Can a 4wd 20hp compact pull a 2 bottom plow? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 09-11-2008, 08:10 PM Thread Starter
me
queen of spades's Avatar
Images: 12
I found one that is cheaper than the new 1 bottom plow. thanks!
queen of spades is offline
post #2 of 11 Old 09-11-2008, 08:19 PM
Anything With Wheels
Argee's Avatar
Re: Can a 4wd 20hp compact pull a 2 bottom plow?
I have 27HP 4WD FordNH that labors when I pull my double bottom 14" with it. You can always remove one of the moldboards and turn it into a single bottom.
Randy G
Argee is offline
post #3 of 11 Old 09-11-2008, 09:37 PM
If ya got low enough gears and plenty of weight,,, sure, right up to the time you bust something expensive. I also have 26 hp 4wd AC and I had 2 bottoms on it, makes it work REAL hard, just not worth tearing up the trans or rear to me, I only pull 1 bottom 14" I can go at a good clip and get the furrow to roll real nice, even in sod. My plow was also 2 btm and I took one off, I plow less than an acre each year, and even if I did more I'd just get some more seat time!
js5020d is offline
post #4 of 11 Old 09-11-2008, 09:53 PM
Images: 16
Depends on the size plow. I built a 2-bottom with 10"ers and my 20hp gas 2WD tractor pulls it easy! I'm sure your diesel has more grunt than this 20hp Onan and with 4WD you should have no problem pulling twin 10's or maybe twin 12's. BUT they don't sell them this way, so you have to build or have one built.
Good tractors come in all colors but I'm a Massey Ferguson kinda guy!
http://gardentractortalk.com/
olcowhand is offline
post #5 of 11 Old 09-11-2008, 11:09 PM
Nice looking plow ya got there olcow!! Very inventive, I like it!,, maybe I could pull a 6 bottom?? Around here the "rule of thumb" for plows is 25hp/18", 20hp/16", 15hp/14", 10hp/12",,, guess that would make 10" bottoms 5hp a bottom,,, darn I can only do 5 if I stay with the rules,,, course I can pull that 1x14 at 5mph, with no weight on the tractor at all. I think a 5 or 6 would looks pretty sweet!
js5020d is offline
post #6 of 11 Old 09-11-2008, 11:23 PM
Just passing through
Upper5Percent's Avatar
depending on soil conditions...and design of unit...
http://www.deere.com/en_US/newsroom/...e_release.html
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #7 of 11 Old 09-16-2008, 03:24 PM
10,000 +posts!
One thing that helps make it eisier to pull is polish up the plows. As in get it shiney. When your done using it grease or oil it up then cover it so it doesnt rust.
Team_Green is offline
post #8 of 11 Old 09-16-2008, 03:45 PM
Images: 16
I modified this MF1650 with a 20hp Onan, and with loader mounted she weighs 1700lbs. That's with cast rear weights & 12 gallons fluid each tire. She's hydro with a 2 speed rear differential.
post #9 of 11 Old 09-16-2008, 04:04 PM
YEOW!!!!!!!!!!! That thing weighs just a little less than my CUT!!!! I come in at 1950 lbs with no weight. Mighty impressive spec's ya got there on that machine!
js5020d is offline
post #10 of 11 Old 09-16-2008, 04:30 PM
dirtgeezer
okieduc104's Avatar
I have seen farmers pull a four bottom plow with 4 horsepower , 1400 pound Percheons
(I was borned in Okiehoma but, my Pappy, brung me to Texxus cause he wonted me to git a god edjekashun!!)
okieduc104 is offline
post #11 of 11 Old 09-17-2008, 03:34 AM
2 bottom with 2 horsepower...
