how much do wheel weights weigh? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 01-19-2010, 09:57 PM Thread Starter
Does anyone know how much wheel weights or the front suitcase type weights weigh?
I'm trying to add some weight to my JD3320 so when I have my forks attached I don't have to keep my shredder attached. I've seen those ballast boxes, however thinking of other options.
jnh92 is offline
post #2 of 15 Old 01-20-2010, 01:36 AM
P B G's Avatar
Re: how much do wheel weights weigh?
If you hit up Deere.com you can get info for the 3320, including parts catalog.
http://jdpc.deere.com/jdpc/servlet/c...o=20&page_no=2
According to which
8 T19293 WEIGHT 2 50KG (110 LB) (STARTER/ADDITIONAL WEIGHT) (USE WITH 11.2 - 24 R1 TIRES)
10 BM17968 WEIGHT 2 23.6KG (52 LB) (STARTER/ADDITIONAL WEIGHT) (USE WITH 15 - 19.5 OR 43 X 16 - 20 R4 TIRES)
So the first is 110 lb, the second is 52 lb for that tractor, depending on set up.
Now the suitcase weights are available in different weights, but I'm unsure of the brackets capacity, and wasn't able to find it quickly. If you don't get an answer I'll look tomorrow.
There's also tire ballast, which both tire and wheel weights have the advantage of not adding load to the tractor. it would be heavier on the trailer, but not on the axles. Where as a large ballast box is all on the axles.
Good luck with your searching.
P B G is offline
post #3 of 15 Old 01-20-2010, 09:13 AM
I opted to go with fluid in the rear tires on my 3320. Dealer quoted me $320.00 for starter kit and 2 110lb. weights. Magneizium Chloride and water installed 420 lbs. for $135.00. Only had done 2 weeks ago. Not had a chance to try out yet. 61" front bucket, frointer forks, 2060 Frointer BB, 7"york rear blade, 5" woods bushhog, JD 4' tiller, 6' disk. Good luck with your choice of ballast.
witco is offline
post #4 of 15 Old 01-20-2010, 09:14 AM Thread Starter
thanks for the info!! that was great...is that 110lbs for each or the pair total weight? I couldn't quite tell. Thanks again, I guess I should have read, hear at work we have a saying "RTFM" which means "Read the Fu*@!#$ Manual" too funny, thanks again.
jnh92 is offline
post #5 of 15 Old 01-20-2010, 09:22 AM Thread Starter
Witco...that is pretty reasonable pricing? I'm curious to see how it performs, did you notice a difference at all? That's definately another option.
jnh92 is offline
post #6 of 15 Old 01-20-2010, 12:35 PM
P B G's Avatar
I think the larger weights are 110 each, I can't see them having a 25lb rear weight option for this tractor, and witco's post seems to confirm.
P B G is offline
post #7 of 15 Old 01-21-2010, 12:06 PM
10,000 +posts!
I did the same as witco, ballast IN the tire. I have to get near other items with my tractor some times. I don't need wheel weights sticking out. Ballast in the rears works great...
Team_Green is offline
post #8 of 15 Old 01-21-2010, 02:50 PM
Dealer price was for 110lbs. each side. Tractor seems to ride smoother. Have not done any heavy lifting or pulling yet, just a new upright freezer of the truck bed last night. Kicking around the idea of adding ww fluid to the fronts. Will do this my self. Did it to my 180LT. and made out fine. Really seams to help with mowing on hills. And plowing snow with aid of chains. But 3320 got the snow jobs as we had 12" to 20" on the "shore" on the 19th and 20th Dec. 09. Will keep you posted.
witco is offline
post #9 of 15 Old 02-01-2010, 02:21 PM
Followup: Pushed snow with the 3320/FEL and 7' rearblade on 2/1/10. Snow very light and dry though we had 7" at my place. Tractor responded well with the fliud in the rear tires. But no noticiable difference in traction yet. Snow very slick. I will keep updates coming. Thanks.
witco is offline
post #10 of 15 Old 02-25-2010, 01:25 PM Thread Starter
Thanks for all the info...I opted to build my own ballast box. I think this will work out much better for me. I will be able to remove the extra weight in a snap when doing some mowing without sinking in the ground. What I learned from everyone's posts is that every idea is good, you just have to select or customize the one that works best for YOUR situation. Thanks...maybe I'll post some pics later.
jnh92 is offline
post #11 of 15 Old 02-25-2010, 01:28 PM
Sign up Today!!!
Mayor's Avatar
Images: 34
The little JD weights are 42lbs.
JD 2305, 200CX, MMM, iMATCH, Weight Box, 826D Snowblower, Frontier Box Blade, Markham Welding Toothbar, Star Sprayer 3 point, Herd M96 Spreader 3 point, Trac Vac 3 point.
Projects: 12 Volt Sprayer, Weight Box, Toolbox
Mayor is offline
post #12 of 15 Old 02-25-2010, 02:58 PM
WALTMART
Waltmart's Avatar
Images: 11
16oz to the pound:
Waltmart is offline
post #13 of 15 Old 02-25-2010, 03:42 PM
10,000 +posts!
To add to Mayors post the large plates are 100 lbs.. not sure of the medium size ones.
post #14 of 15 Old 01-02-2011, 07:53 PM
David S VG's Avatar
I made the tooling for these and had them cast at a local foundry. 275 pounds a side.
Name:	wheel weights 001.jpg
ID:	137091   Click image for larger version
Name:	wheel weights 002.jpg
Retirement is easy but yuh really have to work at it.
David S VG is offline
post #15 of 15 Old 01-02-2011, 08:25 PM
CedarView's Avatar
Originally Posted by David S VG View Post
275 pounds a side.
Holy Crappers! That should do the trick.
CedarView is offline
