i have a fordson dexta (live pto) the lever to go from position control to draft control seems to be having a problem when i am in position control it will act like it is in draft control which i know it's not and the lift links will only work at the very top of the lever Guide. when i push on the lever like i am going to go into draft control it will not go all the way down and then the arms start acting normal and the arms work on the full guide from top to bottom like they are suppose to but you have to push down on the position/draft lever with some force for the lift to move correctly it's like its backwards or something and you are not able to flip the lever to draft control what is going on?
