Big n Tuf mix and spray rate - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 05-13-2010, 01:00 PM Thread Starter
Workaholic
tettruck's Avatar
Can anyone share their mix volumes formula and spray rate of Pronto Big n Tuf (Tractor Supply..... or Roundup, by other name) for gravel road and ditch maintenance? I've been looking at their label and can't quite find what I need. Maybe a 1.5 to 2 % solution? Spray at what rate?
I've got about 1 acre of area in gravel drives on my property along with ditches, that take runoff to seasonal creek. Will be spraying with trailer sprayer with boom behind my atv.
Thanks.
2005 John Deere 4310 E-Reverser
300 CX FEL
5' Frontier Box Blade
5' LX5 Rotary Cutter
BX62 Wallenstein Wood Chipper
Husqy chain saws 350 and 365
Craftsman GT5000 6-sp manual 48" deck
Quad Boss (Swisher) 44" trail mower
2006 Chevy Silverado Duramax 6-speed manual Crew Cab
tettruck is offline
post #2 of 4 Old 05-14-2010, 03:40 AM
AZJDpilot's Avatar
Re: Big n Tuf mix and spray rate
2% solution of glyphosate usually works pretty good, but read your label to make sure.
2008 x540 w/54"deck
Johnny Bucket jr
Fimco 40 gal sprayer
Gearmore 480# spreader
Stihl BR600 blower
AZJDpilot is offline
post #3 of 4 Old 05-16-2010, 10:10 AM
USMC
slkpk's Avatar
Images: 21
I switched to Ortho Ground clear instead of Roundup and have had better luck with it lasting longer. I don't remember off hand how much I used. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #4 of 4 Old 05-17-2010, 03:10 AM
Phoenix125's Avatar
I use TSC's Ground Work 50% Glyphosate... pretty close to Big N Tuf's 41%. Here's my spreadsheet I made for my Fimco 15gal. 2.1 gpm sprayer at various speeds. It's confusing, but if you figure out my spreadsheet, you can adjust the numbers to match your equipment.
http://www.electrichorizons.com/jd/F...ss_Killer.xlsx
-William "Kim" - AKA: Phoenix125
2009 JD 2305, FEL w/ 53" Bucket & hooks, 54" MMM w/ Ind. Lift, Hydraulic Diverter, & JD Mulch Kit, 12v Port 1 & 2, (3) ROPS Lights, JD Ballast Box w/ Reese Hitch mod, JD 60" Back Blade, Harbor Freight Quick Hitch (27.5" due to old implement), Bro-Tek Skid Plate, Markham Welding Tooth Bar, Wallace 5' Box Blade, Frontier GM1060R Finish Mower, EZmover Hitch, Harbor Freight Winch, Clamp-On Pallet Forks from eBay, CountyLine Carry All, Agri-Fab Speader, Precision Dethatcher, County Line 5' Landscape Rake, Fimco 15gal 2.1 GPM Sprayer, TSC 48"x24" Roller, Precision Spreader, CountyLine 3pt Post Hole Digger
My 2305 & 200CX Maintenance Schedule Check List: PDF Excel
Phoenix125 is offline
