Dealer put tubes in the tires!!! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 31 Old 06-23-2009, 05:37 AM Thread Starter
unit40's Avatar
We were working on a ballfield yesterday with the 1070 when one of the front tires went flat. One of the guys noticed that the front tires had tubes in them. We had the dealer replace the front tires last fall because they were getting worn and had many plugs in them and we needed other work done on the tractor at the time so I didn't think it was a big deal. I called the dealer service dept and asked why they put tubes in tubeless tires. They told me that once you break the factory bead then the new tires will always leak. What a bunch of bull!!! We have NEVER, EVER put tubes in our tires on any of our machines. The worse case was with a Kubota F3060 mower when the calcium filled rims rotted out from the inside so we had to replace the rims and the tires. So yesterday, we used a portable air tank to get the tractor back up on the trailer, I brought the tractor back to the shop and put the rim on the tire machine, pulled out the tube, the rim was in great shape, applied some bead sealer and a metal screw on valve stem and viola, NO LEAKS!!! Once, if ever , I get caught up, I'm going to pull apart the other front tire. Turns out some gunk managed to get in the valve stem hole in the rim where the tube stem was sticking out. Tubes are bad, bad, bad!!!!! Dealer is starting to make me think that along with some other questionable jobs they have done, that maybe I should look elsewhere.
unit40 is offline
post #2 of 31 Old 06-23-2009, 06:24 AM
Collector of many tractors
Kbeitz's Avatar
Re: Dealer put tubes in the tires!!!
Hummmm.... I put tubes in all my tires and I like them...
Kbeitz is offline
post #3 of 31 Old 06-23-2009, 06:44 AM Thread Starter
unit40's Avatar
Why put tubes in tubeless tires? Do you ever get a puncture? You cant plug it you have to break down the tire. Ever get water in through the opening in the rim where the valve stem comes out? You'll get rot inside the rim. Plus crap can get in there and wear away and abrade the tube.
unit40 is offline
post #4 of 31 Old 06-23-2009, 07:33 AM
The Magnificent
D-Dogg's Avatar
There is little chance any junk gets past the stem of a properly inflated tube. Also the tube will receive and contain the water from the air used to fill the tube, rather than having it rust the rim.
Tubes prevent the bead from accidentally unseating on a low pressure tire, and prevent blowouts that can occur during a loaded turn.
I would not use my FEL with tubeless tires. Of course, I am a safety Nazi.
You are honestly the first person I've met to decry tube use. Interesting point of view, but I think you are going to hear much strong disagreement with your position.
D-Dogg is offline
post #5 of 31 Old 06-23-2009, 07:36 AM
Retired Aug.31 2007
jeepersmitty's Avatar
When I get a flat it gets a tube and slime in the tube. Once a tire is done that way I seldom ever have to bother with a flat untill the tire is wore out.
I always know...
jeepersmitty is offline
post #6 of 31 Old 06-23-2009, 09:38 AM
JD RULES
x595's Avatar
Images: 3
Hi all ,
I don't use tubes , just never needed them and SLIME only guarantee's it's
performance for 2 years , then they recommend removing the product and
replace with new , (not happening) ... What I use is a product from
www.gemplers.com called ULTRASEAL , very good product , our Military
uses it and no expiration date !!!
Later,x595
2005 JD X595 w/ HDAP Tires
54c MMM --- (SOLD)
62c MMM
54" Quick Hitch Front Blade
4x8 Utility Trailer - 1500# Axle
North Star 15,000 Watt Generator
Troy - Bilt Super Bronco Rear Tine Tiller
Troy - Bilt 2500 PSI Pressure Washer
22" Yard Machine Push Mower
SpeeCo SplitMaster 28 Ton - Horizontal/Vertical Log Splitter
STIHL 025 - 18" Bar --- (SOLD)
STIHL 025 - (Spare Parts Saw) --- (SOLD)
STIHL MS 290 FARM BOSS - 20" Bar
STIHL FS 45 Trimmer
x595 is offline
post #7 of 31 Old 06-23-2009, 02:44 PM Thread Starter
unit40's Avatar
I would either plug or patch the tire. None of our loaders have tubes. Non of our back-hoes have tubes. If a low pressure tire blows out then it was overloaded. Keep the tubes for fun on the lake.
unit40 is offline
post #8 of 31 Old 06-23-2009, 03:14 PM
Banned!
