Hydraulic Fluid/Transmissoin/Front End Loader - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 02-25-2011, 08:08 PM Thread Starter
GreenGuy23's Avatar
It's getting close to summer time and I am preparing my equipment for mowing and garden chores that are just around the corner.
Winter here has been pretty bad and warm weather is definitely welcome.
I have a Yanmar YM2000 and I want to change out my hydraulic fluid. I plan to drain it and my manual says it requires 16qts. I am going to assume that 16qts without a front end loader.
My question(s) are: Should I add more to compensate for the front end loader? I know that all of the fluid is not going to drain out but would it be OK to add a little extra?
I believe it requires JD 303 spec type fluid?
I know it is a little low on fluid, when the 3pt hitch is raised the front end loader is slow and not very responsive, however when the 3pth hitch is lowered (when I am mowing) the loader works like a charm.
I am just ready to get mowing. I don't get to use the tractor much in the winter. My thought is that if it is too cold for my tractor, it's too cold for me.
GreenGuy23 is offline
post #2 of 18 Old 02-25-2011, 09:23 PM
winston's Avatar
Re: Hydraulic Fluid/Transmission/Front End Loader
You are not going to be draining all the fluid out of the loader cylinders and hoses but I wouldn't worry about what is left in them. Just retract the cylinders when doing the change. When the cylinder rods are fully extended you will be at your lowest fluid level in your transmission reservoir. I usually check my level at that point and again when cylinders are fully retracted. Your level will be a little higher in that position. I try to have my level a little high when in the retracted position and a tad low when in the extended position. A tad high or a tad low is going to be OK. Hope this makes sense to you. You are correct on the hydraulic/transmission fluid type.
winston is offline
post #3 of 18 Old 02-25-2011, 10:18 PM Thread Starter
GreenGuy23's Avatar
Re: Hydraulic Fluid/Transmissoin/Front End Loader
Winston thanks for the help. I will do that when I drain it out. I checked it yesterday and it was full, but it was kinda milky. I figured that I would drain it and fill with new, and then later in the summer do it again to flush some of it out.
The manual says 16qts but who knows. I have had some trouble with the fluid capacities and this guide, they don't always match.
A bit off topic, but, I have changed the oil in this tractor, and the same guide says 5 qts. Skeptic I put 4qts in and the dipstick reads full. Anyone who has a YM2000, how many qts of oil do you use in your oil change?
The previous owner didn't really take care of this tractor much and I am trying to clean up the mess.
post #4 of 18 Old 02-26-2011, 02:55 PM
I use 4 qts. in my engine and a 5 gallon bucket for the trans/hyd. I just had to put new seals in the loader valve and the old man at the industrial supply told me to switch to synthetic 0 or 5 weight fluid and to put a filter on the pump supply line. Mine is a 240d with loader.
I also noticed that weight on the 3pt will slow down the loader a bit. Seems logical.
caleb is offline
post #5 of 18 Old 02-26-2011, 02:59 PM
Retired MTF Admin
mark777's Avatar
Holy Cow, caleb...
New one on me. It isn't too light is it? I'm guessing five gallons of synthetic most come pretty dear price wise as well...
mark777 is offline
post #6 of 18 Old 02-26-2011, 08:27 PM
I can't find a large amount of syn. hydraulic fluid anywhere local. I did find a filter and some compression fittings for the metal supply pipe. Supply pipe is 7/8" if anyone else does this. I am going back for fluid tomorrow but here is a look at it. 3/4" NPT filter has a flow raring of 9 gpm when use on supply side. I grabbed the 10 micron filter but they had a 25 micron for same price. Cost me $16 for the filter base, $5 for the filter and 2x compression fittings $6 each. Call it a $35 project. Took an hour maybe.
I pulled the original filter screen in the tranny so I don't have to go there again.
ID:	145490   Click image for larger version
caleb is offline
post #7 of 18 Old 02-26-2011, 10:28 PM
winston's Avatar
I'm certainly no lubricant guru so take this with a grain of salt. I think the old man with the synthetic oil advise is wrong. To many folks using recommended fluid or ATF with good results. Just my opinion.
winston is offline
post #8 of 18 Old 02-27-2011, 05:39 AM
Retired MTF Admin
mark777's Avatar
Winston...
