Another project coutesy of my BIL - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 11-19-2010, 10:40 PM Thread Starter
Still lovin' the 322!
PA318Guy's Avatar
Well, he visited last year for Christmas and was taken with the tractor and the "toys" I had for it! So he decided I just didn't have enough so now look what I got! Now I have to figure out how to mount is so it can be used front and rear on my tractor, and on my trailer! Maybe my sister didn't do so bad after all!!!!
Current Machine JD 322
PA318Guy is offline
post #2 of 14 Old 11-19-2010, 11:20 PM
TooManyGT's Avatar
Re: Another project coutesy of my BIL
Nice! I just got one of those for my little trailer, seems to work really well just has a little delay after you release the button.
What did you have in mind for a mounting system?
Brad
Kubota '10 B2620 w/LA364, Homemade bucket QA, Homemade Hyd. grapple bucket, homemade backhoe.
Wheel Horse '93 520H 60" deck, 48" blade
Simplicity '64 Landlord, Mid-grader blade, 46" front blade, sickle bar, Hyd-lift, deck.
Case 444, 48" deck, 54" front blade, 41" tiller, 3pt
Simplicity GTH20 & Deutz 1920 Diesel (under construction)
TooManyGT is offline
post #3 of 14 Old 11-19-2010, 11:24 PM Thread Starter
PA318Guy's Avatar
I'm trying to figure out something I can drop into my front weight bracket, hook over my 3 pt hitch, and drop into the area behind the jack on my trailer! I'd like it to be simple with maybe a catch or pin arrangement on the bottom to keep it from "lifting". It should fit all three locations withoutany modification (interchangeable locations)!
PA318Guy is offline
post #4 of 14 Old 11-20-2010, 07:56 AM
TooManyGT's Avatar
I can see the front weight braket and trailer being easy because you can make a matching braket for the trailer based on the weight bracket. The 3pt might require making an adaptor the the winch can pin onto. Sounds like a fun project. Can you post up pictures of the weight braket? Sounds like thats what the mounts are going to be based on.
Brad
post #5 of 14 Old 11-20-2010, 09:32 AM Thread Starter
PA318Guy's Avatar
Brad
Here is the front weight bracket! It holds up to 8 suitcase weights so I figure it should do a good job of holding the winch in place. I'm thinking a plate with a couple of square posts in it that goes through this, then have adapters made for the 3 pt. and trailer to match. I'm also going to have to mount an electrical connection on the tractor and my truck that it can be plugged into (heavy duty exterior).
PA318Guy is offline
post #6 of 14 Old 11-20-2010, 11:01 AM
TooManyGT's Avatar
Hmmm, looks like if you can copy the "hook" section of the suitcase weight and find a way to pin it in so it can't come back out by accident.
Brad
post #7 of 14 Old 11-20-2010, 04:52 PM
DMAC's Avatar
Images: 39
PA318Guy
Very nice gift, trade BIL's?
On your 3 pt hitch, did you make a 2" receiver attatchment? If so you could add a 2" OD square tube to the winch and plug it anywhere there is a 2" receiver. This has worked great here; it plugs into the tractor front and rear, the truck in the rear and the front of the flatbed (to pull objects on to the bed) also the front of the truck. Loan it to a buddy with a 2" receiver etc.
DMAC
Cub Cadet 3204 with:
54" Dozer Blade w/carryall sides
45" Snow Thrower, Snow Cover, lights+weights
3 Point Hitch w/2" receiver
23" Rear Ag Tires, 18" Front, 4-Ply
Dual Lift front hitch w/Angle
Homemade: front bucket, dirt scoop, boom pole, york rake.
3 point ripper, winch, battering ram, hyd press, crane, etc. Front or Rear hookup
DMAC
DMAC is offline
post #8 of 14 Old 11-20-2010, 05:03 PM Thread Starter
PA318Guy's Avatar
Originally Posted by DMAC View Post
PA318Guy
DMAC
DMAC, good idea! I guess I could rig up an adapter for the front weight rack to hold a 2" receiver too! Good thing is that Walmart stocks them so I've got some close buy! Do you have any pics of your setup you could share?
Thanks!
Tim
PS For the time being I'm keeping my BIL!
PA318Guy is offline
post #9 of 14 Old 11-20-2010, 05:36 PM
DMAC's Avatar
Images: 39
The winch plugged into the tractor.
The winch welded on to the 2" square tube with a scrap plate that holds the controls and the electronics. Also the reveiver for the flatbed, it mounts 12" above the bed for a decent pulling angle.
DMAC
DMAC
DMAC is offline
post #10 of 14 Old 11-20-2010, 07:17 PM Thread Starter
PA318Guy's Avatar
DMAC, started working on one of my other projects for a while (they never stop), thanks for the pictures, looks like it works very well. This has a wireless controller so I'm going to have to see the range on that. Also, I'm going to have to check out an electrical store to see what kind of 2 wire heavy duty outside connectors they have. I want a simple quick connection!
PA318Guy is offline
post #11 of 14 Old 11-20-2010, 08:33 PM
Littledeere's Avatar
Images: 45
Connectors used on jumper cables on tow trucks work great they plug right up and are made for a high amp pull and they are coated for protection.They look like the same thing they use on electric fork lifts to plug up the battery. Bought mine years ago from Snap on I will try to get you a pic
Littledeere is offline
post #12 of 14 Old 11-20-2010, 11:24 PM
tiny tractor big interest
Grainger stock those in a couple different sizes as well. Used a pair to quick connect the Amplifier leads in my motorcyle saddle bag
Adam
lx176mainer is offline
post #13 of 14 Old 11-21-2010, 11:41 AM
JRC0528's Avatar
Look up Anderson Connectors on feebay.... I bought a pack of 10 there, smaller 2 conductor sized for 8 AWG wire. I think they are rated 50A, but they work great for the RC winch!
Like DMAC, I also mounted my winch on a 2" square tube. I have receiver tubes on the front and rear of the tractor and the back of the truck. An Anderson connector is installed on the side frame of the tractor and in the bed of the truck for convenient power hook-up.
Jim C.
Many a man in love with a dimple makes the mistake of marrying the whole girl!
-- Stephen Leacock on the danger of infatuation
JRC0528 is offline
post #14 of 14 Old 11-21-2010, 04:23 PM Thread Starter
PA318Guy's Avatar
Thanks for all the ideas on the electricals! I'll have to check them out!
PA318Guy is offline
