NH 1725 clutch replacement - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 05-31-2011, 07:52 AM Thread Starter
Has anyone ever replaced the clutch on a 1725. I am having a bit of trouble with mine. I got it all back together and it seems like I have to use all the adjustment just to get any pedal. It dosn't seem right. Any help would be appreciated. Thanks
Larch is offline
post #2 of 5 Old 06-01-2011, 01:57 PM
MTF MEMBER
buba's Avatar
Re: NH 1725 clutch replacement
sounds like ya might have the clutch disk in backwards that is usually what happens when it is
you can never have too many antiques but finding the time and money to restore them that is a problem
buba is offline
post #3 of 5 Old 06-01-2011, 04:31 PM Thread Starter
Thanks, I'll try flipin it.
Larch is offline
post #4 of 5 Old 06-01-2011, 06:12 PM Thread Starter
I tried flippin the disc and no difference. Any other suggestions?
Larch is offline
post #5 of 5 Old 06-15-2011, 11:08 PM
The pressure plate is probably mis-adjusted from the factory. You would have to split again, put your old pressure plate on with new disc. Measure the finger height. Remove and install new pressure plate with new disc. Measure finger height and you will probably find that the finger (or adjusting bolt) height is lower. Adjust up to old pressure plate adjustment height and you will probably be fine.
Clutch manufacturer will say that this should have been checked before installing. Most people don't because the plate should be pre-adjusted.
Tractortech is offline
