How many hours on an oil change? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 06-09-2010, 09:17 AM Thread Starter
c5rulz's Avatar
The other thread on the 50 hour service interval got me thinking. The manual says engine oil "every 200 hours or yearly".
I am surprised how few hours I put on the 2305 since I use it year round for snow removal. I did the 50 hour service last spring and now have about 140 hours on it. I am probably going to change the engine oil and @ 150 hours. I can't see doing it at 90 hours as that is way sooner than the other parameter John Deere reccomends.
BTW, I am considering switching to synthetic oil since it isn't much more expensive than JD oil.
Thoughts gentlemen?
SS1023B PTO driven spreader
John Deer GT235 48" with powerflow bagger
Husqvarna 353, OE Tree Monkeyed 346XP, 346XP ported, 550XPG, 357XP, 562XPG, 372XPG ported, 288XP Lite ported,
Dolmar 7900
Jonsered 2159 ported
Echo CS303T
Echo PPT 266
Echo PPT-266 pole saw
Speeco 28 ton splitter
Silvey 510
Oregon 511AX
Nielsen 100B for rakers
Stihl straight shaft trimmer W/ cutting blades
c5rulz is offline
post #2 of 17 Old 06-09-2010, 09:21 AM
The Magnificent
D-Dogg's Avatar
Re: How many hours on an oil change?
Once per year regardless of hours would be my absolute minimum. You need to get out the moisture which inevitably enters the crank case.
D-Dogg is offline
post #3 of 17 Old 06-09-2010, 09:31 AM
Central Kentucky
BigD's Avatar
Images: 9
I've been changing the oil at 100 hours and the filter at 200 hours. Still using the Dino type oils since I was told its the diesel soot contamination in the oil that needs to be removed by periodic oil changes.
Pete,
JD 2320, FEL,62D MMM, 4 ' Box Blade, 6' rear blade, 4' tiller and 17' Gator Trailer
BigD is offline
post #4 of 17 Old 06-09-2010, 09:33 AM
9K+ Poster
JDFANATIC's Avatar
I've changed the oil/filter in all my Deere's at 50 hrs and continue to do so on my 2210. I know it's way below the recommendation, but I feel more comfortable . . . and the cost, negligible.
Cheers
JDFANATIC
JDFANATIC is online now
post #5 of 17 Old 06-09-2010, 11:31 AM Thread Starter
c5rulz's Avatar
I understand the condensation thing, but mine sits in a heated garage and normally runs at least an hour every time it is used.
Dolmar 7900
Echo CS303T
Echo PPT 266
Silvey 510
Oregon 511AX
c5rulz is offline
post #6 of 17 Old 06-09-2010, 11:36 AM
Master Control's Avatar
Preach it brother JDFan! You can't service them enough ... or often enough!!
Have a great day,
Joe
I'm as old as my tongue and a little older than my teeth, and that's the truth.
International Harvester 424D Utility (1964)
John Deere 2305 MFWD
200CX w/49" bucket
John Deere 4005 MFWD
300CX w/61" bucket
John Deere Z510A w/48" 7-Iron deck
John Deere Z920A w/48" 7-Iron MOD deck
John Deere 54C Mower (2305)
John Deere 647 Tiller
John Deere 673 Tiller
John Deere Ballast Box
John Deere PHD300 Post Hole Digger w/stand
John Deere PHA109 Post Hole Auger 9"
John Deere MX6 Rotary Cutter
Agrex XA500 Spreader
Artillian Pallet Forks
Bush Hog SBX72 Box Blade
ECHO Bear Cat 5540 Chipper/Shredder w/optional blower, chute and cap
Fred Cain S-2 Subsoiler
Frontier LP1184 Land Plane
Home-made "Peanut Weeder"
International Harvester 309A Moldboard Plow 3-16
Leinbach 81-16 Moldboard Plow 1-16
Leinbach GB48 Garden Bedder
Leinbach RR-8 Landscape Rake
Stihl FS 110 R Trimmer
Stihl BR 600 Magnum Backpack Blower
Over 90
[Ken N Tx gave me this moniker on 28 Aug 2010.]
Master Control is offline
post #7 of 17 Old 06-09-2010, 01:07 PM
jsb2b's Avatar
I do my oil and filter every spring for the mowing season and only oil in the fall for the plowing season. I have 170 hours since purchased in Sept 2005. Did the 50 hour service in July of 2006. Low useage. Probably overkill on the maintenance but it's a cheap investment every year.
JD 2305, JD 62C MMM, JD 54" QH Blade, JD JS-63C
jsb2b is offline
post #8 of 17 Old 06-09-2010, 01:34 PM
Great Site Good People
BLIND REF's Avatar
I am switching to synthetic oil (Amsoil)this time around.
John Deere 2305 TLB, 62MMM
BLIND REF is offline
post #9 of 17 Old 06-09-2010, 08:36 PM
USMC
slkpk's Avatar
Images: 21
I plan on keeping mine a long long time slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #10 of 17 Old 06-09-2010, 08:38 PM
89YT12's Avatar
Images: 9
its not green but every 50 with castrol 30w and a dab of lucas
Jason "J"
89YT12 is offline
post #11 of 17 Old 06-09-2010, 08:56 PM
refueler's Avatar
I change the oil and filter in my 4110 every 50 hrs. I'm sure its overkill but its not much money and the oil looks dirty so I change it.
refueler is offline
post #12 of 17 Old 06-09-2010, 11:39 PM
Just passing through
Upper5Percent's Avatar
Water is one of the most destructive contaminants in most all lubricants. It attacks additives, induces base oil oxidation and interferes with oil film production. Low levels of water contamination are normal in engine oils. High levels of water ingression merit attention and are rarely correctable by performing an oil change. The following are some additional notes on water contamination:
*Long idling in wintertime causes water condensation in crankcase, which leads to loss of base number and corrosive attack on surfaces, oxidation of the oil, etc.
*Emulsified water can mop up dead additives, soot, oxidation products and sludge. When mobilized by flowing oil, these globular pools of sludge can knock out filters and restrict oil flow to bearings, pistons and the valve deck.
*Water sharply increases the corrosive potential of common acids found in motor oil.
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #13 of 17 Old 06-10-2010, 09:21 AM Thread Starter
c5rulz's Avatar
But doesn't having a heated garage for winter use and running an hour each use minimize condensation accumulation? FWIW, I generally won't idle the motor under 1500 rpm unless engaging the PTO.
Dolmar 7900
Echo CS303T
Echo PPT 266
Silvey 510
Oregon 511AX
c5rulz is offline
post #14 of 17 Old 06-10-2010, 01:25 PM
Once a year for me, regarless of hours. I also go ahead and change all filters (inner, outer air & fuel), except transmission filter. Been doing it this way since '05 and it has been working out well.
johnnydel29 is offline
post #15 of 17 Old 06-10-2010, 02:25 PM
The Magnificent
D-Dogg's Avatar
Nice equipment in your signature, btw.
Because of such an investment, it seems a bit odd to me that you are wanting to be stingy with the oil.
I posted a thread a while ago about bad oil looking good. In short, I had changed hydrostatic fluid which looked perfect, contained no apparent moisture, and in an unscientific flow test, flowed exactly the same as new.
However when I fired the tractor up, everything about the transmission was better. No more moaning, groaning, higher top speed, faster action on the lift, etc.
D-Dogg is offline
