Jinma 284 starting issue... - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 12-20-2011, 04:21 PM Thread Starter
My jinma 284 is giving me some problems..I thought it was just a weak battery because I could jump start with cables from the pickup...today it wouldn't turn at all [guages and lights looked normal], I kept trying with the key and it sounded like a fuse blew...now I am not getting anything???[guages and lights dead]
The 30 amp fuse in the block looks ok...is there a relay or something in these machines that could have blown?? If I am correct and my original issue wasnt' a weak battery what could it be? Bad starter? any ideas welcome I need this fixed...thanks.
CanuckShooter is offline
post #2 of 9 Old 12-21-2011, 10:42 AM
Re: Jinma 284 starting issue...
I'm not aware of any relays like that. I think it's time to start from scratch. Disconnect battery, put on charger. check terminals, clean, check connections, clean, looking for loose or broken wires. Pay particular attention to main grounding point on frame. Check fuses. After that and with the battery charged (if it's good) you can start troubleshooting with a meter.
Gramps in NM is offline
post #3 of 9 Old 12-21-2011, 11:38 AM Thread Starter
Update...I rechecked the fuses found the top 30amp burnt so I replaced it. Put the key on run, and jumped the starter with a screwdriver.
After running for a couple hours cleaning up the mess in my drive the tractor started right up as per normal.
I am thinking that the problem may be in the safety switch, ignition, or starter??? There was plenty of power when I jumped the starter so I don't think battery power is my problem [was my first thought]....
post #4 of 9 Old 12-21-2011, 01:06 PM
Glad it's working out for you. Still the question of blowing a fuse. In reading what you did to get it going this time you make no mention of heating glow plugs in the jumping process. You might check your glow plug wires/ strip and so on for a short. If that's OK I would look at main switch. Safety switch on clutch is easy enough to check.
post #5 of 9 Old 12-25-2011, 11:23 AM Thread Starter
That is another thing that I found a little odd...I keep it plugged in with an inline coolant heater and when I was having trouble getting it to turn over I never bothered with heating the glow plugs. So, when it did engage the starter and turn the engine over, it fired.
Did the same thing when I used the screwdriver on the starter, it turned over a couple of times and fired, which I thought was odd because I thought you always had to heat the glow plugs? Sure not complaining though because I had a real mess in the drive and was getting a little frustrated with my lack of mechanics...lol
post #6 of 9 Old 12-25-2011, 03:08 PM
Diesel self ignites by high compression. It doesn't need a spark like gasoline to ignite. The glowplug simply makes it easier to ignite the first time. Heating the cylinder with the glow plugs is something totally different to heating the cooling water. The warm cooling water doesn't circulate in the engine when it is turned off so the cylinder isn't warmed yet by the water. As soon as it is running the rest of the engine is warm so you shorten the preheat time for working. I would always use the glow function. It is also possible to preheat with the glowplugs a few times if it is very cold outside. I put a little bit mineral 2 stroke oil(~1:250) into the diesel fuel. It further enhances easy starting of diesel engines. I have never had a problem with the mixture even in very cold Austrian alpine nights! You will notice a different runing sound characteristic very quickly!
7
7sleeper is offline
post #7 of 9 Old 12-28-2011, 11:19 AM
I find that bit about the mineral oil interesting. Any idea what is in it that enhances starting? Just the oil itself? Did not realize it may be more flammable than diesel.
post #8 of 9 Old 01-06-2012, 08:44 AM
Sorry for the late answer but I was away for some time.
I'm not sure how it works but it starts and runs much smoother. I donot believe that it has anything to do with the increased flammability. The 2 stroke oil does lubricate the injection pump from the inside.
7
7sleeper is offline
post #9 of 9 Old 02-04-2013, 08:22 PM Thread Starter
Update: I found the problem that was causing the fuse to blow, one of the wiring connectors had partially come apart causing an arc (large white one near fuse box)
I also replaced the battery, cleaned the battery cables and ground connections and connections at the starter.
So now the fuses don't pop, but it only starts once in awhile using the ignition key. I'm suspect that the solinoid might have some moisture inside that is freezing because it seems to happen more often when it's below freezing. It will just 'clicks' but starts right up when I jump the starter.
At least I can cleanup the snow now. :-)
