Finally built my mid mount grader blade - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 02-04-2012, 03:48 AM Thread Starter
TractorBob's Avatar
I read swdias thread and asked some questions and finally made my blade happen! It's not finished yet but this was the fitting and it fits perfect! I couldn't resist and had to go try it down in the town yard sand pile just down the road from me and it works AWESOME!! for the tips and help swdias and poncho62.
I took an old 48" craftsman dozer blade cut it down to height, turned the push bar around to be the drawbar and pivot. I welded a piece of channel to the front of the drawbar with side tabs to bolt it to the frame for the lift pivot point(seen in pics above). I used a piece of chain I had laying around to hang the blade with. I got the chain length right the first shot. I may also fab up some bars on each end of the blade to put weights on for some down pressure and to help dig hard packed dirt and soil.
My attachment for the blade is still in the process of laying out but heres a pic to get an idea. I am going to weld all the U shaped pieces on as teeth to scarify the ground. The points of the teeth will be about 3/4" below the blade to give some digging depth in tough, rocky NH dirt. I am going to weld 4 tabs to the top of the scarifier to through bolt it to the main grader blade. I want it to be easily removed when its not needed for finish work.
Now I need to take it back off and finish grinding down the messy welds trim the lifting chain to the right size and make a handle for the lock that holds the blade from pivoting. Then most importantly make it blue!!
Next I'm thinking a 3 pt hitch. But we'll see if I'm able to do that. If I do do that, then I may have to talk to skyrydr2.
65 Sears Suburban 8 HP w/ 10 HP repower (The Old Tractor)
72 Ford LGT125 (The Hydro) with Johnson FEL
74 Ford LGT100 (The Ford) with 48" Dozer, 48" Mid grader, 50" Mower and a 42" snow thrower for attachments
And I drive a 00 VW beetle TDI as daily, 94 f250 4x4, 86 F350 4x4 currently a project
"There is a sickness worse than alcohol and dope, it is the tractor debt, and there is no cure in sight."
TractorBob is offline
post #2 of 5 Old 02-04-2012, 07:34 AM
skyrydr2's Avatar
Re: Finally built my mid mount grader blade
Awsome job Bob! 3 point hitch is easy as long as you have a hydro trans to attach to the axle
Keith
'82 Ford LGT 165(Kubota diesel conversion)
'72 Ford LGT 125 (loaded, 3 point hitch, and rear pto, and hydraulic lift )
'58 Ford 1841 Industrial(for the big jobs)
skyrydr2 is offline
post #3 of 5 Old 02-04-2012, 08:37 AM
poncho62's Avatar
Images: 7
Looks good...I need to stiffen up the blade on mine a little
Ford LGT100
Ford LGT125
Ford LGT145(sold)
Ford LGT165
John Deere STX38
Ontario Rodders
poncho62 is online now
post #4 of 5 Old 02-04-2012, 11:53 AM Thread Starter
TractorBob's Avatar
Poncho, It was easier to make than I thought. I had to use my neighbors torch and was going cut the db down the center to build it the way you and swdias did with the separate triangular drawbar but he convinced me to leave the drawbar solid for strength reasons so I did. It is very solid and has no flex to it what so ever.
Sky, Your hitch build pops up every time I do a search for ideas. I have been looking at different ideas on the 3 pts and haven't really found one on a lgt 100 other than a sleeve hitch. I have a 4 spd trans and it is quite different from your hydro tractors. Here's a pic of my rear. What part of MA are you in? I'm originally from 20mins south of boston.
post #5 of 5 Old 02-04-2012, 09:02 PM
skyrydr2's Avatar
North central Ma. Right off rt2 litterally .
As far as all the brackets, they are universal and should work on your rig as well. Not sure about the lower arms though ? I have to finish my LGT125 soon, as spring is coming and I would like it finished and painted . All that is left is the pto shaft setup.
Keith
skyrydr2 is offline
