260 backhoe question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 02-22-2010, 04:07 PM Thread Starter
I bought a new 2305 with the 260 BH. My question is about the hoe "bleeding" down over night. The boom part of the hoe will drop a good 3-4 inches over night and the bucket drops some too. Maybe an inch for the bucket. I've been putting the transportation pin in when I'm not using it to keep the boom from dropping. Just wondering if this is normal or should I be making a call to the dealer? The hoe seems to be working fine as I've dug up many stumps so far. Been a great machine for me, except for the crappy design of the seat. Thanks for any input!
mav351 is offline
post #2 of 14 Old 02-22-2010, 04:31 PM
10,000 +posts!
Re: 260 backhoe question
mine "relaxes" also
Team_Green is offline
post #3 of 14 Old 02-22-2010, 05:45 PM
picframer's Avatar
Images: 7
All of mine do the same, I noticed the arm on the left side drops a bit also. Deere at least here will do a test at no charge which I had done on the 2520 but it was within specs. whatever that means, anyhow I have three backhoe's 2305, 2520 & 2720, they all bleed off.
A colllection of CUT's, excavators and GT's, just about every attachment going and a major amount of Stihl gear. We operate a Landscaping business.
Smiling every Day!!! Andy
picframer is offline
post #4 of 14 Old 02-22-2010, 05:47 PM
Rogue Fabrication
SomeGuyFromOlympia's Avatar
mine will bleed too
SomeGuyFromOlympia is offline
post #5 of 14 Old 02-22-2010, 06:07 PM
fresh-popcorn's Avatar
Mine Bleeds also.
I always set my FEL down to the ground after I turn off the tractor (when I am done for the day) but noticed that the BH will "loosen" while driving it around without the pins in place.
Never really thought much of it since both the FEL and BH work great when I am using it.
2010 JD 2305 FEL & Back Hoe
Bro-Tek Skid Plate
Bro-Tek Thumb Attachment
Bro-Tek Ripper Attachment
4' Brush Hog
4' Box Blade
Ensoll Pallet Fork Attachment
Post Hole Digger w/ 9" Auger Attachment
fresh-popcorn is offline
post #6 of 14 Old 02-22-2010, 06:15 PM
Banned!
If I remember right, they will "bleed" when not under pressure for a certain amount of time, ie: motor not running. This is why you have traveling pins. Now if it happens while running and not under heavy load you have a serious problem. John
P.S. Never trust the hyd's to hold anything while working on tractor, blocks or some form of support must be used before working on or around tractor, also good idea to release pressure on system too.
John@Reliable is offline
post #7 of 14 Old 02-22-2010, 06:50 PM
etcallhome's Avatar
Mine bleeds also and yes the crappy seat design.!!!!
Have fun and be safe ! ! !
JD 1026R ,60" MMM, 54FB, H120 FEL, 260 BH, 47" JD Snow Thrower, MF Chisel Plow, RTS48 Bush Hog Tiller, 6' Amish made trailer , King Kutter 5' Rear Blade.
etcallhome is offline
post #8 of 14 Old 02-22-2010, 07:05 PM
Retired and Busy!
Rodney in VA's Avatar
Images: 6
Questionable seat design aside... my back hoe will also bleed down. I always keep the locking pin in when not in use. Speaking of the 260 BH... mine saved my butt a week ago when I got stuck in a snow bank a little too close to a small creek. The backend was loosing the battle to stay out of the creek and I was stuck bad and by myself. The 2305 was leaning towards the creek and was about to turn over so I could no longer sit on the seat. I was able to to stand to the back side of the BH and operate it gently and after about 15 minutes I was able to inch the rear end little by little away from the creek and eventually got it turned 45 degrees and got it out. I was a happy camper and went right back to plowing snow. I was smiling but was very thankful I didn't end up in that cold creek with the 2305 on top of me.
Rodney
John Deere 2305 TLB
John Deere X540 GT
"Retired and Busy"
Rodney in VA is offline
post #9 of 14 Old 02-22-2010, 07:19 PM
Great Site Good People
BLIND REF's Avatar
They all will bleed, perfectly normal.
Glad everything turned out okay for you Rodney! I had a similar situation happen to me around my pond only no snow.
John Deere 2305 TLB, 62MMM
BLIND REF is offline
post #10 of 14 Old 02-22-2010, 07:25 PM
Banned!
Glad everything turned out okay for you Rodney! I had a simular situation around my pond only no snow.
Sounds like you two need the h2o outrigger option
post #11 of 14 Old 02-22-2010, 08:12 PM
Plow Day Man!
PA PLOW DAY's Avatar
he needs some pontoon's
Bryan Seward, Co-Founder of the PA Plow Day and Garden Tractor Show.
PA PLOW DAY is offline
post #12 of 14 Old 02-23-2010, 03:45 AM
Retired Mod
Michael's Avatar
Images: 9
Mine also does bleed down over night. Due to space constraints in my garage I leave the travel pins in and nothing next to the outriggers.
Michael is offline
post #13 of 14 Old 02-23-2010, 09:23 AM Thread Starter
Thanks for all the responses. I won't worry about it anymore! I'll just leave the pin in when not in use.
mav351 is offline
post #14 of 14 Old 02-23-2010, 09:28 AM
10,000 +posts!
put a strap from one out rigger to the other to prevent them falling...
