If they don't open properly when you click on the thumbnails, then right-click over the image and select 'open in new window'. Hopefully that helps you.
When assembling the door, be prepared for a 'very' tight fit. Don't give up on it, just keep stretching the material until it finally fits over the door frame.
Also, here's a couple of links that might help with the install. The first one is my thread showing a video on how I install the enclosure. Since I leave it partially assembled for summer storage, I save myself quite a bit of time in the Fall when I have to put it back on the tractor. The second link is to a thread I started showing what it looks like after it's installed ... and the height limitation with 'normal' garage door heights.
