Loading tires - Page 11 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #151 of 165 Old 05-15-2012, 09:04 PM
CraftMan's Avatar
Re: Loading tires
How about foam, there's a place that does it locally. They drill a hole in the side of the tire, pump it full of foam, then plug the hole with a bolt. It sets up solid and weighs a ton, no leaks....ever. They quoted me $65 per tire for a 23x10.5x12, kinda pricey but sounds like its worth it. I'd like to do all four on my big tractor. I did a wheel barrel tire with a can of expanding foam once, worked awesome.
1992 LT-12 38" deck (detail mower)
1984 GT-18 44" deck (awaiting restoration)
1984 GT-18 AG's, weights, dozer blade, sleeve hitch (work horse)
1993 MAX amphibious 6x6 16hp Briggs
1987 GMC Jimmy 350ci 8" lift 37" super swampers
CraftMan is offline
post #152 of 165 Old 05-15-2012, 10:33 PM
Re: Loading tires
at a lot of work sights they do this to the golf carts. makes them really bumpy.
2010 John Deere x728 with Front Fender Kit,
Hard-Side Cab With Heater 2- 4" LED Work Light from MOBILE HID
54-inch Quick-Hitch Front Blade,
Electric Broadcast Spreader,
72 lb. Cast-Iron Wheel Weights
6 Suitcase Weights
Bossgobbler is offline
post #153 of 165 Old 05-16-2012, 12:16 AM
OldBuzzard's Avatar
Re: Loading tires
Foam filled tires are great for being heavy, but absolutely awful for ride quality.
They have no flex, and they will beat you to death unless you have a REALLY well suspended seat. I wouldn't foam fill a GT's tires on a bet.
Bolens TF: 800, G10-04, G11-01(3), 1256-02(2), H14-02
Bolens LF: 1886-01 w/FEL, 1886-01 w/Forklift, 1886-01, 1886-02, 1250-01 (2), HT20D, HDT1000.
Bolens Estate Keeper 7
Attachments: More than I can list.
OldBuzzard is offline
post #154 of 165 Old 05-16-2012, 12:40 AM
15,000+ Posts & Climbing
Re: Loading tires
Even if you have a well suspended seat, the rest of the tractor doesn't and it will get pounded to an early death.
Foam filled tires are for smooth concrete floors, not rough terrain.
TUDOR is online now
post #155 of 165 Old 05-16-2012, 08:53 AM
CraftMan's Avatar
Re: Loading tires
Very good points gentlemen, guess I really didn't think about the ride quality of a lawnmower.
CraftMan is offline
post #156 of 165 Old 05-16-2012, 09:19 AM
Re: Loading tires
I skipped to the latest reply on this thread so may have missed this topic. But has anyone added fluid to tires on a MM ZTR ? My Gravley seams to skid alot. I know I can control spped and turning but I wondered if a little weight in the tires would help.
witco is offline
post #157 of 165 Old 05-17-2012, 02:08 PM
Tripp's Avatar
Re: Loading tires
This is the best product to use if you can get it in your area keeps the tires cool and also prevents rim rust and tire break down.
http://www.deltatiresealant.com/products.php
Tripp is offline
post #158 of 165 Old 05-17-2012, 07:13 PM
OldBuzzard's Avatar
Re: Loading tires
I don't know of any GT that would benefit from having 'cooler tires'. Plus, did you look at the pricing of that stuff?
I'll stick with Rim Guard, which most likely adds more wt/gal, and costs a heck of a lot less.
post #159 of 165 Old 10-29-2012, 01:53 PM
Re: Loading tires
I going to put 7 gallons of fluid in my rear tires. 23X10.5X12 turfs. what kind of air pressure should I put in afterwards?
318JD is offline
post #160 of 165 Old 10-29-2012, 02:42 PM
Re: Loading tires
The same as normal. With the smaller air chamber, it will ride harder.
TUDOR is online now
post #161 of 165 Old 10-29-2012, 05:38 PM
Re: Loading tires
I would use Rim Guard, but I get inhibited propylene glycol for free. I've heard the sales rep will drink a glass of it to prove how safe it is, but I haven't actually seen it myself. It's slightly heavier than water, and contains corrosion inhibitors. I've used various methods to get it into tires, but the last time I used a sprayer type pump. It took about 30 minutes to pump an entire 55 gallon drum into a 17.5-24 tire, and no stopping to let air out.
ID:	235021   Click image for larger version
rockcrawl is offline
post #162 of 165 Old 10-29-2012, 06:07 PM
Re: Loading tires
Has anyone put fluid is there front tires of a 318 or similar for more steering traction? I'm having trouble steering when the blower is down. The front tires are 16X6.50X8
318JD is offline
post #163 of 165 Old 10-29-2012, 06:55 PM
Contadino's Avatar
Re: Loading tires
I used my garden sprayer to fill my tires. Just removed the spray end and pushed the hose over the valve stem. Removed it every gallon or two to let the air out. Being able to pressurize the tank made it go pretty fast.
I'm going to try adding WW fluid to the front tires this year. Had some skidding last year when snow plowing. A few pounds might help a little anyway.
Contadino is offline
post #164 of 165 Old 10-30-2012, 12:14 AM
Re: Loading tires
As long as you don't have a FEL, no problem and it will help with stability on the slopes as well. I had a set of 16x6.50-8s loaded with calcium chloride many years ago on the rear of a LT for using the snow blower. There was about 25 lb in each tire.
Front wheel weights are also available. I have a set of 8" cast iron weights that weigh over 30 lb each.
TUDOR is online now
post #165 of 165 Old 10-30-2012, 03:00 PM
Re: Loading tires
Here is a thread I put up a while back about filling my tires with WWF. Some might find it interesting.
Tire fill IV!
squatch is offline
