windshield washer fluid for filled tires - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 01-22-2011, 09:32 PM Thread Starter
Does windshield washer fluid cause rusting or ruin the rim or tire when use to fill tires?
2007 John Deere 2305, 54" mmm, 200cx FEL
jerseymark is offline
post #2 of 18 Old 01-23-2011, 12:19 AM
Member of the 0.4k Club!!
Luv2Q's Avatar
Images: 3
Re: windshield washer fluid for filled tires
No personal experience here using WWF but doing a "Google Custom Search" of MTF seems to indicate .. not much. Some folks thought it inhibited rust, others thought it didn't. The consensus seems to be that Rimguard (derivative of beet juice which is non-corrosive and is also heavier than water) is best followed by RV antifreeze (propylene glycol rather than the toxic ethylene glycol used in automotive antifreeze).
I'll be adding fluid to my tires one of these days and will likely use the RV A/F. Nearest place I can get Rimguard is in the Dallas area, about 150 mi away.
Regards, John
2010 Kubota B2320HSD w/ FEL, 54" MMM, 4' boxblade, 4' LP shredder, 5' LP rake, 6' blade
1958 Ford 601 Workmaster - Gone but not forgotten
1947 Ford 8N - Ditto
Troy-Bilt Model 13025 + 25 gal towed sprayer
Carolina Skiff J16 w/ Suzi 25
Luv2Q is offline
post #3 of 18 Old 01-23-2011, 06:07 AM
15,000+ Posts & Climbing
Even air will rust the inside of a rim, if the paint job is substandard.
The most caustic fluid for tire loading is calcium. I can attest to the rusting out of rims in 12 - 14 years using this medium, ...... twice, ........ on the same tractor. Even straight water won't match that destruction. Don't worry about it.
TUDOR is offline
post #4 of 18 Old 01-23-2011, 08:02 PM
Plow Day Man!
PA PLOW DAY's Avatar
i've used windshield washer fluid, no problems, my good friend had his newest tractor filled with that rimguard stuff that was mentioned and the dealer swears by it.
Bryan Seward, Co-Founder of the PA Plow Day and Garden Tractor Show.
PA PLOW DAY is offline
post #5 of 18 Old 01-23-2011, 11:48 PM
The most common tire fluid around my area is the chloride solution and there are also a lot of rusted-out rims as well. When I bought a new tractor several years ago I wanted to stay away from the salt so I asked what could be used as an alternative. They acted like there wasn't anything they could really think of.
I asked if RV antifreeze could be used. They guessed it could be but they weren't too thrilled about it. Still, I got some and had it installed. That was about 8 years ago and I have not had any problems at all. I would highly recommend it. I have heard some good things about RimGuard but it seems to be hard to come by in my area of Illinois.
George
Wedgie is offline
post #6 of 18 Old 01-24-2011, 01:16 PM
Old as Sin
silver hair deere's Avatar
Heres a question , the only thing holding air in my tires is plugs and slime , is filling them out ? or do i need tubes .
Silver Hair Deere
2014Craftsman YTS 4500
1989 Sears lawn tractor (5 bolt)
1996 MTD 696 needs front fixed
1998 Murry needs engine 12.5 B*S
1989 GMC 1500
1998 FORD RANGER
When one breaks down , i just drive or
mow with another
A PROUD MEMBER FOR 10 YEARS !!!!
silver hair deere is offline
post #7 of 18 Old 01-24-2011, 11:02 PM
Deere 330 Killer
Hugh-SS/16's Avatar
Images: 15
I put new tires on my SS/16 and loaded them with out tubes cause the rims and tires are mint.
You can load tubes, but you get less weight and it takes longer.
WWF is non corrosive, and usually will say so on the label
GT_80 Fan Club Member: #0001
1967 Suburban 10
1969 Hydro-Trac 12
1970 Hydro-Trac 12
1973 SS/16
Hugh-SS/16 is offline
post #8 of 18 Old 01-25-2011, 12:02 PM
wally2q's Avatar
The next best thing is sugar. Highly soluble in water (especially when the water is warmed up), and then causes the water solution to be heavier... like rimguard.... and totally not-corrosive.... AND totally not toxic.... but it may attract ants (and kids) if spilled out of your tire.
you can dissolve just over 200g of sugar in 100ml (100g) of water at 20 deg C.
Doing that, you can make sugar-water pretty thick... like syrup... and it's heavy as heck...
wally2q is offline
post #9 of 18 Old 01-29-2011, 09:15 AM
JD RULES
x595's Avatar
Images: 3
wally2q , the Sugar Solution you speak of might be Heavy , but I would think it will Freeze without an additive added ...
