Hello Folks,
I was cutting the lawn for a school board using their own GTH24V54 Mower and I leaned over the the machine to pick up a branch lying on the ground. When I leaned over the drive was in reverse and my side hit the shifter.
When I was ready to go again, I was left with only reverse gear.
If you move the shifter from Reverse to neutral and forward there is little to no resistance on the shifter.
I'm hoping it's just a bent linkage or a pin came out.
Does anyone have any details on how to dis-assemble to look for broken or damaged parts?.
How easy is it to manually engaged the shifter along the side of the tranny?
Thanks in advance,
GCG...
Thanks in advance,
GCG...
