Slip Clutch for Chipper/Shredder - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 09-01-2010, 12:31 PM Thread Starter
Ex City Boy
OneTrack's Avatar
I could use some advice. I have a BearCat 554 Chipper/Shredder (like this: http://www.bearcatproducts.com/outdo...0PTO%20Chipper) It is belt driven, and is shipped without a clutch.
However, my PTO shaft is twisted, presumably from jams. So I would like to add a friction-type slip clutch to the PTO shaft. Some relevant data:
Tractor: Kubota BX1860 with 13 HP PTO (1500 in.lb PTO output torque at 540 rpm)
Tractor PTO output: 1-3/8 in. 6-spline, male
Chipper input: dia. 1 in. smooth round shaft with key
PTO Shaft: Metric Series 1
I have spoken to BearCat about this, and they simply say that a clutch is not necessary; they rely on the belt drive to act like a slip clutch.
I have spoken to Weasler Engineering (they make clutches and PTO shafts) and they do not make any clutches with torque settings that low.
I have not been able to find a suitable clutch elsewhere. Can anyone steer me in the right direction? Has anyone here put a clutch on a low-torque tractor?
Thanks for the help.
S.
(Yes, I know the tractor is undersized for that chipper/shredder Ė but itís all Iíve got.)
Kubota BX1860
Kubota Implements: FEL, 54" MMM, Snowblower
Kubota Options: Rear Remote Hyd
Other Implements: PTO TracVac, BearCat 554 Chipper/Shredder, Modified CM Dump Trailer, ETA Compact PHD
OneTrack is offline
post #2 of 8 Old 09-01-2010, 02:02 PM
JRC0528's Avatar
Re: Slip Clutch for Chipper/Shredder
You say it's a belt-drive on the chipper itself? Is it possible to adjust the belt tension on the unit itself? I'd see first about loosening the belts up just a little so that they'll slip rather than twisting the shaft. Sounds to me like they are too tight anyways if they're allowing it to twist the PTO shaft!!
If it uses a spring loaded idler can you replace the spring or otherwise adjust the spring's tension?
Jim C.
Many a man in love with a dimple makes the mistake of marrying the whole girl!
-- Stephen Leacock on the danger of infatuation
JRC0528 is offline
post #3 of 8 Old 09-01-2010, 05:01 PM Thread Starter
Ex City Boy
OneTrack's Avatar
A lighter spring on the belt tensioner isn't a bad idea...
S.
Kubota BX1860
OneTrack is offline
post #4 of 8 Old 09-01-2010, 06:40 PM
I've owned a number of Brush Bandit chippers, and have never seen any provision for any type of torque relief. Smaller Bandits don't even have a clutch, just direct belt drive. The belts are not considered a slip item, the engine should stall if the machine is overloaded. I think you need a bigger tractor or a smaller chipper.
rscurtis is offline
post #5 of 8 Old 09-08-2010, 01:46 AM
wally2q's Avatar
What the weasler folks told you is a bunch of bull.
Any implement can be used with this clutch (see pic. below).
And the clutch is adjustable from 0 in.lb. all the way to 30 or 40HP of equivalent torque (I can't remember exactly, but it's up-there).
I know, because I have one on my chipper...
cheers!
http://www.tractorsupply.com/pto-dri...-shaft-0271211
wally2q is offline
post #6 of 8 Old 09-09-2010, 09:55 AM Thread Starter
Ex City Boy
OneTrack's Avatar
Thanks wally2q. That's exactly what I need. Now I just have to find one in Canada. I have spoken to TSC here, and they don't carry it. I have spoke to my local Kubota dealer, and they don;t seem to know how to get a similar one... I'll keep digging.
Thanks again!
S.
Kubota BX1860
OneTrack is offline
post #7 of 8 Old 09-10-2010, 12:00 AM
wally2q's Avatar
call a few farm-supply stores. depending on where you live, you may get lucky, and they will carry one. Slip clutches are very common.
I got mine at Swanstons outside of Rockwood (near Guelph)
http://www.swanstons.com/
Now in relation to your twisted drive shaft - you may need to replace it, as it will not telescope properly when retracting and extending during lift and lowering operations (ie Jam and stress the tractor PTO shaft support housing).
wally2q is offline
post #8 of 8 Old 09-12-2010, 09:23 AM Thread Starter
Ex City Boy
OneTrack's Avatar
Thanks for the link. Yes, I noticed that the twisted drive shaft would not telescope properly. Have a replacement coming. I'll let you know how it all works-out.
S.
Kubota BX1860
OneTrack is offline
