John Deere 870 3 point hitch question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 04-12-2010, 02:32 PM Thread Starter
Blueberry's Avatar
Hello.
I recently acquired a JD 870 tractor and have been trying to use a back blade to scrape the top layer of sod off of an area of my property. The problem is that no matter how low I set the hitch down, the blade floats, is that the way it is supposed to work? I thought it would push into the ground and allow me to set the depth.
Thanks in advance for your responses.
Blueberry is offline
post #2 of 5 Old 04-12-2010, 02:53 PM
9K+ Poster
JDFANATIC's Avatar
Re: John Deere 870 3 point hitch question
BB,
Welcome to the forum! A 3PH doesn't have downforce so a back blade will only dig to the extent it's weight will cause it to. Sometimes you can add weight, but this is a case where a box blade (with adjustable scarifiers) will dig much better.
Cheers
JDFANATIC
JDFANATIC is offline
post #3 of 5 Old 04-12-2010, 02:59 PM Thread Starter
Blueberry's Avatar
Thank you! That is exactly what I needed to know.
post #4 of 5 Old 04-12-2010, 09:28 PM
I Love All Color Tractors
DJ in WV's Avatar
Images: 6
The only other option that you have besides trying to add weight to the blade, is to lengthen the top arm to make the blade angle into the ground more. Think of a wood chisel turned over from the way it is supposed to be. This will help some, but JD is correct. The best way is with a box blade with scarifiers.
Challenge Met
Looking for a Technical Exchange Article? Here's an Index!
My YouTube Page
My Equipment:
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1973 Gravely Model C8
Eight other Gravely C's, L's, and LI's
1978 Massey Ferguson 1655
1982 Gravely 8123
1983 Troy Bilt Junior
DJ in WV is offline
post #5 of 5 Old 04-13-2010, 11:38 AM
Phoenix125's Avatar
and congrats on your new tractor!
- When using the back blade, sometimes several passes over the same site helps.
- You could try to angle it (set it to 30 or 45 degrees), then shorten the top link allowing the front edge of the blade to dig to help break the surface.
But, of course, as JDFan and DJ have said, a box blade would work best. I purchased a back blade having the same hopes and you and ended up buying a box blade off Craigslist a couple weeks later.
-William "Kim" - AKA: Phoenix125
2009 JD 2305, FEL w/ 53" Bucket & hooks, 54" MMM w/ Ind. Lift, Hydraulic Diverter, & JD Mulch Kit, 12v Port 1 & 2, (3) ROPS Lights, JD Ballast Box w/ Reese Hitch mod, JD 60" Back Blade, Harbor Freight Quick Hitch (27.5" due to old implement), Bro-Tek Skid Plate, Markham Welding Tooth Bar, Wallace 5' Box Blade, Frontier GM1060R Finish Mower, EZmover Hitch, Harbor Freight Winch, Clamp-On Pallet Forks from eBay, CountyLine Carry All, Agri-Fab Speader, Precision Dethatcher, County Line 5' Landscape Rake, Fimco 15gal 2.1 GPM Sprayer, TSC 48"x24" Roller, Precision Spreader, CountyLine 3pt Post Hole Digger
My 2305 & 200CX Maintenance Schedule Check List: PDF Excel
Phoenix125 is offline
