Lauson carb leaks like crazy! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 04-08-2010, 06:43 AM Thread Starter
I was given a Troy Bilt Horse (I think it was made in 1973). The Lauson carb leaks out of the carb air inlet. It drips about 1 time per second. The more fuel in the tank the faster it drips.
The float (copper) is fine with no fuel or water in it.
I just replaced the needle and rubber seat attached to the float. With the bowl off I could easily shut off the fuel using the float.
The thing continues to drip.
Any ideas how to fix this problem?
PDA1 is offline
post #2 of 3 Old 04-08-2010, 08:56 AM
Old Stonebreaker
Re: Lauson carb leaks like crazy!
I don't know what make of carb is on my Briggs powered horse, but I found the tab on the float was worn down enough the float was contacting the carb body which kept the needle from seating tight enough.
Mike
mla2ofus is offline
post #3 of 3 Old 04-09-2010, 02:34 PM
Float needs to be reset. It is set too high. or the seat is not set in all the way.
cnhyardtoys is offline
