Tow behind lawn leaf vac - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 53 Old 10-15-2010, 05:28 PM Thread Starter
Hi All,
Looking to purchase a tow behind lawn leaf vac to attach to my Husqvarna 20hp 46in for my large 1.5 acre annoying leave infested yard. Any thoughts or recomendations. Thanks All.
canigolf2day is offline
post #2 of 53 Old 10-15-2010, 05:56 PM
USMC
slkpk's Avatar
Images: 21
Re: Tow behind lawn leaf vac
Mulch it and be done with it. Lot easier than dumping and bagging. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #3 of 53 Old 10-15-2010, 06:25 PM
We're all friends here
APinNY's Avatar
Images: 5
There has been much discussion about lawn vacs on this forum. Here is a link to my review of the DR machine:
DR Lawn Vacuum Review
Any machine will beat the he%% out of raking.
Al
Kubota BX1860, 48" fine cut mulching MMM, FEL, snow thrower, cab, Heavy Hitch
TroyBilt LTX 13, (given away)
DR Lawn Vacuum. Review here
APinNY is offline
post #4 of 53 Old 10-17-2010, 04:48 PM
I bought a cyclone rake about six years ago. It does a great job . The hardware is stainless steel and everything about it is top quality. It folds up for easy compact storage and has a 3 year warranty .Go to cyclone rake . com and watch the video. I love mine!
gman2304 is offline
post #5 of 53 Old 10-22-2010, 11:53 AM
Recently purchased an Agri-Fab Mow N Vac from T-S. So far so good
99flhr is offline
post #6 of 53 Old 10-22-2010, 01:32 PM
I"d look at the Trac-Vac models.
CT-JR is offline
post #7 of 53 Old 10-24-2010, 12:04 PM
Lawn Boys Never Die
miller17636's Avatar
I have an agri fab as well. Great machine and it won't break the bank. Got mine at Lowes on clearence last year. They even threw in the remote hose kit.
2010 John Deere x320
1988 John Deere 318, 47" 2 stage snow blower, quick hitch, Cozy Cab Series II, 51 broom
1987 John Deere 332, 44 loader
1986 John Deere 330
Lots of Lawn boys
miller17636 is offline
post #8 of 53 Old 10-25-2010, 02:40 AM
I like my trac vac. though I sometimes I had one of their larger models so I wouldnt have to dump as often; you'll definitely need a larger one for that size yard
I bought mine used a year ago, needing carb work from sitting with old gas inside, working like a champ so far this year
if I had to buy another I would do so off season; as during leaf season the prices shoot way up even on used; I paid $225 for mine last year and drove 2 hours away to find it (was a Craigslist buy) because I don't mind mowing or snow removal but have always hated hand raking whether it was from a freshly mowed/overgrown yard or leaf season; and that was as-was condition; plugged carb and all; I had to "rob" a carb and gas tank from another machine (my brother's logsplitter) to be able to use the trac vac last Fall; that problem is now solved, everyone now has it's own "right" carb and gas tank once again; but when I found out that a guy that I know, bought an identical twin to my machine this past summer at the local annual tractor/Threshermens show for a measly $50 that only needed a new recoil starter spring I was pizzed.
mine's an '87 model, the one with the 8 cu ft 16" square X about 40" tall "box" as the catcher, not the ones that use the regular yard cart; I did see one of those type go at a local estate sale last summer for ~$525-550. and did see a few at local garage sales this yr but never asked since I have no place to put another;
there was an ad for one like mine at a garage sale about a month ago, like an hour away from me (Craigslist) that had one like mine listed for $50 "Ran when last used" but that was 4-5 years ago by the sellers estimate. so they are out there.
Don B. is offline
post #9 of 53 Old 10-27-2010, 02:33 PM
So little time.....
pintopkp's Avatar
Ditto. This is my first leaf season with mine and I absolutely love it. Great for bagging thatch after dethatching too.
pintopkp is offline
post #10 of 53 Old 10-27-2010, 10:35 PM
Tech Nerd Tractor Convert
Toolin's Avatar
I'm another satisfied Cyclone Rake owner. See the "Cyclone" link in my sig line below.
Paul.
i1050|Maint|Gov|Tach:ind,laser|Deck|Blade|JBJr|SBlow:Fit,Winch,Act|Chain|Cyclone|Sweep|Gators|Aerator|Cart|Knob|Hoist|Cab|Trailer|PC|Bits
"Grass is the cheapest plant to install and the most expensive to maintain." ~Pat Howell
Toolin is offline
post #11 of 53 Old 11-06-2012, 08:59 PM
I am going to look into a Cyclone Rake, I have had a very rough and trying experience with the 8hp DR lawn and leaf vac, tow behind....
