What is a good small tractor and tiller combo for large scale gardening? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 23 Old 08-01-2005, 02:18 PM Thread Starter
I want a new, small tractor to run a tiller and other small implements for big scale gardening. I'm not mechanical, and although I've used big tractors, I want one that I can service and switch out implements without any help. My husband's got a Ford TN65 with a plow that can break up my gardening areas, but it is just too big to turn around in the tight spots I use. For an example, one garden is 80x40. I would like to have a compact, or subcompact size that has a narrower footprint than his does (6ft) and that can turn much tighter. My husband suggested 4WD to get more power out of a little tractor. I would like to run a front end loader on it, and it would be great if someone made miniature plows and seed drills and such. I work in heavy clay soil and it would need preworking to run a tiller. I want to steer away from getting something that was primarily designed to mow.
Besides the tractor I need some advice about the tiller. Do I get one the same width as my tractor, or will an offset help with that issue? I want to use it to prepare a seed bed, to cultivate weeds, to work in manure and compost. Which tillers work well, and what kind of features do I need to look for?
twest is offline
post #2 of 23 Old 08-01-2005, 02:28 PM
chrpmaster's Avatar
Re: What is a good small tractor and tiller combo for large scale gardening?
don't know what your budget is but you could look at one of our members (ropari) recent posts of a Case 446 with attachments for sale. those are very tough tractors as others can attest to yet small enough to fit most areas.
Just my .02
Andy
Stupidity is exasperating. Willful ignorance is bulletproof.
I totally take back all those times I didn't want to nap when I was
younger
I think part of a best friend's job should be to immediately clear your
computer history when you die
chrpmaster is offline
post #3 of 23 Old 08-01-2005, 02:44 PM
Citizen of Earth
bontai Joe's Avatar
If you definitely want new and can afford them, The Simplicity Legacy is a very nice choice (Also available as the Massey Ferguson 2927) can be fitted up with 4WD, a loader, and 3 point hitch. Also the Cub Cadet 5000 series and 6000 series tractors available in several different configurations, and engine options for a little less money.
If it's FREE, it's for ME!
bontai Joe is offline
post #4 of 23 Old 08-01-2005, 03:19 PM
Citizen of Earth
bontai Joe's Avatar
I want to also recommend looking at Kubota. They make a fine machine at a reasonable price.
post #5 of 23 Old 08-03-2005, 05:53 AM
ex spelling bee champ
Ingersoll444's Avatar
Images: 14
Sounds like you would realy want a sub compact. Check out the Kubota BX tractors, the Massey ferg GC tractors, and JD has one in that size also. They are about the size of a big garden tractor, but are built like a full size tractor with all the feachers. Not cheep, but sounds like the best size for you.
BTW Welcome to MTF!!!! Hope you like your stay here!!!!!
Paul B
SUPER Of The Month 10/2011
Ingersoll444 is online now
post #6 of 23 Old 08-03-2005, 08:33 AM
thesmartfarmer's Avatar
Depending on what budget you are on would be the main deciding and if you want new or used? Also I would go with a sub-compact and the tiller should either be off-set or just a little wider than your tractor (covers up your tire tracks)
thesmartfarmer is offline
post #7 of 23 Old 08-03-2005, 10:48 AM
guest
Guest
Posts: n/a
First off Twest! I used my 4410 in our garden which was about the size of yours until we recently moved. It does a good job but is overkill for that size garden. I use it in other areas as well.
For the garden and tasks you mentioned, budget NOT an issue; I would suggest a John Deere 4115 with a 410 FEL & HD bucket (you may want to consider a 4 in 1 bucket). A VERY compact machine with a 24 hp diesel engine to provide more than enough power for any task. http://www.deere.com/en_US/ProductCatalog/GC/servlet/com.deere.u90785.cce.productcatalog.view.servlets. ProdCatProduct?pNbr=128DLV&tM=GC&cNbr=GC_CUT&sCNam e=4000+TEN+Series+Compact+Utility+Tractors and iMatch kit, with a Land Pride RTR 1550 or RTR1558 pto tiller. http://www.landpride.com/lpdiv/produ...rod_rtr15.html I have the RTR 1558. VERY solid and great performing tiller. The iMatch kit mounts onto the 3 pt. hitch and makes changing out implements very easy. The Land Pride tiller has an adjusable offset which I like. I have mine offset to the right about 12 inches beyond the rear tire width. This makes it a lot easier to get in close to my string bean fence.
