down pressure - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 06-15-2010, 06:20 AM Thread Starter
down pressure
might have posted my question in the wrong place.
how do you get down pressure on a 3 point hitch.? are there aftermarket kits ava. to do this.
anyone done this to their tractor & how did it turn out.
thanks
candyman is offline
post #2 of 20 Old 06-15-2010, 07:12 AM
9K+ Poster
JDFANATIC's Avatar
Re: down pressure
candyman,
What are you doing that requires down pressure? Can you just add weight to the implement or re-angle the top link?
Cheers
JDFANATIC
JDFANATIC is offline
post #3 of 20 Old 06-15-2010, 08:27 PM
mhb@ufe's Avatar
Re: down pressure
thanks
The only down pressure kits I've heard od are for post hle diggers. I've never used one but have seen them listed by sone me manufacturers.
I used to know everything but I forgot most of it
Mark
Maines Antique Tractor Club:
http://www.maineantiquetractorclub.com/
mhb@ufe is offline
post #4 of 20 Old 06-15-2010, 09:58 PM
Just passing through
Upper5Percent's Avatar
Re: down pressure
You could install a TOP-N-TILT...
http://www.ccmachinery.com/TNT.htm
If you are doing this so you can exert down pressure it is not a good idea to do this. Most 3-point systems are not designed for the added down pressure force and will prematurely fail and cause unsafe situations with the added down force.
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #5 of 20 Old 06-16-2010, 04:49 AM Thread Starter
Re: down pressure
i am doing nothing that requires down pressure, but just seems like when you pay that much for a tractor it should have it.
paul, thanks for the link i`ll check it out. i wonder is this something that can be done without going to a dealer.
down pressure, why not.
hard to believe that no one has said here is how i did it. am i the only one that has ever thought about doing this. ??
massey gc 2610 tractor
candyman is offline
post #6 of 20 Old 06-16-2010, 06:52 AM
Re: down pressure
I can't understand why it would be needed. Adding down pressure would take the weight from the rear wheels. Adjusting the top link can do the job most of time. All my farm tractors had draft control that when useing ground engaging equipment like a plow had some down effect but otherwise it was not needed.
Jimmyjo is offline
post #7 of 20 Old 06-16-2010, 11:46 AM
15,000+ Posts & Climbing
Re: down pressure
No, your not. I built a 3PH for my MF12H GT many moons ago and used a 2-way cylinder for control, but no float position. It was great for changing tires, but don't even think of trying to control depth of cut. You run out of traction real quick.
With FELs on my 2 larger tractors, I have no problem getting the rear tires off the ground. Lift the front end with bucket down force and put axle stands just in front of the rear tires and relax the down force. Front tires go down, back tires go up. Simple.
TUDOR is offline
post #8 of 20 Old 06-16-2010, 05:57 PM
Phoenix125's Avatar
Re: down pressure
The problem with only using the top link to create down pressure is the angle of the implement will change once you extend the top link beyond the lower arms. Yes.. I, too, had thought about rigging up down pressure, but then I realized I can't think of any time I'd use it.
-William "Kim" - AKA: Phoenix125
2009 JD 2305, FEL w/ 53" Bucket & hooks, 54" MMM w/ Ind. Lift, Hydraulic Diverter, & JD Mulch Kit, 12v Port 1 & 2, (3) ROPS Lights, JD Ballast Box w/ Reese Hitch mod, JD 60" Back Blade, Harbor Freight Quick Hitch (27.5" due to old implement), Bro-Tek Skid Plate, Markham Welding Tooth Bar, Wallace 5' Box Blade, Frontier GM1060R Finish Mower, EZmover Hitch, Harbor Freight Winch, Clamp-On Pallet Forks from eBay, CountyLine Carry All, Agri-Fab Speader, Precision Dethatcher, County Line 5' Landscape Rake, Fimco 15gal 2.1 GPM Sprayer, TSC 48"x24" Roller, Precision Spreader, CountyLine 3pt Post Hole Digger
My 2305 & 200CX Maintenance Schedule Check List: PDF Excel
Phoenix125 is offline
post #9 of 20 Old 06-17-2010, 08:15 AM
JRC0528's Avatar
Re: down pressure
Adjusting your top link longer on most implements will help them dig in better. I have a ripper (like a mini sub-soiler at around 16" deep) that has no trouble digging and often stops me in 4WD Low w/ diff-lock!
Plows and even rear blades (in many cases) respond well to lengthening the top link. I admit I have hung weight off an implement a couple times, but it's certainly not the norm.
Jim C.
Many a man in love with a dimple makes the mistake of marrying the whole girl!
-- Stephen Leacock on the danger of infatuation
JRC0528 is offline
post #10 of 20 Old 06-17-2010, 08:23 AM
Re: down pressure
Far from the first to consider this option. My Dad built a back blade for a John Deere "G" that had down pressure using a PTO mounted pump and a three point system that hooked to the rear axle. This was around 1950. Worked well but was used only for grading the road and in the barn lots.
I agree with the other posters, set the draft on the implement and don't tear up the three point hitch.
Mike
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is offline
post #11 of 20 Old 06-17-2010, 08:51 AM
UK Poster
Simon Smith's Avatar
Images: 13
Re: down pressure
Never had or even seen a tractor with down force on the three point, not even the Ford 8210. it was originally designed so that the implement would pull down all four wheels of the tractor and improve traction compared to trailed implements. Down pressure would completely defeat the object. If a plough or other ground engaging equipment is not penetrating the soil then it isn't set up correctly.
1992 LandRover Defender 110 County
1968 Wheelhorse Commando 8 (mine)
1968 Wheelhorse Commando 8 (unrestored, shared)
1972/2005 Wheelhorse Dual Drive (triple D, shared)
1972 Wheelhorse GT14 (unrestored shared)
1972 Wheelhorse Raider 12 (unrestored, shared)
2011 Triumph Tiger 800XC
Simon Smith is offline
post #12 of 20 Old 06-22-2010, 05:12 AM Thread Starter
Re: down pressure
thanks for the replys. i`m still gonna check it out down pressure with free float . seems like there would be a lot of times it would come in handy.
this tractor stuff is all new to me not sure if i`m using the right terminology.
cm
candyman is offline
post #13 of 20 Old 06-22-2010, 12:06 PM
Re: down pressure
As other sage tractor users have said, totally unnecessary, get the implement adjusted properly and you dont need it. Forcing most implements down only takes weight off the main drive tires and obviously causes loss of traction, I dont see the point as most manufactured implements are designed to use the "natural" draft principle anyways.
Good luck on your endeavor to build a "better" mouse trap though.
js5020d is offline
post #14 of 20 Old 06-22-2010, 12:43 PM
UK Poster
Images: 13
Re: down pressure
Personally, I think either you will end up with zero traction or something will break! I wouldn't even consider such a mod. You are trying to undo all Harry Fergusons hard work.
http://en.wikipedia.org/wiki/Harry_Ferguson
post #15 of 20 Old 06-22-2010, 12:45 PM
Re: down pressure
My old Farmall 460 has downforce, but have only used it with the PHD, but since it came with the 2 point and equipment bar standard, so I had to get a three point conversion kit for the PHD