In 2010, my first unit (which was later replaced free of charge) blew through 10 rubber engine couplers that prevent the engine from being damaged when there was a clog. Nothing was clogging the machine but 10 rubber gears were shredded and I replaced them.
For 2011 and 2012, the replacement machine experienced 5 rubber coupler failures but this was a big improvement over the original machine. In addition I have experienced the following issues with this machine:
1) Oil dipstick shakes loose and allows oil to spew from engine – needs to be monitored closely.
2) 4 large bolts holding the frame of the unit to the hitch have sheared off twice – I was finally able to find strong enough bolts from local hardware store to prevent them from shearing. (grade 8 bolts)
3) The universal deck adaptor is of such a shape that even slightly moist grass and leaves create clogs in the output chute just off the deck. This does require shutting off your tractor due to closeness to mower blades. The adaptor seems to collect the grass and leaves at a large area at the bottom and they quickly have to launch up and out to a 45 degree angle that gets to be too steep when they are heavy and therefore backup and create a clog.
4) The black plastic thumb-pad screws to allow putting on and off 6 inch collection hose seem to only last 10 to 20 uses and when they break off you will need to have a pair of pliers to address the next, most important, issue.
5) Finally and most significantly, the 8hp lawn and leaf vac is very particular about wanting dry leaves with no twigs or sticks (sticks become twigs under a turning mower deck!) due to 1) the internally ribbed hose that enters a 90 angle plastic chute at the rear of the ‘box’ catching twigs in the hose or the 90 angle chute itself being a tough turn for the twigs and/or 2) the coupler between the hose and the 90 degree plastic angle warping outward within the 6 inch flex hose causing a greater surface area for twigs to grab on and clog the hose. I found myself getting about 15-20 feet of travel while using the product before I had to dismount, undo the hose at the rear of the box and unclog the hose, reattach the hose and get going again.
I have a 3 acre yard and I have found the product to be unusable in my particular situation.
ryanmad2000 is offline
post #12 of 53 Old 11-12-2012, 09:53 PM
Retired & lovin it!
Newsman's Avatar
I also have the Cyclone Rake. Have had it for eight years and it has really proved it's worth. Especially like the 20 foot long vac hose for flower beds and under shrubs and hedges. Sometimes there are areas you just can't get with a backpack blower.
MikeC
Newsman is online now
post #13 of 53 Old 11-13-2012, 08:58 AM
Have Dog - Will Travel
Jere39's Avatar
I just posted this same info in the JD forum to a similar question, but it appears to a different audience. I have a TracVac 880. I am perfectly happy with the results I get. But, I'll be the first to admit I do not get 100% clean up. Part of the problem is the combination of leaf leak out the front of the deck and exhaust routing on the JD x728 blowing leaves out of the path of the deck. The bigger issue is leaves never quite all fall, so there is a perpetual, though decreasing replenishment of the leaves on the lawn.
As mentioned by a few, the TracVac does not collapse, nor fold up. It takes a significant chunk of storage space. The best I can offer there is, I store stuff inside it over the winter, like a trimming mower and a wheelbarrow. Not optimal.
I made this youtube video of my set up working the leaves: http://youtu.be/njiJli4PpXI
Here is a little time-lapse from that same day:
Before:
2 Passes:
Half Finished: (note the leaves left behind)
Finished, at least for a day, you can see a few trees still clinging to some leaves, and my entire lawn is surrounded on all four sides by second generation PA hardwood. There is no such thing as the "end of leaf clean-up"
Disclaimer - These pictures and video are from last year.
Jere39 is online now
post #14 of 53 Old 11-13-2012, 09:24 AM
APinNY's Avatar
Images: 5
Jere, your Trac Vac does a nice job. I also have perpetual leaf fall. Certain beech leaves fall all winter long and some stay on until spring. As to the exhaust pipe, I read somewhere on here that a member fashioned a curved extension pipe, for a different reason. That might work for you. That's a nice piece of property you have. If storage is a problem I would put up a bulding or shed. Just sayin'.
Al
APinNY is offline
post #15 of 53 Old 11-13-2012, 09:41 AM
Ratchet Jaw old Member
drbailey's Avatar
I bought a pull vac last Fall, I had no problem liking it right off. I have used it three times this year,as you can see I need to get to work on the leaves again(now!) I think it will take two more vacs. for the year.
Craftsman from Sears, I also have a hose ext. for hard to get to spots.
If I remember right, it list for $1600.00 last year. there were discounts at the time, I gave $1300.00
drbailey is offline
