.
I had the 2"x1"x1/8" channel cut to 9" and 11" - however as you will see later the 9" was actually too long. First step is to make the angle between the two main pieces.
And then weld it together. Grind down the welds on the side as I will be putting on some reinforcing gussets. I also welded on the 4"x5" 11 gauge plate that will be used for mounting the casters.
The gussets were cut out of 5"x5" squares of 14 gauge steel. I split it down the middle to create two gussets out of each square.
The gussets goes on here and get welded on.
Repeat to make two of these assemblies.
Now I ran into my first problem. The holes are too close to the 2" channel and the welds interferes with the nuts when assembled.
Nothing a grinder couldn't fix though. The plate is welded in several other spots so it should still be plenty strong.
I then slotted the upright so it can be bolted to the rear of the snow blower and be adjustable in height.
Here is the full assembly with the 8" casters attached.
Compare the size to the previous casters I had made to try out. They worked great but they were just too small so they sank into the gravel.
Here they are attached. I am using the same bolt holes and hardware as the original rear skid shoes.
It worked great and I was very pleased after a test drive down the driveway. Then I tried backing into the garage - and oops - I see a problem
I had some extra 5/16" bolts available that I could use, so I came up with an alternate idea. I needed to move the wheels outboard a little to give more clearance for them to swing around. Since there is a thick reinforcement plate for the rear skid shoes I could drill in and tap extra holes. This is the first time in 15 years I have tapped a hole, but it worked out OK even with the cheap HF tap and die set.
After this I also found that the pneumatic tire really squished down when under load and the 9" down leg was too close to the ground. I took off approx. 1" and then painted the assembly.
Here are the casters fully installed. I have them set to leave the cutting edge about 1" above the level. I also cut the slot longer so I can raise it higher if needed.
I drove it down the driveway and it all looks to be working good now.
As you can see I had a few issues along the way, but I think the result turned out very good. We will see when the snow comes if they work better than my fixed wheels last year.
At least if everything else fails it is fully reversible and I can always put the old wheels from last year on again.
Hope you enjoyed seeing my mistakes so you don't have to make your own
1999 Agco Allis 2025 (Simplicity Legacy) - 25 hp Kohler with 60" deck and 60" Snow Blade
2001 Simplicity Legacy - 20 hp Kohler with 3 point hitch, 54" deck, 48" FEL and 47" 2 stage Snow Blower
2003 Simplicity Legacy - 23 hp Kohler with 54" deck and 3 point hitch
Alan Lloys is offline
post #2 of 20 Old 11-23-2011, 11:09 PM
Aksarben96's Avatar
Re: Snow blower mod for gravel driveway (Pictures) - large caster installation
Nice piece of engineering , only through trial and error will we all learn . Can't predict if its the final design until you have some snow you can play , pardon work with but seems pretty good to me . Hope you will post a video to show this mod in action !
1974 JD 140 H3 with Johnson 12A loader,48" mmm ,54" 4 way plow,precisefit spreader
1999 Ariens LT12,Agri-fab poly 10 cart,
Brinly poly roller,Husqvarna trailer 275
Troy-bilt Pony Tiller
1995Toro 824 powershift w/cab, John Deere 14sbs sp
1993 Snapper 5hp mulch convert. sp.
Nebraska Winter http://www.youtube.com/watch?v=xvqF768uDxM
Nebraska Green http://www.youtube.com/watch?v=OeNt_3a6OT8
Hail http://www.youtube.com/watch?v=3U79qL5fofQ
Aksarben96 is offline
post #3 of 20 Old 11-23-2011, 11:14 PM
MTD 990 Twactor Guy
SammyRye's Avatar
Images: 15
WTG Alan - Very nice job on the engineering and fabrication. Looks like it should work just fine.
Rich
1973 MTD 990 (Silver) 16 hp B&S Single
1982 MTD 990A (Red) 16 hp B&S Single
2003 Craftsman LT2000 22 hp B&S Twin
Reduce - make do with what you have,
Reuse - give it new life by being creative,
Recycle - if you can't use it, maybe someone else can!
http://www.wunderground.com/US/WI/La...typeclick=big2
SammyRye is offline
post #4 of 20 Old 11-24-2011, 12:51 AM
Images: 9
Nice job!