Wouldn't have it any other way. put my name on the board for tubes!
music-in-a-bottle is offline
post #9 of 31 Old 06-23-2009, 05:43 PM
USMC
slkpk's Avatar
Images: 21
slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #10 of 31 Old 06-23-2009, 06:19 PM
Grateful11's Avatar
If you live on a farm long enough you're going use a tube eventually. Just put a new tire on the IH 82 pull-type Combine she gotta tube to boot. Slow
leaks is what gets most of ours, not punctures or cuts. A slow leak will nag
you to death.
'11 John Deere 5065M /cab
'10 Kubota L3940 w/FEL
'09 JD X720
'91 CaseIH 5140 Maxxum w/cab
'78 IH 686 w/M&W Turbo 106 PTO hp w/canopy
Grateful11 is offline
post #11 of 31 Old 06-23-2009, 08:44 PM Thread Starter
unit40's Avatar
Won't just about any tire slowly leak all of it's air over time? I think if you have a nagging leak, then you find the leak and you fix it. If your valve stem leaks you're going to break down the tire and put a tube in it? If you're leaking air through the bead you're gonna break down the tire and put a tube in it, instead of replacing the valve stem or cleaning and sealing the bead? If putting a tube in you're tire is the way you want to fix a problem, OK with you. But a professional Deere service department should know how to properly install a tractor tire on a tractor rim the way it is supposed to be installed and I don't see any tube in a parts breakdown for any Deere tractors, do you? My 2 cts.
unit40 is offline
post #12 of 31 Old 06-23-2009, 11:41 PM
~aRBy~'s Avatar
That would be why you got a tube.
Also, why would you put calcium in to a tubeless tire?
74 - Ford 4000
99 - Husqvarna YTH 150
07 - Huskee Supreme SLT4600H
05 - John Deere GX345
Chainsaws, Husqvarna: 340e, 345e, 345e, 346xp, 445, 357xp Dolmar: PS-5105 Stihl: 028av, MS280, MS260 Homelite: super EZ auto, Super XL auto McCulloch: Pro-Mac 10-10
~aRBy~ is offline
post #13 of 31 Old 06-24-2009, 12:54 AM
Just passing through
Upper5Percent's Avatar
Tubes vs Tubeless
Hokey Smoke...we've discovered another issue rivaling politics and religion...
When it comes to loading tires...Rim Guard is the way to go...non-polluting/ non-rim-rotting beet mixture...
http://www.rimguard.biz/
Rim Guard™ was developed and patented in 1998 as a liquid tire ballast that overcame all of the shortcomings of other liquid tire ballasts.
• Rim Guard™ is nearly 30% heavier than water.
• Rim Guard™ is non-corrosive.
• Rim Guard™ is non-toxic and biodegradable.
• Rim Guard™ is freeze-resistant down to -35°F.
• Rim Guard™ is cost effective because inner tubes are not needed and tires are easier to repair.
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #14 of 31 Old 06-24-2009, 05:23 AM Thread Starter
unit40's Avatar
We didn't put the calcium in the F3060's tires, the Kubota dealer did when they sold us the mower. The machine had filled tires and wheel weights to provide added traction to the drive tires and provide added stability for the machine because of the hopper that rests on a frame over the rear hood raised the center of gravity. Rim Guard, beet-juice, whatever works for you. I think the standard procedure when loading a tire with CaCl is to fill it so much that none of the inside rim is exposed to air. Try checking tire pressure with a calcium filled tire...it will destroy the gauge.
unit40 is offline
post #15 of 31 Old 06-24-2009, 06:47 AM
UK Poster
Simon Smith's Avatar
Images: 13
The reason we put tubes in whenever we take a tyre off is because almost every LT or GT and a lot of compacts actually need them.
Most manufacturers use tubeless tyres, but they are not tubeless rims. New machines generally arrive with almost flat tyres so we just inflate them to the correct pressure, but if the bead has broken we fit tubes. I always have tubes in my machines and have had no problems with punctures, but have the satisfaction that a puncture in a tube can be repaired in the field with basic tools.
If someone has a lot of thorns we fit tubes and thornguards. Or for a larger tractor doing hedgecutting work etc we would recommend nailguards.
Calcium will always rot the rims if used without tubes, it is not only impossible to fill the tyre completely so there is no air gap but it is also against all the recommendations I have seen. A tractor needs something compressible in the tyres (air) as that is its suspension.
1992 LandRover Defender 110 County
1968 Wheelhorse Commando 8 (mine)
1968 Wheelhorse Commando 8 (unrestored, shared)
1972/2005 Wheelhorse Dual Drive (triple D, shared)
1972 Wheelhorse GT14 (unrestored shared)
1972 Wheelhorse Raider 12 (unrestored, shared)
2011 Triumph Tiger 800XC
Simon Smith is offline
