metal vs poly lawn roller - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 33 Old 03-07-2010, 11:45 AM
Paranoid's Avatar
Location: That which does not kill me will probably hurt like hell
Images: 6
Re: metal vs poly lawn roller
I have a 36" plastic, with rounded edges that weighs about 500lb when filled. I only use it a few times a year to flatten out my lawn and it suits me fine. Got it from Northern Tool.
2009 Cub GT-2542, front 2" receiver w/Winch, CC 42" Snow Blade, elec sleeve hitch
2007 Honda HRX 217
Stihl Farm-Boss & Mini Boss
Not Correctly Restored 1970 Stingray................
Paranoid is offline
post #17 of 33 Old 03-07-2010, 01:06 PM
Barbosa's Avatar
Originally Posted by subeluvr View Post
Ohio Steel's metal rollers have rounded edges...
That is a **** nice roller right there. And I'd wager it has a not so nice price to accompany it.
2003 Simplicity Prestige - 20hp Kohler Command - 50" deck - Gator G5 Blades - Blowout Baffle & Deck Re-enforcement Kit | EGO Cordless 56V Straight Shaft Trimmer | EGO 530 CFM 56V Cordless Blower | Simplicity 42" Dozer/Plow Blade | | 62LB x 2 wheel weights | Craftsman 10 cu.ft Poly Dump Cart
Barbosa is offline
post #18 of 33 Old 03-07-2010, 06:47 PM
Banned!
Barbosa, I'll take that wager and you can pay up...
Model 10T $189.99 with Free Shipping
http://www.yardandgardendirect.com/lawnroller.htm
You can't always get what you want, but if you try sometimes you can get what you want!
subeluvr is offline
post #19 of 33 Old 03-07-2010, 07:30 PM
Banned!
If you build a lawn roller in the neighborhood of 36" in diameter, where in he_ _ is flex involved. If you build anything out of any kind of plastic and expose it to the elements, it will start to deteriorate in 5 to 6 years. if you build it with 1/4" steel pipe, no matter how long you live, you will never live long enough to see it rust through.
gravely-power is offline
post #20 of 33 Old 03-07-2010, 07:53 PM Thread Starter
johndeere's Avatar
Images: 7
Seems to have a short tounge?Looks like the rear tire would hit if you turned short?Does it take 40 acres to turn that rig around?
The reason I was considering a poly roller.Is a friends Agrifab metal roller rusted and broke loose at the welded seam length ways across the drum.I looked at a Agrifab at Farm&Fleet this weekend and it has that seam and the metal appeared to be thinner grade then his.Soo im think polly again.
Home Depot has a 36wide 24diameter poly for $159.00 with free shipping.
johndeere is offline
post #21 of 33 Old 03-07-2010, 08:06 PM
Banned!
I favor the steel roller cause I use it on a gravel driveway. I'm sure a poly roller wold get punctured.
I have a Toro roller made by Ohio Steel (exactly the same as the 10T but without the round corners) that has been filled and outside since 1997. I added anti freeze with rust inhibitor and no problems so far.
Seeing the AgriFab products with my own eyes I can tell you that they are lesser quality versions of the top tier products from the likes of Brinly and Ohio Steel.
Turns around just fine and pulls just like the 600 lbs it weighs
How can you not buy American steel from Ohio?
subeluvr is offline
post #22 of 33 Old 03-07-2010, 08:27 PM
pfrenet's Avatar
I have a 48" poly roller. I originally filled with water, but it took a long time and the water pump ran quite a bit during fillup so I decide to fill up with sand the next year. I found that it worked better with the sand (actually added weight) and if I needed to take somewhere else, I just used the winch to pull it up on the trailer. I store it along side the shed in winter and it holds it shape.
pfrenet is offline
post #23 of 33 Old 03-07-2010, 09:35 PM
Barbosa's Avatar
WOW! That is an incredibly low price. To **** with the poly, I'd spend the extra $25 and get the Ohio Steel one.
Barbosa is offline
post #24 of 33 Old 03-07-2010, 10:06 PM
lynnr's Avatar
Yeah...caution against tight turns with this one. Halfway thru it's second season mine snapped clean off at the T. Fortunately on flat ground! TSC and Ohio didn't want to know about it of course.
Fixed that and it did another season until the axle shaft broke loose in that thin steel. Currently building a beefier hub. Oh yeah, patched that long seam a time or two as well.
I'd say, if you are OK welding your own stuff to keep it going, it's not so bad of a deal. Sure is heavy enough ;-)
- LynnR.
Just another hacker - bits and bytes by day, iron by night, trees on weekends.
lynnr is offline
post #25 of 33 Old 03-07-2010, 10:13 PM
Mouse's Avatar
Rolled the lawn today, I've had this poly for the past 6 years, I filled it the day I got it and never did anything else. I roll w/ it and thats all.
Mouse
1962 Cub Cadet Orginal
1963 Cub Cadet 100
1969 Cub Cadet 125
2009 Cub Cadet LTX1046VT
2011 Cub Cadet LTX 1040
1997 John Deere LX 178
Mouse is offline
post #26 of 33 Old 07-14-2010, 12:08 PM
Banned!
Question Re: metal vs poly lawn roller
So johndeere, what did you end up getting?
I am also in the market for a roller.
Markcuda is offline
post #27 of 33 Old 10-05-2016, 11:35 AM
IL X540
How are everyone's rollers holding up, now that it's been 5-6 years since you guys bought these?
jrkleins is offline
post #28 of 33 Old 10-05-2016, 03:19 PM
I have been using my poly roller for 4 years with water and no problems yet.
dilligaf1 is offline
post #29 of 33 Old 10-06-2016, 03:03 AM
bought a poly roller two years ago after the steel one we had rusted out on both sides where the handle attaches to it. no sign of rust on the new one.
dave_r is offline
post #30 of 33 Old 11-08-2016, 02:55 PM
My roller is pretty much indestructible I think.. Also just shy of being **** near impossible to move! It's metal frame and tongue, but the roller itself is cement! Must weigh....well, alot!
joshjv is offline
