mtd single speed transaxle - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 07-04-2009, 11:37 AM Thread Starter
Hi,
I have a yardman rider with the 618-0387 single speed transaxle, does anyone know where I can get used parts for one of these? I need the bevel gear and the pinion gear. From the info I have researched usually the clutch collar would break. Of course MTD has no parts available unless you replace entire transaxle with the 918-0551A
herbertml is offline
post #2 of 12 Old 07-06-2009, 10:24 PM
Re: mtd single speed transaxle
I have a parts transaxle I'll sell the parts out of, gears all good.I have my manual if you get me part numbers i can check your part numbers vs mine. It should be the same insides. Single speed with the variable speed pulley mounted on the transaxle with the larger pulley right?
kcp877 is offline
post #3 of 12 Old 07-11-2009, 07:19 PM Thread Starter
I need the sprocket bevel gear 717-1422 and the 12 tooth bevel pinion 717-1571, my transaxle # is 618-0307
post #4 of 12 Old 07-12-2009, 11:24 AM
Ok I'll check the parts diagram. If you could post the model number of the whole tractor it would be easier to look up I could just load the manual
kcp877 is offline
post #5 of 12 Old 07-12-2009, 10:41 PM
Mine is a 14 tooth bevel pinion, not a match.
kcp877 is offline
post #6 of 12 Old 07-13-2009, 11:35 PM Thread Starter
model # is 13AX604G401, it shouldn't make a difference if I change both gears. At most it will give it a little different gear ratio.
post #7 of 12 Old 07-14-2009, 01:24 AM
johndeereowner's Avatar
try ebay.
John Deere Model B
John Deere Model 60
johndeereowner is offline
post #8 of 12 Old 07-14-2009, 07:10 AM
Outside it's the same, just looked, My trans is good, it just has a bad sheeve bushing and a bad top housing. You could take your top housing, buy new sheeve bearings for $5 and just put your top on my trans if you wanted. Just need to figure out a price and shipping. PM me directly with you email address and I'll send you the manual that mine came out of so you can see the parts breakdown. It was out of a 2002 I think.
kcp877 is offline
post #9 of 12 Old 07-14-2009, 07:13 AM
Is yours a 1999 or 2001? Partstree shows you with a 14 tooth bevel on the 2001, you should double check and count yours. It's going to be much cheaper to ship a pinion then an entire housing.
http://www.partstree.com/parts/?lc=m...dn=00825000027
kcp877 is offline
post #10 of 12 Old 04-27-2010, 12:48 AM
JamesGarfield's Avatar
Herbert,
Try M_And_D parts (M-AND-D.COM). If you have part numbers (and I see you do), you can darn near any part ever made for MTD. Fast delivery too.
JamesGarfield is offline
post #11 of 12 Old 05-18-2012, 08:51 PM
I have anew 12 tooth pinion gear and a ring gear. I got a ring gear in mine that has a sprocket on the back and 6 small holes not all the way thru on mine that I need which I believe is the 717-1422. The new one I have has 3 cogs on the back and 3 cogs on the front. Close to the same as mine but without the sprocket And partial holes. Bought this machine with bad rearend and those are the new parts the guy bought but no the same as mine.
chevy_nova2 is offline
post #12 of 12 Old 05-21-2012, 10:14 PM
If you still have the gears and want to sell them I would be more then willing to buy them. I mostly just need the ring gear and it has the sprocket on the backside where the chain goes down to the gears at the bottom. Also on the front side it has 6 half drilled holes for the forward and reverse. As long as theres a chain on it im sure its the right one. Call anytime at 218-838-5785 my name is Gary. Thanks
