summer and winter diesel fuel - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 10-13-2010, 06:56 PM Thread Starter
JD GReg's Avatar
We are getting closer to that time of year, where we will
be switching to winter diesel fuel.
Can a person mix the two diesel fuels without any issue.
Like, if I have 1/2 tank of summer diesel left in my
tractors, can a person just top off with winter diesel.
Or, to get rid of the summer diesel, can I blend it with
winter diesel.
Right now, I'm trying to not buy anymore diesel fuel until I
absolutely need it, but I'm sure I will have some summer diesel
left over when winter hits. Same thing will apply next spring
when I have left over winter diesel.
Greg
JD GReg is offline
post #2 of 8 Old 10-13-2010, 07:02 PM
picframer's Avatar
Images: 7
Re: summer and winter diesel fuel
Yes, put some additive in with the mix and you will be fine, we go through so much we have a pup trailer that goes around filling things, we are now at 5 degrees C in the mornings and some of the tractors really don't care for what they are drinking but after a few moments they are fine, excavators don't seem to care.
A colllection of CUT's, excavators and GT's, just about every attachment going and a major amount of Stihl gear. We operate a Landscaping business.
Smiling every Day!!! Andy
picframer is offline
post #3 of 8 Old 10-13-2010, 07:05 PM
Last couple times we fill the tanks prior to the really cold weather we get the winter grade. Never had a problem mixing them. We do use a stabilizer and algae treatment year round. I've never heard of anyone having a problem mixing the fuels.
Mike
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is offline
post #4 of 8 Old 10-14-2010, 02:01 AM
Just passing through
Upper5Percent's Avatar
"Q: Is cold weather fuel "different" from summer fuel?
One TDR (http://www.turbodieselregister.com/) member works for a fuel pipeline company that blends fuels for northern climates.He posted this information to the TDR forum:
Most fuels are blended by the refinery. Our #2 has a flashpoint of 138F to 148F in the winter months and 150F to 170F in the summer. We add 1.25 gallons of Paraflow 527 per 1000bbls of each reciept. Our straight #2 diesel has a cloudpoint of -10 to-15.Our premium diesel has a extra additive package and is good to -20 to -25. Some customers from colder climates in our area will custom blend their fuel to their climate. This is done by the carrier(truck) at the rack and is usually 70/30 or 75/25. To make it short.if you live in a colder climate you are probably getting blended fuel. I use a regular diesel with 50ml of Amzoil Cetane booster in every other tank. I have not had any problems down to -30.
Our #1 diesel runs at 110F to 130'F flash and 41.0 to 44.0 gravity at 60 - all depending on the season. #1 is a hotter fuel and lighter than #2. "
On the farm we use Deere additives...so we just change our additives from the summer formulation to the winter one...
https://jdparts.deere.com/partsmkt/d...onditioner.htm
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #5 of 8 Old 10-14-2010, 01:47 PM
2320Guy's Avatar
I live in a Northern Climate, and run a diesel truck (Chev 2500HD) and my 2320,..This is the first I have heard of "cold climate diesel"??? I just buy what is at the pumps. Should I be running premium in the winter on both perhaps???
Edmonton, Alberta, Canada
2014 JD 1025R
60" Mowing Deck with Mulching Kit
72" Custom FEL Snow blade for loader
JD IMatch
2320Guy is offline
post #6 of 8 Old 10-14-2010, 03:41 PM
This is what I have used in all of our Duramax Diesels in the winter...
Economic cold weather protection
* Fuel Gelling Protection - pour point reduced by as much as 40F (22C), depending on base fuel
* Reduces ice formation of water in fuel
* Contains no alcohol
* Specially formulated for ultra low sulfur diesel
* Can be used with bio diesel up to B5 (5% bio content)
http://www.stanadyne.com/view.php?id=76
post #7 of 8 Old 10-14-2010, 05:39 PM
USMC
slkpk's Avatar
Images: 21
I like FPPF Polar Power or Power Service. I've had the best luck with. Nothing worse than being gelled up in the winter. I change the fuel filter each fall and drain some of the fuel and moisture out of the tank before adding any additive for the winter. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #8 of 8 Old 10-15-2010, 11:13 AM
Nicky&Sterling RIP 03-08
saskman49's Avatar
You get winter diesel anyway. I always check as to when it comes in as I only buy my fuel at the CO-OP and they are very good about this. I would recommend you check where you buy your fuel about it as well. BTW I have never seen premium diesel fuel in these parts as even furnace oil here is dyed diesel according to the CO-OP manager at the AG center.
I run Texas Refinery DZL-PEP Artic additive in my diesel fuel year round as it is what most farmers around here have used for years.
John
JD2320 with 62D, 200 CX with 53" bucket
Speeco QH & Hydraulic top link
JD 647 tiller
JD 413 Rotary Cutter
Frontier SP1060 Soil Pulverizer
Frontier BB2060 Box Blade
Land Pride 1572 Rear Blade
Allied 50" blower
Frontier pallet forks
55 Gal 3pt sprayer
Frontier middle buster
3 section diamond drag harrows.
Homemade garden Bedder and cultivator with 2" receiver as well
JD X485 with 62C deck
JD Gator TH 6x4
JD 216H 46 mower and 33 tiller
JD JS35 Mower
Stihl BG86, 017, MS250, FS90R, KM130R
saskman49 is offline
