John Deere 950 c/with Model 40 Rotary Tiller - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 04-03-2010, 05:42 AM Thread Starter
Well I managed to find myself a Model 40 Rotary Tiller, fitting nicely on my John Deere 950. It's 60 inches wide and appears to have be made in heaven to fit the old girl. I lucked out by surfing the web and located at a local John Deere dealership. Paid $750 cdn, I grabbed it and ran out the door.
Question - I've ordered the manual, but was surprised to find that the dual side drive chains don't appear to have any lubricate oils or greasing points ?? Has anyone had any words of wisdom on the maintenance of this rotortiller.
DV Knutson
Alberta Canada
Name:	JD 950 & Model 40 Tiller.jpg
dvknutson is offline
post #2 of 9 Old 04-09-2010, 05:09 AM Thread Starter
Re: John Deere 950 c/with Model 40 Rotary Tiller
Nothing ?? ... I quess I'm the only person interested in mantaining this vintage of Tillers !!
post #3 of 9 Old 04-09-2010, 04:03 PM
Citizen of Earth
bontai Joe's Avatar
I'll move this over to the compact tractor forum where folks may have an answer for you. You posted this in the lawn & garden tractor forum.
If it's FREE, it's for ME!
bontai Joe is offline
post #4 of 9 Old 04-09-2010, 04:38 PM
9K+ Poster
JDFANATIC's Avatar
Nice catch Joe! That's a new tiller on me.
Cheers
JDFANATIC
JDFANATIC is offline
post #5 of 9 Old 04-09-2010, 06:42 PM
Just passing through
Upper5Percent's Avatar
DV Knutson
Alberta Canada
There should be a plug on the side of the chain case...
SAE 90 wt. oil
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #6 of 9 Old 04-10-2010, 07:43 AM Thread Starter
Help Re: John Deere 950 c/with Model 40 Rotary Tiller
That's the problem ... I can't seem to locate any such plug. I'm including a pic of the tiller taken while in the back of a Pickup.
The chain guard (one piece on each side) has what appears to be a tightener and a pivot block. I'm going to remove or loosen the tightener and see what's underneath ?? I've looked quickly, but maybe I've missed the obvious hidden hex plug??
I've got a manual ordered. I can't imagine the side chains running dry ??
DV Knutson
Name:	Model 40 JD Tiller (S) .jpg
post #7 of 9 Old 04-10-2010, 07:59 AM
9K+ Poster
JDFANATIC's Avatar
DV Knutson
My snowblower has a chain drive that run dry so it may be possible but I think it was wise to order the manual.
Cheers
JDFANATIC
post #8 of 9 Old 04-10-2010, 09:40 PM
DV Knutson
Is that tightener(?) down by the lower end of the chain guard?...If so, that is probably your fill point...
post #9 of 9 Old 04-13-2010, 08:25 PM
Ironmower's Avatar
It likely is a "dry" chain(s), just going from other makes i've seen.
Ironmower is offline
