Mtd 990???? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 08-23-2011, 04:07 AM Thread Starter
Mtd 990????
Hi, I have a Mtd 990, (I think) Its been painted and all badges and tags are missing, it has a 16 h.p. briggs and stratton 320427-0147-01-7101261
I believe its a 71 if I read the code right, but I dont know if thats the original motor.
My question is about the engine, the wiring is a mess....its not charging, can anyone tell me what wires from the stator to check, or how to check them, I'm hoping the stator will test O.K. because someone has cobbled together something that might be a diode of some sort dunno, definatly not o.e.m. regulator.
(It does have points) also can someone tell me the correct part number for the regulator.
Thanks
Dan
Dan123 is offline
post #2 of 8 Old 08-23-2011, 11:47 AM Thread Starter
Re: Mtd 990????
Well I believe I have identified that cobbled up part, I think it was a vacuum rectifier(without the glass, it was busted) LOL, someone got creative,
As near as I can tell I have an unregulated stator, so I believe the only thing I need is a rectifier/diode, correct?
Dan123 is offline
post #3 of 8 Old 08-23-2011, 07:20 PM
Re: Mtd 990????
I believe the original part number was 390240. Looks like a large aluminum heatsink and sits on the cowling above the starter.
Chagrin is offline
post #4 of 8 Old 08-23-2011, 07:31 PM
The Magnificent
D-Dogg's Avatar
Re: Mtd 990????
How about some pictures, Dan.
As far as I know, the 1971 990 had a 14 HP engine. Pretty much the same block as the 16, but different spec.
One of my 1972 990s has the 15HP Engine and the finned regulator on the starter.
D-Dogg is offline
post #5 of 8 Old 08-24-2011, 02:16 AM Thread Starter
Re: Mtd 990????
Thanks for the reply's, I will post pics as soon as I can
Dan123 is offline
post #6 of 8 Old 08-25-2011, 09:11 PM Thread Starter
Re: Mtd 990????
Well D-Dogg you are right about the horsepower rating, I was going off what the guy told me that had it before me. I got all the wiring from stator to where the regulator will go all squared away, and thank you CHARGIN for the part number of the regulator, ordered it today. Will post back when I get the rest of the wiring done and see if its gonna charge.
Dan123 is offline
post #7 of 8 Old 08-30-2011, 12:00 PM Thread Starter
Re: Mtd 990????
Well folks I got the regulator yesterday and installed it today, no go on charging.
I am getting 14 volts ac across the two ac terminals but very low dc voltage at the center terminal,(0 to 3 volts dc) and its polarity is reversed? Any input will greatly be appreciated.
Dan123 is offline
post #8 of 8 Old 08-30-2011, 02:45 PM Thread Starter
Re: Mtd 990????
OK, Got it figured out, My ammeter was bad, I hooked it up without and it works fine, 13 to 14.5 volts dc. I robbed the ammeter from my ford lgt and it looks like its putting out about 4 amps @ wide open throttle
The top pic is after I installed the new regulator, and the bottom pic is that thing someone had installed in place of a regulator???
Thanks again fella's, hopefully I will be able to return the favor and help someone out here.
Dan123 is offline