Hope it works as well as it looks. If it does you could probably sell some as many have a problem with their gravel driveway. Good luck.
pfreiburger is offline
post #5 of 20 Old 11-24-2011, 01:57 AM
rubadub's Avatar
Very nice indeed, plus you took the time to put the nice clear pictures on
Rob
rubadub is offline
post #6 of 20 Old 11-24-2011, 04:43 AM
USMC
slkpk's Avatar
Images: 21
Thanks for sharing with us and let us know how it works out for you. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #7 of 20 Old 12-10-2011, 11:15 PM
mbrun's Avatar
Good work. I can see that being beneficial.
~~~~~~~ 2010 JD x500 ~~~~~~~~
..Brush Guard, 48" Snow Blade, Electric Blade Lift
..Custom Blade Squeegee & Dollie
..P796 Halogens
..JP Electric Sleeve Hitch
..RimGuard Loaded Tires (+92lbs extra, each)
..DR Power Grader
..Dual 50lb Wheel Weights, Chains
..PrecisionFit/Agri-Fab 45-0299 48" Core Aerator
..Brinly Aerator/Seeder, Moldboard Plow,
..Box Scraper, Dethatcher (On Loan)
..Craftsman 48" x 18" Roller
..Brinly 25-Gallon Tank Sprayer
mbrun is offline
post #8 of 20 Old 12-11-2011, 07:19 AM
redmule's Avatar
Great Job.
redmule is offline
post #9 of 20 Old 12-11-2011, 10:27 AM
I hope it works for you in the ice and snow when all the casters and wheels freeze up. That is the problem I see with these conversions. If you have the tractor in a heated garage it may not be a problem. Roger
rhenning is online now
post #10 of 20 Old 12-11-2011, 10:42 AM
We're all friends here
APinNY's Avatar
Images: 5
Nice work Alan. Good fab job.
Al
Kubota BX1860, 48" fine cut mulching MMM, FEL, snow thrower, cab, Heavy Hitch
TroyBilt LTX 13, (given away)
DR Lawn Vacuum. Review here
APinNY is offline
post #11 of 20 Old 12-11-2011, 06:53 PM Thread Starter
Alan Lloys's Avatar
That is a good point I really had not though of.
But I do have a heated garage and usually the snow and ice melts off the snow blower before it is needed next time.
So I think I will be OK.
I will report back once we get some snow around here.
post #12 of 20 Old 01-21-2012, 08:46 AM
cyser man's Avatar
Very Nice pics! I have been thinking of doing the same. I hate having to lift the blower everytime i back up! Have u had a chance to use it yet?
Name's Sean. 2000 Craftsman, 20hp, Snowblower attachment.
cyser man is offline
post #13 of 20 Old 01-21-2012, 10:19 AM Thread Starter
Alan Lloys's Avatar
No use yet - this winter is a bit weird.
We have about 1-2" on the ground only. So far I have used the plow for two small swipes in front of the garage and that is all. There is not even enough snow to try the blower on the lawn.
I did get my float position fixed on the tractor which should make this setup work even better. The plan is to leave it in float and then just have the casters hold the blower up. That way it should follow the contours of the driveway.
If we ever get enough snow here I will see if I can take some pictures. With my luck it will snow while I am traveling instead and my wife will be stuck at home since she is still sick
post #14 of 20 Old 01-21-2012, 10:51 AM
firefighter5143's Avatar
Images: 15
Looks real nice. I finally got a good snowstorm yesterday to try out my new rig. Up N I have been using my single stage on the gravel driveway and I just put the skid shoes all the way down and I don't seem to have a problem throwing rocks. I bet the 2 stage is considerably heavier so my guess is the shoes dig in.
SIMPLICITY
firefighter5143 is offline
post #15 of 20 Old 01-21-2012, 02:50 PM
GB in MN's Avatar
Images: 5
Nice work great fabrication should work like a charm.
GB in MN
72 Sears G16 Suburban "S3"
67 Sears Suburban 12 "S1"
48 Earthmaster Model C
60 Sears Suburban DB
66 Sears Suburban 10 "S2"
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1949 Economy Standard
1984 Simplicity 7790
GB in MN is offline
