Snowblower chute tilt control wth wires? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 11-08-2010, 09:46 PM Thread Starter
C2H8O's Avatar
Images: 7
I have searched the forums but have not been able to find a chute tilt control with wires
I am readying the Bolens snowblower attachment for the winter. I modified and mounted the chute rotation control. Now it would be great to control the chute tilt from the seat, and bicycle brake cables seem OK. I think electric actuators are too expensive for me.
DougL
C2H8O is offline
post #2 of 11 Old 11-08-2010, 10:42 PM
Re: Snowblower chute tilt control wth wires?
This is what I used on a JD I used to own. Small linear actuator and home made brackets. Roger
ID:	128451   Click image for larger version
ID:	128452   Click image for larger version
rhenning is offline
post #3 of 11 Old 11-08-2010, 10:55 PM
The Ariens blowers used on the GT and Grand Sierra tractors used a cable for positioning the deflector from the operators seat. It was a single cable, heavier than a bicycle brake cable though, and would lock in position with a quarter turn of the operators handle on the end. It mounts to the same bracket that holds the chute crank near the operator, and on the chute there is small angle bracket for holding the cable housing. The cable attaches to the deflector with a small tab welded to the deflector. A small drawing could be seen here - http://www.rcpw.com/lookup/?aribrand...QT/74HFlnnAA==
It would be very easy to make and attach the two little brackets on the chute and deflector to hold the cable. I've never tried a bike cable so I don't know if it would be strong enough for the push/pull but a cable assembly from an Ariens parts supplier (complete with handle, attaching nuts, and threaded pivot for attaching to deflector) runs about $70.00 or so.
I'm adding this to my Ariens tractor blower for this season. I haven't installed it yet so I can't get any pictures for you right now, but I'll have it done in a couple days and can take some pics if you're interested.
Just a thought.
lh7018 is offline
post #4 of 11 Old 11-09-2010, 10:18 AM
DGS 6500 - North Dakota
Here is the manual cable setup on my Bercomac. That dark black "rod" looking thing on the far left is actually a spring. There are some nylon washers that help the deflector move up and down easily. But it still takes the force of the snow to move the deflector up.
http://www.bercomac.com/images/fichi...0843090643.pdf
92merc is online now
post #5 of 11 Old 11-10-2010, 01:53 AM
kccraftswoman
kccraftswoman's Avatar
Images: 17
Smile Re: Snowblower chute tilt control wth wires?
i used a window motor for the rotate and might be using an electiric actuator that i am watching on ebay.if i don't get that motor, then i will go to plan (B) and use a window motor for the up and down and i am trying to find a circuit to run both motors by 1 joystick(that i bought off ebay cheap).when i find the circuit that will work i'll pass it along .i do know that there are at least 4 relays in the circuit for both motors. tootles . K.C.
kccraftswoman is offline
post #6 of 11 Old 11-10-2010, 01:19 PM
Cranky Motorsports
GT_80's Avatar
Images: 32
a bike cable would only work if it had a spring return in one direction- they are menat to pull only not push- on the other hand a cable that is used for a Hurst or B&M shifter for a car would work well... Just a matter oh how and where to hook it up and how much travel you need... I just as soon get off the tractor to change the chute angle- it almost NEVER gets moved on my machine, and the chute rotates side to side with a rotating handle and cable assembly
B&M replacement cable
MTF Addict #35886
Hugh-SS/16 fan #0001
I love Onans, Tecumsehs, and diesels!
1967 Suburban 12 "The 679"-Yanmar L70 Diesel swap
1967 Suburban 10 - soon to be trike with tecumseh again
1967 Super 12 - nice original
1968 Super12 "Miss Emma Lee"
1968 Super 12 "C&B Special"
1970 Suburban 12
1971 SS14
1973 SS16/ 18/6 Diesel hybrid "D10S"
1974 SS16 - rescued
1976 SS18 "Trusty"
1978 GT18 with Hard cab
Attachments: lots
My YouTube
My Ebay
Sears Manuals
GT_80 is offline
post #7 of 11 Old 11-11-2010, 09:05 PM Thread Starter
C2H8O's Avatar
Images: 7
The info and pictures helped, thanks! I agree a bike cable is not enough to push. I am going to try two cables in a pull-pull arrangement like the Craftsman units. JD has a single cable pull with a spring to rock the deflector the other way.
I will post pics showing how it goes or if it turns out totally ridiculous.
DougL
C2H8O is offline
post #8 of 11 Old 11-14-2010, 12:07 PM
jaynut's Avatar
Images: 16
here's what I built with a cheap 12v motor, 1/4" drive socket universal joint, & some 1/2" threaded rod - I had a little trouble with it detting stuck at the ends though, so I put compression springs over the 1/2" rod on either side of the nut mounted on the chute & it works great now - just have to keep it lubed up
ID:	129280   Click image for larger version
ID:	129281   Click image for larger version
ID:	129282   Click image for larger version
jaynut is offline
post #9 of 11 Old 11-14-2010, 01:35 PM
standard issue neuralyzer
LLigetfa's Avatar
I saw one that used a motor from a cordless drill. Most people have a few of those around that the battery has expired on.
If you want to go with steel cable, use two cables pulling in opposite directions, not one with a spring return. Water invariably gets inside the cable and it freezes. At least with two cables you have a chance to work it loose.
LLigetfa is offline
post #10 of 11 Old 11-14-2010, 02:59 PM Thread Starter
C2H8O's Avatar
Images: 7
Here is the first functional design I came up with for the chute deflector. The cost was a $5 pack of bicycle cables and some scrap I had around. The Bolens deflector does NOT have a single pivot point, so it was more difficult to modify than other tractors. The handle is 1/2 of barbecue tongs.
I modeled the Ariens design. The return spring on most spring+cable systems is very weak; it depends on the blast of snow to lift it upwards so I used a little bungee cord. I also copied the cable lift control facing downward so water does not run into the cable sleeve
I really like the little 12v motor with a threaded rod. Very simple! I will try that if I can find a similar motor. Linear actuators are way overkill at $170.
I will let you know how well it works in snow!
ID:	129306   Click image for larger version
DougL
C2H8O is offline
post #11 of 11 Old 11-14-2010, 09:46 PM
kccraftswoman
Images: 17
well that is using your head i like the reuse of the bbq tongs. keep up the good work.
