TN70 4x4 Problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 03-22-2012, 10:46 PM Thread Starter
TN70 4x4 Problem
Just purchased a 2003 TN70 and I am having problems getting the 4x4 to engage. It is the pull up lever style with no indicator light. The book says to pull up while decelerating but that is not getting it done. I have tried clutching, not clutching as well as various speeds. Can someone help please?
Tabasco is offline
post #2 of 5 Old 03-28-2012, 01:54 PM
Re: TN70 4x4 Problem
Sorry you haven't gotten any help. My D40 Case has the same system. I usually engage 4WD while standing still with the clutch depressed. Sometimes I've had to move the tractor a bit to engage -- but seldom. I disengage while still or moving with the clutch depressed.
If I was having a problem I'd check the exposed linkage first to make sure it had enough adjustment to engage. Total movement on my lever is probably 2-3".
Are you SURE that it's not engaging? You can't tell on mine unless you load it up to the point that you need 4WD ---- as in when I'm using a 6' tilling implement or in deep snow.
Case D40
Toro 4225 Zero Turn
John Deere 111
Rumely 25-40
McCormick Deering 15-30
Larry from MT is offline
post #3 of 5 Old 03-28-2012, 10:43 PM Thread Starter
Thanks for taking the time to reply. I had checked the linkage and it seemed adequate. I tried engaging from a dead stop once before and it did not work. I will try that again as i usually am rolling as the book recommends. Thanks again.
Tabasco is offline
post #4 of 5 Old 02-18-2013, 02:42 PM
Hello,
Were you able to resolve the 4x4 engagement problem?
We have a TN70 with the same issue. Thanks. Scott
SandsFarms is offline
post #5 of 5 Old 02-18-2013, 09:29 PM Thread Starter
Scott,
Yes, I figured out the best way for my particular tractor. I travel at a moderate speed and then decelerate quickly as I pull up hard on the lever. Do not engage the clutch. I find it helps to do this on a slight decline or down slope. Maybe it will work for you.
Tabasco is offline
