need a opinion on a 3 point 5 foot farmking finishing mower - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 04-20-2008, 09:54 PM Thread Starter
Mr. Dave's Avatar
One of my neighbors has a 5 foot farmking finishing mower that he bought for his 2210 and he is selling it cause he says it doesn't do the best job on uneven ground. He said he bought it 3 years ago for 1400.00 plus he had to buy the PTO shaft seperate. He used it less than 6 times and it shows it. He said he would let me have it for 900.00. I was thinking about getting it cause I put a skid plate on my 2305 and I have to take it off to put on the MMM and this would be easier to take on and off. I also have some uneven ground but is there a way to get a good even cut with these 3 point finishing mowers. I would appreciate some opinions from some people with experience using these finishing mowers and is farmking a decent brand. It was factory painted JD green.
Thanks...Dave
JD 2305, 200CX FEL, Working lights W/ Guards, Bro-Tek Skid Plate, IHL, farm king / buhler finish mower, 72" Ford Rear Blade, Ballast Box, SpeeCo quick hitch.
Mr. Dave is offline
post #2 of 6 Old 04-20-2008, 10:15 PM
Good at breaking stuff!
cdhd2001's Avatar
Re: need a opinion on a 3 point 5 foot farmking finishing mower
Thanks...Dave
I posted a reply then realized you asked about a "finish mower" and not a "rotary cutter".
Someone should be along shortly to help with the question...
FYI, I have been using my rotary cutter (with 2 back wheels!) as a "finish" mower. Looks good to me but then I am not a mowing perfectionist. Plus I live out in the country and my neighbors should just be happy that I even mowed the grass...
2011 John Deere 2520 with 200CX Loader & 46 BH
2014 John Deere Gator 855D with PS
2013 John Deere X320
Forest fires are not fun!
cdhd2001 is offline
post #3 of 6 Old 04-20-2008, 11:03 PM
Images: 10
Hey Mr Dave, I have a 6' Farm King finish mower that I bought used about 3 years ago. Mine is blue, and does work great. I bought it for mowing areas that gets mowed every 3 or 4 weeks. I bought it for around $480 from a dealer. Its in really good condition. I would say $900 would be a good buy if it was used like 6 times. Also mine is a side discharge and does not throw the grass out very far, but does not windrow. Some clippings just drop down under the mower like the blades are not supplying enough vacuum. Overall I do like the mower, but like I said I dont use it on a week to week basis. Good luck Dave!!
NEWT92 is offline
post #4 of 6 Old 04-20-2008, 11:10 PM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
Thumbs up Re: need a opinion on a 3 point 5 foot farmking finishing mower
I use a 5' King Kutter finish mower..It cuts a lot better that when I used a rotary cutter..
My ground is not even and it rides on 4 caster/swivel wheels..
$900 sounds like a good price!!
R.I.P Durwood
Ken N Tx is offline
post #5 of 6 Old 04-21-2008, 07:33 AM Thread Starter
Mr. Dave's Avatar
Hi NEWT92,
Does the side discharge make a differnce on the Farm King finish mower?
Regards...Dave
Mr. Dave is offline
post #6 of 6 Old 04-21-2008, 09:02 AM
Images: 10
Hi NEWT92,
Regards...Dave
I really cant answer that because I never used a rear discharge. I have seen on some rear discharge mowers, if the grass is tall and/or wet they will windrow bad, between each blade. I can say that I have cut some tall grass and mine has never left a noticable windrow. The discharge on mine is wide open from front to back. Also, the way the underside is designed, as far as the baffles, is wide open so no real chance to really create alot of vaccum, so thats why some clipping just fall down, and not get thrown out. Mine is about, if I had to guess around 10 or so years old. The newer decks may be different.
NEWT92 is offline
