Need to replace the oil seal on my shredder gear box- How do I find one? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 09-20-2008, 10:05 PM Thread Starter
1944 Ford 2N
bdoss's Avatar
Help Need to replace the oil seal on my shredder gear box- How do I find one?
My shredder's gear box started to leak oil (bad) thru the bottom seal - Took it apart today and found a wire had been warpped around the shaft and part of it slipped between the seal and the shaft- Din't cut the seal just opened a path for the gear oil to pour out.
Cleaned it up and reinstalled - The seal is holding pretty well , but but I'd like to get another one-
The shredder was purchased with the tractor (44 2N) and has been painted so thick I can't find anything to tell me the brand - it's pretty standard (5ft) and I seen a lot that look like it
The only markings are on the rear of the gear box AO(or-Q?)MO R-45-312
The bottom plate (which encloses the seal) has part number - AR40 314 (I think- reinstalled it before I wrote the part number down and the pic I have is blurred).
How can I find out what I've got?
Most important--Where can I get the part (oil seal)
how do I press the old one out?
Thanks for any input....
ID:	46347   Click image for larger version
Yesterday is not ours to recover,but tomorrow is ours to win or lose.
bdoss is offline
post #2 of 18 Old 09-20-2008, 10:06 PM Thread Starter
1944 Ford 2N
bdoss's Avatar
Re: Need to replace the oil seal on my shredder gear box- How do I find one?
Pics of the shredder
ID:	46350   Click image for larger version
bdoss is offline
post #3 of 18 Old 09-20-2008, 10:11 PM
standard issue neuralyzer
LLigetfa's Avatar
Just take that part with you to a bearing supply place and they will caliper the three dimensions and match it.
LLigetfa is offline
post #4 of 18 Old 09-20-2008, 10:21 PM Thread Starter
1944 Ford 2N
bdoss's Avatar
Thanks, LLigetfa,
Thanks for the prompt reply.
Unfortunatly the nearest one is 75 miles away and I don't think I could remove the old seal without destroying it - which is fine IF I have a new one on hand first..
I'm hoping someone chimes in and says it is a standard part number I can order over the web
bdoss is offline
post #5 of 18 Old 09-20-2008, 10:58 PM
Old Guy With Old Toys
raytasch's Avatar
Post a close up detailed picture of the gearbox and someone will ID it and go from there.
ray
Ford Jubilee-- restored, pulls a finish mower once in a while
Ford 850 -- the workhorse--does it all
IH CC 122--semi retired-awaiting restoration
JD 4300HST FWDA W/Loader--- another workhorse
Sears DGS6500
raytasch is offline
post #6 of 18 Old 09-21-2008, 09:53 AM Thread Starter
1944 Ford 2N
bdoss's Avatar
requested pics
ID:	46375   Click image for larger version
bdoss is offline
post #7 of 18 Old 09-21-2008, 09:54 AM Thread Starter
1944 Ford 2N
bdoss's Avatar
more pics
ID:	46378   Click image for larger version
bdoss is offline
post #8 of 18 Old 09-21-2008, 09:59 AM Thread Starter
1944 Ford 2N
bdoss's Avatar
even more
ID:	46385   Click image for larger version
bdoss is offline
post #9 of 18 Old 09-21-2008, 10:01 AM Thread Starter
1944 Ford 2N
bdoss's Avatar
and lastly
ID:	46387   Click image for larger version
bdoss is offline
post #10 of 18 Old 09-21-2008, 10:11 AM
Ther should be (or MAY be) a number stamped into the seal's outer steel ring or on the rubber seal itself,along with a brand name like "Chicaco-Rawhide","National",etc..look it over closely before attempting to remove it,for many times the I.D. numbers get destroyed during removal!..
You can probably pop that seal out with a screwdriver ot brake spoon ,used like a lever,don't hammer it out from behind unless it refuses to pop out,that way it leaves the part numbers intact in most cases,and lets you match it up to a new seal too..some places can supply seals just by giving them the measurements off the shaft it seals,and the housing O.D. and the width,if there is no number on it to go by..
Robert
Tractor-Holic is offline
post #11 of 18 Old 09-22-2008, 12:08 AM Thread Starter
1944 Ford 2N
bdoss's Avatar
Thanks, guys.
It's not leaking so much I have to change it now-- Hopefully will get another couple of years with it as is.. If it get's too bad- I'll try to remove it (whole) and see if I can find a bearing supply company that can help me..
bdoss is offline
post #12 of 18 Old 10-05-2008, 11:03 AM
my gear box says agmo R-45-312 on the casting and i just got areplacement seal number national seals number 473517 this is the lower seal and the upper seal number is 471192 My parts came from the local Massey Ferguson dealer. Hope this helps!
dzemcik is offline
post #13 of 18 Old 10-05-2008, 11:19 AM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
Thumbs up Re: Need to replace the oil seal on my shredder gear box- How do I find one?
dzemcik..
Thanks for the heads up!!
Enjoy all of the many Forums on MTF!!
Ken N Tx is offline
post #14 of 18 Old 10-05-2008, 09:03 PM Thread Starter
1944 Ford 2N
bdoss's Avatar
Thanks, dzemcik..
Welcome to MTF - You just added to my list of the best guys on the web!!
I'll check them out -- Getting tired of putting a pan under the shedder to catch the leaking oil!!!
bdoss is offline
post #15 of 18 Old 10-06-2008, 11:50 AM
DSPUK's Avatar
That looks very similar to one on the topper I use to cut mates field - next time I go I will get a close up picture - the oil filler hole is in same place and blades and plate look same
Tractor is Ford 1720 - taken bucket off front as he has a digger (back hoe )
Dave
DSPUK is offline
