3-pt chains? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 11-02-2010, 03:35 PM Thread Starter
3-pt chains?
Newbie Question. What is the purpose for the chains that criss cross on the 3pt hitch? I have installed an A-frame hitch adapter and now my chains are not long enough. Do I need them? Thanks.
Brian
bparent is offline
post #2 of 8 Old 11-02-2010, 05:23 PM
15,000+ Posts & Climbing
Re: 3-pt chains?
The chains are to keep the hitch from swaying left and right and usually have turnbuckles to slacken them off or tighten them up.
You really don't want to use a backblade, or any other implement, without them if you're close to a car or house or anything else that can be damaged by the implement swaying from side to side.
TUDOR is online now
post #3 of 8 Old 11-02-2010, 08:24 PM Thread Starter
Re: 3-pt chains?
Copy that. I will get some longer chains. What about the two threaded rods that attach the rock shaft to the lift arms. Do you adjust these to gain lift height or how low the implement will go down? Thanks.
Brian
bparent is offline
post #4 of 8 Old 11-03-2010, 04:01 AM
Re: 3-pt chains?
The top link adjusts the angle of the implement to the ground, eg. shorten the top link to make a back blade stand up straighter for scraping, or lenthen it for digging. Trial and error to find what works for you.
The threaded rods on the lift links allow you to level or tilt the implement based on what is required to do the job. Lenghten one and shorten the other and you can do ditching with a backblade. Another reason for the anti-sway chains.
The range of lift and lower can also be moved higher or lower with the levelling screws but there should be lots of lifting range on your 3PH so this isn't normally a problem. If you adjust to raise the implement higher for transport, you lose on the depth it will go down.
What make and model of tractor?
TUDOR is online now
post #5 of 8 Old 11-03-2010, 07:17 AM Thread Starter
Re: 3-pt chains?
I see. Thanks again for the info. The tractor is a Yardman 998 series. I dont have any ground engaging implements for the 3pt. just the hitch reveiver adapter so I can jocky my trailer around the yard. I basicly bought it to be used as a spare mower just in case something happens to my Gravely. Plus now I have a fun toy to tinker with. It came with a 50in deck and a 54in snow blade. Here are some pics. Thanks again for the info.
Brian
ID:	127597   Click image for larger version
ID:	127598   Click image for larger version
ID:	127599   Click image for larger version
bparent is offline
post #6 of 8 Old 11-03-2010, 12:53 PM
Re: 3-pt chains?
Looks like it's in real nice shape! Should'nt have any trouble pushing snowflakes with that!
TUDOR is online now
post #7 of 8 Old 11-04-2010, 08:30 AM
3K & Yet So Little to Say
ColonyPark's Avatar
Re: 3-pt chains?
I don't think I have ever seen a Yardman that beefy, nice find and thanks for the pics.
2011 John Deere 1026R w/60" 7Iron Drive Over NON AutoConnect MMM and FEL and 47" Front Mount Snow Blower with "Wings" and 48" KingKutter II Tiller and 48" KingKutter Brush Hog and CountyLine CarryAll
1990 John Deere 185 w/46" Deck and PowerFlow Bagger
ColonyPark is offline
post #8 of 8 Old 11-04-2010, 09:23 AM
Yardman's Avatar
Images: 5
Re: 3-pt chains?
Brian
Hi Brian, That's a purty tractor you got there. It looks a lot like my 1996 MTD 999 tractor. Mine also has a 50" deck. 22 HP Kohler engine. I mow with my ZTR and have removed the mower so I can do "tractor things" with it. I bought a JD dozer blade on eBay and tried adapting it for my MTD. The cable in the picture lifts it fine, but I find that it doesn't "hold" the blade at any apticular angle. It's still a work in progress. I had a bracket fab'd for the snowblower to mount the drivesaft unit.
Name:	MTD Yardman 002 (Medium).jpg
ID:	127715   Click image for larger version
Name:	MTD Yardman 006 (Medium).jpg
ID:	127716   Click image for larger version
Name:	Dozer Blade Final 001 (Medium).jpg
ID:	127717   Click image for larger version
Name:	January 2010 pic 033 (Medium).jpg
Running FULL RABBIT! Ain't no turtle in me.
Yardman is offline