Your mention of the seed drill kinda throws a wrench in my suggestion above as I am thinking that depending upon the size of the drill, even a 4410 may be on the small side. Perhaps you could expand a bit on this area to give us a bit more info.
You can save money going with the 4010 or 4110, or even 790.
My suggestion IF budget IS a big consideration would be a Kioti CK25 HST or CK 30 HST http://www.kiotitractor.com/products...rs/ck25HST.asp http://www.kiotitractor.com/products...rs/ck30HST.asp . The Kioti tractors are VERY solid and reliable machines at a very good price. Take a look at the various models and see which meets your needs.
A MUCH less expensive but solid tiller I would suggest is the King Kutter pto tiller. They can be purchased at Tractor Supply Center http://www.mytscstore.com/detail.asp...productID=1756 . Also our sponsor Carter and Carter Machinery http://www.ccmachinery.com/sells some very nice tillers at VERY competitive prices as well. As does our sponsor Smart Farmer http://www.thesmartfarmer.com/ViewPr...odelNumber=L85 One of our other sponsors Pat's Easy Change System http://www.greenwellmfg.com/ makes a real handy quick change 3 pt. hitch adaptor. Be sure to give them a look!
Sorry about the long post. Just wanted to offer you both ends of the spectrum and a few ideas in between. Please feel free to come back with more questions and ideas.
post #8 of 23 Old 08-03-2005, 11:05 AM
Hey Cheif dont forget us also!! We have Tiller they are just not listed on our site. We carry the Maschio, Curtis, and Muratori brands.
post #9 of 23 Old 08-03-2005, 11:23 AM
guest
Guest
Posts: n/a
Thumbs up Re: What is a good small tractor and tiller combo for large scale gardening?
Sorry about that! My mistake! I didn't realize you were carrying those now. Omission has been corrected with my apologies and promise to exercise better eye sight in the future.
post #10 of 23 Old 08-03-2005, 07:00 PM
Guru on the Mountain
jdkubotamurray's Avatar
Check out the JD790, 2210 and 4000 series.
jdkubotamurray is offline
post #11 of 23 Old 08-03-2005, 07:55 PM
Archdean's Avatar
Should come as no surprise to no one that I would recommend a B Series Kubota to you , specifically a B 7510 ,,, It's what I use and find it perfect for the application .
Please avail yourself to the following link you will not be dissapointed!!
http://www.kubota.com/f/products/b7410.cfm
Will be happy to answer any and all questions that you may have!!
Archdean is offline
post #12 of 23 Old 08-03-2005, 11:52 PM
The B's are a nice little tractor, but once you've had a Kubota L it's hard to go back.....;+} I did like the bx while I had it also.
post #13 of 23 Old 08-03-2005, 11:59 PM
Archdean's Avatar
I agree JDKM but when you reread the question she first posted the 'B series' seems to be the ticket for this lady!!
Archdean is offline
post #14 of 23 Old 08-04-2005, 09:58 PM
Snow Plow Junkie
itsgottobegreen's Avatar
For clay soil. There is only one tiller you want. The kubota reverse tine tiller. The B7510 or B7610 with a 48" model. Would be perfict. I have run my buddy's 5' kubota reverse tiller on his 4310 in maryland's claycrete. It busted right through the hard rocky clay. My 48" forward tine tiller (95% of 3pt tiller are this way) just walks up on top of the hard soil. They just don't work well as a reverse tine tiller.
Kubota tractors and tillers are the best.
Snow Plow Junkie
Kubota B7500 cab w/heat, loader, plow, blower, MMM, tiller, box, rear blade, brushhog, power broom, aerator
Walker 48" GHS 26efi
3-JD 110 (1964,65)
1-JD 112 (1972) Forsale $300
1-JD 214 (1986)
36/37a blower, 31 tiller, 42/43 blade, RF Cab, 7 mower decks
itsgottobegreen is offline
post #15 of 23 Old 10-28-2005, 09:54 PM
lb59's Avatar
Originally Posted by twest
Do I get one the same width as my tractor, or will an offset help with that need to look for?
I prefer one that covers both wheel tracks.
That way you can work right to left or left to right.
You can also make passes in either direction without leaving wheel tracks.
lb59 is offline
