Where to start on a tractor thar has been sitting 8 years - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 01-27-2007, 04:30 PM Thread Starter
shawn01754's Avatar
Images: 3
Now that I have got this tractor home its time to figure out what next. Its been sitting for 8 years. Iam guess the carb will need a rebuild (Gas). Iam not sure what to do with the gas tank. Ive been told the flywheel has a bad spot on it.My guess is I should get it running to make sure its worth the split.What else should I look at?
shawn01754 is offline
post #2 of 18 Old 01-27-2007, 04:34 PM
ex spelling bee champ
Ingersoll444's Avatar
Images: 14
Re: Where to start on a tractor thar has been sitting 8 years
Well always a good idea to pull the plugs, get some oil in there and let it soak a little. Drain the oil out, and put some fresh oil in there. After the oil has soaked a bit try turning the motor over. Keep the plugs out BTW. Drain all the gas, clean the carb and put some fresh gas in. As long as it turned over with the plugs out, I would reinstall some, and she what happands.
Paul B
SUPER Of The Month 10/2011
Ingersoll444 is offline
post #3 of 18 Old 01-27-2007, 04:36 PM Thread Starter
shawn01754's Avatar
Images: 3
Thats sounds like a good start, What type of oil, motor, or something like mystery oil?
post #4 of 18 Old 01-27-2007, 06:42 PM
Collector of many tractors
Kbeitz's Avatar
Why not just put a good used engine on it ???
Kbeitz is online now
post #5 of 18 Old 01-27-2007, 07:42 PM Thread Starter
shawn01754's Avatar
Images: 3
That an idea we could consider, thanks
post #6 of 18 Old 01-27-2007, 08:06 PM
Images: 3
What kind of tractor are you working on?
Cub Cadet: Plowin' the competition under since 1961
Wild Bill 83 is offline
post #7 of 18 Old 01-27-2007, 09:45 PM Thread Starter
shawn01754's Avatar
Images: 3
Iam working on a Minneapolis Moline big mo 500. Its a backhoe/loader, so theres a lot of stuff to check I guess.
Name:	big mo 12.jpg
post #8 of 18 Old 01-27-2007, 10:58 PM
Images: 3
Thanks, that makes it easier to understand what you are dealing with
Like Paul said, pull the spark plugs and get some penetrating oil in there. Start the plugs back in and let it sit for a while. While it is soaking, clean all the electrical contacts needed for your ignition circuit. Rebuild your carb. Clean out the sediment bowl (if it has one) Make sure you can get the transmission into Neutral. After 3 or 4 days, see if you can get the engine to turn by putting a socket with a breaker bar on the crankshaft pulley. If it will turn, pull the spark plugs back out, and put some Marvel Mystery Oil in the cylinders. Crank it over with the socket again to coat the cylinder walls. Put a good tune up on the tractor, and change the oil. Make sure there is water/antifreeze in the cooling system. Install a good battery, and see what happens
post #9 of 18 Old 01-28-2007, 04:50 AM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
Check the hyrdrolic fluids to see what they look like...Milky white means that they are water contaminated..
R.I.P Durwood
Ken N Tx is offline
post #10 of 18 Old 01-28-2007, 08:06 AM
bear's Avatar
its good idea to pull the tappet cover and see if the valves are free it seems every time i think they'll be ok or get in a huury and skip that step i'm straightening pushrods or looking for different rocker arms
bear is offline
post #11 of 18 Old 01-28-2007, 08:29 AM
Camaniac
look up seafoam, kroil and pb blaster, all good products for your application here.
1956 Cub Lo-Boy
JD LA175
JD LT133
JD RX73
Sears 16/6
If you can't fix it with a hammer, it must be an electrical problem!
freebird is offline
post #12 of 18 Old 01-28-2007, 08:46 AM
dyt4000's Avatar
Images: 12
All of the above...it looks like a fun project!!
1957 IH Cub Lo-Boy
1959 Ford 631 Workmaster
1967 Wheel Horse 857
2001 John Deere 425 3 point lift, rear PTO and Heavy Hitch with trash can option
dyt4000 is offline
post #13 of 18 Old 01-28-2007, 09:02 AM
Mrwiggles2's Avatar
Images: 9
Thanks to Jim Rome for turning me on to PB Blaster. While I doubt his hands have ever laid on a can, his ads are right. It loosens stuff and does a good job. For years I was using WD40 and for light apps its ok, but pb is the stuff for all tough jobs.
Craig
Buffalo, NY
You Tube Channel Link Below. Videos on my tractors, how-to and just good stuff!
http://www.youtube.com/user/mrwiggles2?feature=mhee
1989 Wheel Horse 416-8 16hp Onan
1989 Wheel Horse 520-H 20hp Onan
Mrwiggles2 is offline
post #14 of 18 Old 01-28-2007, 09:32 AM
Kbeitz's Avatar
What fer engine is in that critter ????
post #15 of 18 Old 01-28-2007, 12:52 PM
*** IT ISN'T GREEN
Iron horse's Avatar
well your on the right track with starting on the internals first, no good making it look good when the engines shot.
It ain't got enough horse power till your ridin a wheely across the field
Iron horse is offline