Later,x595
2005 JD X595 w/ HDAP Tires
54c MMM --- (SOLD)
62c MMM
54" Quick Hitch Front Blade
4x8 Utility Trailer - 1500# Axle
North Star 15,000 Watt Generator
Troy - Bilt Super Bronco Rear Tine Tiller
Troy - Bilt 2500 PSI Pressure Washer
22" Yard Machine Push Mower
SpeeCo SplitMaster 28 Ton - Horizontal/Vertical Log Splitter
STIHL 025 - 18" Bar --- (SOLD)
STIHL 025 - (Spare Parts Saw) --- (SOLD)
STIHL MS 290 FARM BOSS - 20" Bar
STIHL FS 45 Trimmer
x595 is offline
post #10 of 18 Old 01-29-2011, 03:11 PM
Just passing through
Upper5Percent's Avatar
Later,x595
Sugar will also precipitate out of solution...leaving just water to freeze if the temperature is low enough...
Take a glass of water, add sugar stir, then come back in a couple of hours...then put that glass in the freezer for night...
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #11 of 18 Old 01-31-2011, 10:27 AM
wally2q's Avatar
Yes - it may precipitate - hence the right (maximum) mixture is required.... also adding alcohol will lower the freezing point.... in other words - put sugar into plumbing antifreeze.
Separately, sugar/water solution has a lower freezing point than pure water in the first place (chemistry)....
wally2q is offline
post #12 of 18 Old 01-31-2011, 11:16 AM
Cranky Motorsports
GT_80's Avatar
Images: 32
WWS is the cheapest easiest solution to use. And, I have said this before, and stand by it, it may be toxic wheras RV antifreeze is not, however, antifreeze does not evaporate- if you spill wws, it evaporates because it is alcohol. And it gets all over the ground every time you wash your windows on your car anyway. My local supermarket sells it for $1.50 a gallon- if you can find me something that is THAT cheap, and environmentally friendly, I will use it. Otherwise, WWS all the way!
MTF Addict #35886
Hugh-SS/16 fan #0001
1966 Suburban 12 parts build - for sale soon
1967 Suburban 12 "The 679"-Yanmar L70 Diesel
1967 Suburban 10 Super 12 Special clone
1967 Super 12 "Christine"
1968 Super12 "Miss Emma Lee" Launtop 178F Diesel
1968 Super 12 "C&B Special"
1970 Suburban 12 Trike Build
1970 Suburban 12 2
1973 SS16 / Roper Diesel "D10S"
1974 SS16 rescued
1976 SS18 "Trusty"
1978 GT18 with Hard cab
My YouTube
My Ebay
Sears Manuals
GT_80 is offline
post #13 of 18 Old 02-01-2011, 03:00 AM
I dunno, I tend to buy weight for loading my tractor tires, not volume. I loaded my tires with as much weight as others with WWF or RV antifreeze PLUS 50 lb. wheel weights. The calcium in each of my 26x12-12 weighed 160 lb. RimGuard is almost as heavy.
Loaded tire plus 40 lb. MF split wheel weights plus 15 lb. 2 link chains equals 253 lb. per tire, or 506 lb that the axle doesn't see.
Years ago, the 23x8.5-12 tires on my MF12 carried 65 lb. of calcium each, and the 16x8.5-8's on my Gilson carried 25 lb. each.
I have no idea how much volume, only the weight matters for traction.
TUDOR is offline
post #14 of 18 Old 02-01-2011, 08:18 PM
walterboatwright's Avatar
Images: 5
Any liquid weight is great. But if you puncture a tire it will most likely ruin it.Liquid is great but the fabric content in most round rubber cant contain the stress with a small hole.Myself I would stay away from the calcium chloride . The same stuff used to melt ice and make pickles. Try an alcohol baised additive.or maybe a vegtable oil weight .its heavier than water and its bio-degradable.
walterboatwright is offline
post #15 of 18 Old 02-02-2011, 01:56 AM
Absolutely correct! Unfortunately, RimGuard is a fairly recent product and was not available to me when I loaded my tires 15 years ago. The rims are now totally corroded from the calcium, for the second time in 29 years. That's why I recommend the beet juice.
My new rims will be loaded with the Canadian equivalent of RimGuard, which is also biodegradable and much heavier than the antifreezes. Vegetable oil tends to congeal into a solid lump at subfreezing temps making for a very rough ride, and like the antifreezes, is also lighter than straight water. Ask your wife as she's doing dishes.
Punctures are a normal fact of life with any pneumatic tire equipped vehicle, especially if you take it off road. I've had more punctures in my truck tires than my tractor tires in the last 35 years, and the trucks stayed on the road.
TUDOR is offline
