Help! JD 2305 keeps stalling - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 32 Old 11-07-2009, 06:52 PM Thread Starter
I was using it to mow my acreage and had been out there a couple of hours and everything was going fine. All of a sudden the engine dies (yes it has gas). I get it restarted but it dies again when I put it to low idle. This happens a couple more times. Each time I get it restarted I have to set the throttle a little bit higher to keep it running. Finally, it wouldn't start at all.
So what do you think is going on here?
Thanks.
Raindem is offline
post #2 of 32 Old 11-07-2009, 07:15 PM
snoyes's Avatar
Re: Help! JD 2305 keeps stalling
Not a tractor expert, but first thing I would check is the fuel filter. See if it is clogged up. I'm sure some of the 2305 experts will chime in here soon as well.
John Deere X748, 54 inch snowplow
John Deere 3720, 300CX Loader
Stihl MS362, Yard Boss, FS 45 trimmer, BG 86 blower
snoyes is offline
post #3 of 32 Old 11-07-2009, 07:51 PM
Thanks.
check both of the air filters,I had the same thing going on and had to replace the outer filter.
castiman is offline
post #4 of 32 Old 11-07-2009, 07:56 PM Thread Starter
Thanks for the input. I checked the fuel filter and it is a little cruded up so I'll plan on getting a new one on Monday. Doesn't look like it would create a total blockage though, so I'm not sure if this is my problem. I emptied the sediment bowl, put everything back, and tried to start it again. Did the same thing, ran for about 30 seconds then died.
Raindem is offline
post #5 of 32 Old 11-07-2009, 08:11 PM
9K+ Poster
JDFANATIC's Avatar
Rain,
It's hard to diagnose these things long distance, but there have been several cases where debris got inside the diesel tank and plugged the line. If this is the case, then draining and cleaning the tank and lines are necessary. The other thing I would try to rule out is a safety switch cut out. There could be a short in one.
Cheers
JDFANATIC
JDFANATIC is offline
post #6 of 32 Old 11-07-2009, 08:22 PM
10,000 +posts!
Do you notice it doing this when you hit a bump or you don't even get to move. If you need to clean the tank and if you have a air compressor get a suction line for the compressor and pull the fuel out that way. they you don't need to pull the tank. I have many times cleaned a fuel tank that way.
Team_Green is offline
post #7 of 32 Old 11-07-2009, 08:37 PM Thread Starter
Thanks again for the follow up replies.
Castiman - the outer filter was pretty dusty so I'll add that to my list of parts to get on Monday.
JD Fanatic - Debris in the tank is a possibility. The issue certainly seems fuel related so I might have to do that if the easy fixes don't work.
Team Green - no, it's not motion related. It will die in 30 seconds if I just leave there to idle. If I move the throttle down to low idle it will die instantly.
Raindem is offline
post #8 of 32 Old 11-08-2009, 09:10 AM
Central Kentucky
BigD's Avatar
Images: 9
Have you check the spark plugs recently? Ok, Ok, just kidding
There are several great suggestions put forth by others here in this forum. After you change the air filter, fuel filter and blow out the fuel lines let us know how things are. I'm very curious. There are other things to check but I'm banking on this problem being a fuel related problem.
Good luck and let us know.
Pete,
JD 2320, FEL,62D MMM, 4 ' Box Blade, 6' rear blade, 4' tiller and 17' Gator Trailer
BigD is offline
post #9 of 32 Old 11-08-2009, 09:47 AM
ralphtt's Avatar
Thanks.
You state "(yes it has gas)".
Sure you don't mean this literally . . . if so, that would certainly explain why it won't keep running . . .
Ralph
Benefactor Member NRA
2012 2520 w/loaded rear tires
CX200 FEL w/Markham Toothbar
62D MMM
iMatch Quick Hitch
Heavy Hitch w/eight JD suitcase weights
Herd 96 Spreader
Artillian Forks
ralphtt is offline
post #10 of 32 Old 11-08-2009, 03:05 PM
clacy's Avatar
Check to make sure that your 3 point hitch lever is down and your drop valve for the 3 point hitch is open. If the hitch lever is pulled up and you had the valve locked so your 3 point would not drop, this will cause it to bogg down and not run as you have described. Just a thought, for it has happened to mine on numerous occasions.
Chris Lacy
Iowa
2520 4x4, 62D" MMM, 200cx loader, palet forks, bucket
2305 4x4, 62" MMM, 54" JD Broom
655 4x2 with sprayer
855 4x4 60" MMD, 49 Snow blower, Mauser heated cab, 54" front blade
755 4x4 60" MMD
6x4 diesel gator
4x4 HPX diesel gator, 72" blade, Curtis heated cab, Warn winch
Z655 Zero Turn 54" Deck
Ferris HDD 52" walk behind mower
FL70 with 14' flat bed and dump
clacy is offline
post #11 of 32 Old 11-08-2009, 04:05 PM
Central Kentucky
BigD's Avatar
Images: 9
Thats a new one on me! I'll have to try this and see what happens. Good to know, THANKS!
Pete,
BigD is offline
post #12 of 32 Old 11-08-2009, 04:54 PM
Just passing through
Upper5Percent's Avatar
Things to check...
Dirty grille, radiator screen, or radiator cooling fins.
Fuel shut-off valve partially closed.
Plugged fuel filter.
Plugged air intake system.
Fuel cap vent dirty.
Faulty seat switch.
Stale or improper fuel / fuel level.
Dirty or faulty fuel injectors.
Low coolant level.
Cooling system needs flushing.
Defective radiator cap.
Defective thermostat.
Defective water temperature indicator or sender.
Low oil level.
Low coolant temperature. See your John Deere Dealer.
Fuel pump not functioning properly. See your John Deere Dealer.
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #13 of 32 Old 11-08-2009, 05:57 PM
Retired Mod
Michael's Avatar
Images: 9
Call the dealer and have them fix it if it is under warranty
Michael is offline
post #14 of 32 Old 11-08-2009, 06:28 PM Thread Starter
D'oh. That would be funny. No, it has the correct fuel. Even bought a yellow diesel-only can so I didn't get them mixed up.
Raindem is offline
post #15 of 32 Old 11-08-2009, 06:30 PM Thread Starter
Unfortunately not under warranty. I've only had it a few days and don't really know the history so I'm hopeful some of the basic maintenance items mentioned here will fix it.
Raindem is offline
