2305 Turn Signal/Flashers not working - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 04-27-2010, 02:21 PM Thread Starter
I am having an issue with my turn/flashers. The lower red driving lights work, but the upper yellow turn/flashers do not. I have tried to replace the flasher relay LVU800247 ~$80, but that did not solve the problem. The bulbs are good and I am getting a clicking sound from the relay.
I traced the green/red and green/yellow from the lights/dash indicators. I am getting voltage out from the relay, but nothing when I connect a bulb. Is this a grounding issue, fuse or possible secondary relay?
I checked all four aux fuses under the hood and cleaned battery/frame ground connections to no avail.
Appreciate any assistance offered, thanks in advance.
Note: I have ordered the tech manual on CD, but thought I may be able to solve the issue while waiting for it to arrive ....
whereditgo is offline
post #2 of 3 Old 04-27-2010, 02:43 PM
Phoenix125's Avatar
Re: 2305 Turn Signal/Flashers not working
Hmmm. It sounds like you tried most of the more common causes. The ground is not likely the issue since the marker lights are working.
I was talking to our local JD mechanics and they said they've had problems with diodes blowing on the turn signals (but only when the customers were wiring a trailer harness).
Here's the page you're looking for:
Tech_Manual_p166.pdf
-William "Kim" - AKA: Phoenix125
2009 JD 2305, FEL w/ 53" Bucket & hooks, 54" MMM w/ Ind. Lift, Hydraulic Diverter, & JD Mulch Kit, 12v Port 1 & 2, (3) ROPS Lights, JD Ballast Box w/ Reese Hitch mod, JD 60" Back Blade, Harbor Freight Quick Hitch (27.5" due to old implement), Bro-Tek Skid Plate, Markham Welding Tooth Bar, Wallace 5' Box Blade, Frontier GM1060R Finish Mower, EZmover Hitch, Harbor Freight Winch, Clamp-On Pallet Forks from eBay, CountyLine Carry All, Agri-Fab Speader, Precision Dethatcher, County Line 5' Landscape Rake, Fimco 15gal 2.1 GPM Sprayer, TSC 48"x24" Roller, Precision Spreader, CountyLine 3pt Post Hole Digger
My 2305 & 200CX Maintenance Schedule Check List: PDF Excel
Phoenix125 is offline
post #3 of 3 Old 04-27-2010, 02:45 PM Thread Starter
Thank you for your help ... Just found that info as well here :
No binkers on my 2305!!!
Will order the four diodes LVU801851 and see if that works.
