Troy-Bilt LTX-1842 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 05-10-2009, 06:48 PM Thread Starter
Help Troy-Bilt LTX-1842
Hi all, very glad I found MTF! I am not very mechanically inclined, and I was wondering if someone on here would double check my diag on my Troy-bilt.
Occasionally while mowing with the PTO engaged the tractor will stop moving, like it jumped out of gear. If I max the pedal to make the tractor go forward the bottom engine pulley smokes one of the belts.
I put it in neutral and turn on the mower deck, no problems. Turn off the deck and try to go, smoke. So I am thinking it is the engine to trans belt.
I pull out the battery to get a look at the pulleys. The tensioner and the large pulley turn free, the variable speed pulley is kind of sluggish, and the center bolt looks slightly off center. A shot of penetrating oil and all is good, until next time. At 140.00 for the VSP assembly, I would like a second opinion before I order an expensive part and be wrong.
Thanks for reading,
Mr R
Mr R is offline
post #2 of 6 Old 05-10-2009, 11:04 PM
Superdave!
s2dve's Avatar
Re: Troy-Bilt LTX-1842
Make sure the idler pulley and spring is in good shape. I'm assuming it has one.
s2dve is offline
post #3 of 6 Old 05-10-2009, 11:45 PM Thread Starter
Yes sir, it does. It is free and the spring looks solid.
Thanks,
Mr R
Mr R is offline
post #4 of 6 Old 05-11-2009, 10:12 PM
Superdave!
s2dve's Avatar
I don't know your particular mower, but I have had similar problems in the past. A few times it was something as simple as the belt getting on the wrong side of a guide pin.
I think most mowers have 'em, they are supposed to keep the belt from coming off the pulley, but occasionally,(and don't ask me how) they 'jump' around the pin. It's the only other thing I can think of.
s2dve is offline
post #5 of 6 Old 05-12-2009, 12:28 AM Thread Starter
Thanks Superdave. I think I will take some time this week and inspect the pulley systems and belts carefully. Being an intermittent problem, I probably won't get very far until it happens again.
I appreciate your help
Mr R
Mr R is offline
post #6 of 6 Old 05-12-2009, 01:47 AM
Superdave!
s2dve's Avatar
I looked up your mower on PartsTree.com and there are actually three idlers and two belts on the drive line. There is a double idler on the lower drive belt and there is where I would start. Make sure they are keeping tension on the belt. Also I'm pretty sure the variable-speed pulley assembly has to rotate from front to back. If it hangs up, I'm sure that would smoke the belt. It could be that a stick or something is interfering with the many moving parts on this type of mower
Sorry if I'm not explaining this very well.
edit: I forgot the link.
http://www.partstree.com/parts/?lc=t...&dn=0015800004
s2dve is offline
