connecting 2305 belly mower pto - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 08-23-2009, 04:05 PM Thread Starter
I finally got my 2305 a few weeks ago, but due to a bunch of things (moving 2 daughters, one to Chicago and one to Atlanta), I haven't had much time to use it or post on here. I did get some time today to try taking the mowing deck off. Pretty easy to do. But I'm having a helluva time getting the pto shaft back on when I try to put it back on the tractor.
Is there a trick to this? This is my first time using a pto with a collar. My old tractor had a "harder" system with a hitch pin to hold it on. But it was easy to turn the shaft to line up the splines. I can't seem to get the splines to line up on this one.
Any advice will be greatly appreciated and I hope to post some pics next week.
Thanks,
Steve
oakhilltop is offline
post #2 of 9 Old 08-23-2009, 04:18 PM Thread Starter
Re: connecting 2305 belly mower pto
I found the secret! Its, make a post on here to let the world know that you are a ????, then go out and try it again!
I had been trying for about 30 minutes, made the post, went back out, and had it on within a minute. The thing is, I'm not sure what I did different. I did try turning the shaft at the ujoint.
post #3 of 9 Old 08-23-2009, 04:33 PM
myyyy preciousssss!
smeagol's Avatar
Oakhilltop, there's a couple of things to do:
[1] make sure the collar is pulled right back and locked into place
[2] set your pto lever to rear so the the PTO spline can turn
[3] it should just slide straight on now, and when its in place the collar will lock into place
With a bit of practice it only takes a few seconds
Regards,
Smeagol
JD 2305, R4's, 200CX Loader w/53" bucket, ballast box, 54C MMM - Ind Lift Kit
Landpride 48" Box Blade
Agriquip 48" carry all
Hardi Sprayer and Sprayquip boom
Pats Easy Change Hitch System
smeagol is offline
post #4 of 9 Old 08-23-2009, 04:46 PM
Bill1031's Avatar
I can relate! Took my mower deck off for the first time last week. I had the same problem but I remembered reading on here to move lever to rear PTO. My problem was that when I took it off I did not notice the collar pulled back. So going back on it took me a little time till I noticed that it moved. Another problem was pulling the deck out from under tractor. My FEL was off so I could not lift tractor up with it but I pulled pins on wheels and droped the deck down. As smeagol says it gets easier with practice! Bill
Bill1031 is offline
post #5 of 9 Old 08-23-2009, 07:51 PM
9K+ Poster
JDFANATIC's Avatar
The sliding collar (which sort of lock in the open position) is what I expect is the unfamiliar culprit.
Cheers
JDFANATIC
JDFANATIC is online now
post #6 of 9 Old 08-23-2009, 08:53 PM
ca6120's Avatar
Thanks for the tip on the rear PTO. I never thought of that. I had resolved to just twisting the mower blades when this happend and knew there had to be a better way. It seems like it does not line up 9 out of 10 times.
ca6120 is offline
post #7 of 9 Old 08-24-2009, 08:39 AM Thread Starter
Yes, thanks for the help. I'll try it again soon and select the rear pto.
It took a little fiddling to get the pins for the lifters to line up, but I'm sure that will get quicker with practice. I used the 2305 for mowing for the first time yesterday ( I still have my old tractor) and wow, did it ever create a whirlwind under the deck. Much stronger than my old garden tractor. That's a good sign for when I use the snowblower this winter.
I found the 2305 to be very maneuverable for mowing. I went with the smaller, 53" I think, mowing deck and it worked well for my yard. There were one or two places that I couldn't get into with the 2305 that I could with the smaller deck on my garden tractor. But not bad at all. Just have to get the weed whacker out.
post #8 of 9 Old 08-24-2009, 03:30 PM
Bill1031's Avatar
There may be a better way but what I did was drop the mower (54") with it sitting on the wheels. Pulled the pins to the arms and disconnected the drive shaft. Then I pulled pins to wheels and let it drop. Slid mower out. When I put it back I slid it under and connected the drive shaft and then lifted each corner to where two holes showing on wheel shafts and slid back in pins. When I then lowered the arms, they just about right. Just took a little jiggling. While I had the mower deck out I scraped off a few clumps of grass, greased fittings on drive shaft and pullys on mower. I also used a hand grinder and just dressed up the blades. When all back together it seemed quieter. Just 16 hours on my tractor but I would say that too much grease can't hurt. Bill
Bill1031 is offline
post #9 of 9 Old 08-24-2009, 03:44 PM
JD GReg's Avatar
Ditto on the PTO lever to the rear.
Same thing will apply if/when using a
snow blower.
JD GReg is offline
