As for resealing the driveway: we considered that...
but the wall still leaks... so it would just restain...:fing20:
We sealed the wall and filled the cracks and painted the thing with a 'waterproof' paint... not sure if it will still leak...
not sure why.. but theres no drain at the base of the wall and its a retaining wall about 6 Ft high in spots.. so it cracked in a few spots and leaks at the base.. hes planning on replacing it next year...
I like the muriatic acid myself. I've used it on concrete a few times for all types of stains. I've never tried it on asphalt, though.
Make sure you wet down the driveway first. If you don't, you could be exposed to some very strong and overwhelming fumes mg: . Apply the acid and sweep it into the driveway with a push broom. Let it set for about 5 minutes and then hose it off.
217.1K members
