Non heated garage ,,how to?? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 10-12-2011, 11:00 AM Thread Starter
flash5153's Avatar
Keep liquids from freezing through the winter.
I plan on using the garage but it might go days sometimes without any heat in it. How can keep my cleaning fluids,paint,carb cleaners,grease,,ect from freezing with minimal heat? There is allot of these items.
I am thinking of building a small room ,,,well insulated and putting a space heater or heat light bulb in it. Anyone know what it takes to get it done?? What amount of heat.
I really don't want to run a electric space heater but I will if I have to. A heat lamp would be much more efficient.
I will be using and heating the garage with a salamander through the week ,,but weekends might see days go by without this.
flash5153 is offline
post #2 of 11 Old 10-12-2011, 11:56 AM
Re: Non heated garage ,,how to??
Actually a heat lamp would be less efficient for heating than a space heater. You'd loose a small fraction of energy to light that would not convert back to heat.
A small room with a space heater, I'd use one of the oil filled ones of good quality, with an inline thermostat set for 40 degrees or so, would probably be your easiest solution.
Reason I suggest an in line thermostat is any of the space heaters I've seen do not regulate down as low as you could get away with. Whatever method of electric resistance heat you select you will get the same BTUs per watt, about 3.42, regardless of claims made by the heater manufacturer.
Mike
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is offline
post #3 of 11 Old 10-12-2011, 12:44 PM
Handyman
Dragon's Avatar
A cold garage solution solution I have seen before is to use an old freezer carcass. Upright freezer is ideal as it is all one space inside and has shelves in place. Not to mention it is already well insulated.
Using the drain hole (if so equipped) or drilling a hole; insert an electric line up into the main compartment and wire it to a light bulb receptacle. Mount the receptacle to the floor of the freezer. Insulate the hole for the cord penetration.
Next you will want to play around with varying sizes of bulbs to determine what works best to get the temperature you desire. I would recommend using one of the Compact Florescent bulbs to save on the $$$ as it will be on all the time in the winter months.
Another benefit is that since the output is so low when using bulbs there is not as high a chance of a fire as might happen with cycling on and off a much more powerful space heater.
I have also seen this same type of setup used for storage of rifles/shotguns. The one I saw was in a basement. The shelves were removed and the sides had brackets mounted to hold at least a dozen weapons vertically. Not to mention the built in shelves on the back of the door for holding ammunition and cleaning materials.
To top it off there was also a "regular" rifle cabinet located nearby that held a few low quality .22's and pellet rifles. This was a decoy for any would be thieves. Since they would "find" the rifle cabinet out in the open they would never think to look in a freezer for the good stuff.
Another benefit of this is that the heat from the bulb also helps eliminate moisture from the cabinet. A definite plus when used for weapon storage.
Here is an online image I found of a similar setup; however this one does not have the light bulb in it.
Dragon is offline
post #4 of 11 Old 10-12-2011, 12:59 PM
jhon's Avatar
Dragon,
I saw this title on the main page and decided to look at it and see what it was about as I have a unheated garage. I just want to say that your solution to his issue is one of the reasons I troll these and other forums. I get a lot of great ideas and learn a lot of stuff.
Thanks for a great answer.
Thanks
Jhon
jhon is offline
post #5 of 11 Old 10-12-2011, 01:34 PM
Handyman
Dragon's Avatar
jhon,
You are very welcome. I too love to roam around and find those items that make me slap my head and say "why didn't I think of that".
Have to pay it forward like this and respond with suggestions myself.
Another benefit of the freezer is that you can still move it around fairly easy unlike a dedicated built on site room.
Dragon is offline
post #6 of 11 Old 10-12-2011, 02:19 PM
G-1
Senior Tinkerer
Whatever you use as a cabinet to store things that should not freeze, here is something that could control the heat source...and at a very reasonable price.
http://www.tractorsupply.com/thermo-...outlet-2170275
This would also be great for keeping an outside doghouse at tolerable temperatures during the winter.
Gerald
G-1 is offline
post #7 of 11 Old 10-12-2011, 02:49 PM
KCFLY's Avatar
Gerald
That is a very slick little item to have! Thanks for linking, I've never seen one before.
-Brad
2000 JD GT235 w/48C, PowerFlo, & front dethatcher
42" blade, and 42" snowthrower
2 105 lb. cast wheel weights
JD 757 ZeroTurn w/60 deck
KCFLY is offline
post #8 of 11 Old 10-12-2011, 05:30 PM Thread Starter
flash5153's Avatar
Huh?? What really sucks is,,I just gave a refrigerator away to make room in the garage for my mowers and things. DOH!!! lol That would have worked great I believe.
post #9 of 11 Old 10-12-2011, 05:32 PM Thread Starter
flash5153's Avatar
I have never seen a thermo plug before,,,great idea too. I will getting a few as I have chickens and rabbits,,dogs and geese. I might need a case of them. I had been using timers,,thermo is way better.
post #10 of 11 Old 10-12-2011, 05:34 PM
An old fridge or freezer with a incandescent light bulb inside 60-100 watts will keep things nicely.I'd make a habit of cracking the door open during the time the shop is heated and close it before leaving.Having one of those sockets would be great as well.You just need to remove/bypass the door switch so the light stays on I had a fridge set up like this for several years I just unplugged the fridge motor in my case I got the fridge free because a lady punctured the freezer coil trying to rush defrosting with a knife !
Leon Renaud is offline
post #11 of 11 Old 11-29-2011, 05:11 AM Thread Starter
flash5153's Avatar
Well I got another refrigerator for this reason. It's in my garage with everything I am storing ,,in it. The problem is getting a bulb in it without damaging it. This one works,,,,so I really don't want to ruin it.
It's a side by side refrigerator/ freezer. I was going to put the bulb on the refrigerator side. I don't see why I can't just drill a hole in the side wall of it,,,down low.I'm not concerned about looks just don't want to hit any working parts on the unit.
