John Deere 655, 755, 855, 955 series - Page 9 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #121 of 146 Old 08-13-2012, 07:24 AM
Re: John Deere 655, 755, 855, 955 series
I recently had an issue with my 955 where the unit would not crank. I reviewed the wiring diagram and determined that this had to be an issue with the neutral safety switch.
The neutral safety switch bracket and wiring harness is underneath the center panel just in front of the seat, so I removed the center panel, disconnected the harness and jumpered across the connections and sure enough my tractor started right up. I took this opportunity to drive the tractor to the garage where it would be much easier to work on.
I ordered the new switch and proceeded to take the center section of the tractor apart to replace it. Once you have the center panel off, and the shift level panel off there are only two more items to remove, the linkage to the pedals (1 bolt), and the retaining bolt for the neutral safety switch bracket (1 bolt).
I have included a picture of this bracket. You can see that the old switch was actually broken in half. Also note the spacer underneath of the switch assembly. This spacer is required to ensure the proper alignment of the neutral safety switch with the roller that presses on the switch.
The total time to remove all panels, replace the switch and have everything reassembled, about 2 hours.
Name:	2012-08-11 09.45.09 (Custom).jpg
Rockabye74 is offline
post #122 of 146 Old 09-01-2012, 09:47 PM
I own a 755 with a pesky oil leak. I beginning to thing itís coming from the main oil seal. Has anyone experienced a leak in this location?
Zooming993 is offline
post #123 of 146 Old 09-02-2012, 09:12 AM
I had a hydro line come loose on my 855 under the floor. It was an aggravating leak. It would leak, then I'd take the middle of the floor out to find it and it wouldn't leak. Put it back and it would leak again. Finally I caught it in the act. One line was almost all the way off and the other was loose too.
2012 2520 72"MMM
roush9799 is offline
post #124 of 146 Old 09-15-2012, 02:49 PM
trainman's Avatar
Just bought a JD755 yesterday and got it home in two loads on my single axle trailer. As a mower it is way over kill for our 2 acre yard, BUT, as a snowblower, it will earn its keep fighting Lake Erie 'lake effect' snow drifts --- This is one tough built machine, was very happy to get it!!
Ray G.
Erie, PA
PK 1620 #66031 (1989)
JD 110 #A18639 (1965)
JD 110 #11031 058569M (1966)
JD 70 #T2011 039293M (1971)
JD 111H #C111HL 222135 (1982)
JD 116H #M00116D302365 (1984)
JD 116H #M00116D341244 (1985)
CubCadet 2185 (199?)
4 Fairmont Motorcars 1946 - 1983
trainman is offline
post #125 of 146 Old 09-15-2012, 02:52 PM
I Love All Color Tractors
DJ in WV's Avatar
Images: 6
Good looking tractor Ray! The blower in the background looks to be in great shape too. Are those a couple of extra wheels on the trailer too?
My YouTube Page
The Shops of Oak Point Farm
My Equipment:
1961 Gravely LI Postal
1967 Gravely 430
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1973 Gravely Model C8
Many other Gravely C's, L's, and LI's
1982 Gravely 8123
1983 Troy Bilt Junior
1988 Gravely Pro 12
DJ in WV is offline
post #126 of 146 Old 09-15-2012, 03:24 PM
trainman's Avatar
Ha! Good eyes, but, you won't really believe this... those wheel rims are the "mid-ramp supports" for the old wood ramps that go with my trailer!! They were left at a dumpster and I snagged them. They are lighter than cinder blocks, don't chew up your hands when you pick them up like the blocks do, and are wide enough to help keep the ramps from rocking if you don't run square up the middle.
Now, 'somewhere' I have newer aluminuminum ramps, but somewhere is a pretty large place.
rayg
Ray G.
Erie, PA
trainman is offline
post #127 of 146 Old 09-17-2012, 10:01 AM
Trainman
Nice set up. Congrats
I have an 855 about the same vintage I imagine. Like you say it is a real brute for power and usefulness.
The one thing I did that helped a lot with snow work is to load the turf tires with anti freeze and ww fluid. That and two link ladder chains make snow work a breeze. Loaded tires make FEL work easier, and don't cause problems mowing.
Enjoy
Wyobuckaroo is offline
post #128 of 146 Old 09-21-2012, 12:09 PM
Bought this 955 and dragged it home two years ago:
I used it to unload this partial 955 that I bought several months later:
With a combination of pieces and parts from both (and other tractors) it now looks like this:
ID:	230117 Click image for larger version
ID:	230118 Click image for larger version
Don't let the decal on the hood fool ya... that's no 430.
Mechanos1 is offline
post #129 of 146 Old 09-21-2012, 04:34 PM
Just passing through
Upper5Percent's Avatar
Attachment 230115
Attachment 230116
Attachment 230117 Attachment 230118 Attachment 230119
Nice rebuild...
That 430 decal will someday just confuse the heck out of a future owner...can just see that post in the future on MTF...
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #130 of 146 Old 09-21-2012, 09:58 PM
DJ in WV's Avatar
Images: 6
Very nice.
Did you document your rebuild with pics? If so, I'd love to see a thread on it.
My YouTube Page
My Equipment:
1967 Gravely 430
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1982 Gravely 8123
1988 Gravely Pro 12
DJ in WV is offline
post #131 of 146 Old 09-21-2012, 10:35 PM
Originally Posted by DJ in WV View Post
Very nice.
No, I did not. I'd still be working on it if I'd taken the time to clean my hands and pick up the camera after every step. There just wasn't enough time in my busy schedule for all that. I was lucky to get the time in on it that I did.
It was nice to use it instead of working on it for a change. Hooked up the brush hog tonight and did a little mowing that I've put off to work on the tractor. The grass in the "pasture" was getting pretty tall and thick, so I cut it with the brush hog this time.
post #132 of 146 Old 09-22-2012, 04:58 AM
JeffinIA's Avatar
You did a great job on the 955 !! My 855 Loves the tires and rims I got from you. A couple boot patches in the rears , new tubes and new fluid and they are still way better than the turfs that were on it , I doubt I'll ever put them on again.
John Deere 445/60"mmm
John Deere 855 w/woods LS72 Loader,
and 72"mmm
Simplicity 4213
Simplicity 4211
1965 Farmall 706
1958 Farmall 560 gas
JeffinIA is offline
post #133 of 146 Old 09-22-2012, 06:11 AM
Likes Vintage JDs
UrbanTractor's Avatar
Just wanted to say to all you guys fixing up these -55 series tractors: Wow! Nice work. They a really have a strong, classic look about them. Keep the photos coming.
UrbanTractor is offline
post #134 of 146 Old 09-25-2012, 06:11 PM
Originally Posted by HookMan View Post
Anyone have one of these units? Likes and dislikes? There seem to be a decent amount of them around without a ton of hours and prices seem ok too. Just curious if they have any known issues or problems. Thanks!
had a 955 for over twenty years love it, it does all I need. but right now I need a radiator for it. otherwise very good maching.
dabadgerusa is offline
post #135 of 146 Old 09-25-2012, 06:17 PM
Attachment 230115
Attachment 230116
you wouldn"t have a radiator lieing around for a 955 would you?