My concerns are the lite viscosity fluid not transferring heat effectively. Especially with a 10 or 20 model that utilizes the Power-Shift transmission pumps.
mark777 is offline
post #9 of 18 Old 02-27-2011, 06:27 PM Thread Starter
GreenGuy23's Avatar
Thanks for the input everyone!
I ended up completing this task yesterday. I am ready for mowing.
Here are the specs for the hydro/trans fluid I used:
http://www.oreillylubetech.com/PDS/303%20Tractor.pdf
I think I overfilled it a bit too much so I will have to drain some later.
I didn't notice any metal flakes so that is a good sign I would imagine.
I do notice a "grind" sound sometimes when I put it in gear. It usually happens when the loader and the 3pt hitch is lifted. Anyone else have this happen? It usually lasts less than a second.
Sorry for all of the questions. I am very new to doing my own mechanic work. This is my first CUT.
post #10 of 18 Old 02-27-2011, 06:45 PM
winston's Avatar
Looks like a good choice of lubricant to me. As far as the grind I am not exactly sure what you are experiencing. I'm thinking like the clutch is not completely releasing and as you move the shift lever it grinds a little. I don't understand the connection with the grind and the lift or loader being up. Maybe you could elaborate a little more?
winston is offline
post #11 of 18 Old 02-27-2011, 06:57 PM Thread Starter
GreenGuy23's Avatar
It normally happens when I am starting from a stop. After I depress the clutch I move into the desired gear and it makes a "grind" before it clicks into gear.
I don't always happen and it's not just one gear.
If I am stopped and I shift into gear it may grind (usually less than a second) but if I keep the clutch down I can move to another gear and it won't make a sound
I am sorry if this doesn't make sens. My laptop is broken and I am typing on my phone.
post #12 of 18 Old 02-27-2011, 07:45 PM
I Love All Color Tractors
DJ in WV's Avatar
Images: 6
Is your transmission fully synchronized? If not, the grind that you're hearing are the gears meshing until engaged. The reason that moving to another gear and no grind would be that the gears are not spinning and don't have to be meshed while still spinning.
My YouTube Page
The Shops of Oak Point Farm
My Equipment:
1961 Gravely LI Postal
1967 Gravely 430
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1973 Gravely Model C8
Many other Gravely C's, L's, and LI's
1982 Gravely 8123
1983 Troy Bilt Junior
1988 Gravely Pro 12
DJ in WV is offline
post #13 of 18 Old 02-27-2011, 07:50 PM
winston's Avatar
Yes, that makes good sense. I had a little Farmall Cub and could never get it where it wouldn't do that. In your case though, if you haven't already, check your clutch pedal freeplay. You should have 9/16" to 1" freeplay at the top of your movement. I would shoot for the 9/16". Less freeplay, the more you are mashing your clutch fingers to release. For some reason you are picking up a little drag and the clutch shaft #12 is continuing to rotate a little until you stop it with the gear mesh. These old Yanmar transmissions are all straight spur gears and no syncromesh to them. http://www.hoyetractor.com/mm5/merch...de=2000CLUTCHB
winston is offline
post #14 of 18 Old 02-27-2011, 07:59 PM
Retired MTF Admin
mark777's Avatar
Originally Posted by DJ in WV View Post
Is your transmission fully synchronized? If not, the grind that you're hearing are the gears meshing until engaged. ......
None of the YM series tractors have synchronized transmissions (excluding Power-Shift models).
mark777 is offline
post #15 of 18 Old 02-27-2011, 08:06 PM
DJ in WV's Avatar
Images: 6
Thanks for the confirmation of the gear synchronizers fellas. I had a feeling, but didn't know. My JD950 is Yanmar built and doesn't have synchronizers either. I thought that I'd take a chance on being right.
My YouTube Page
My Equipment:
1967 Gravely 430
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1982 Gravely 8123
1988 Gravely Pro 12
DJ in WV is offline
