Pulling a tractor with a hydrostatic transmission, bad? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 09-05-2009, 07:56 PM Thread Starter
kaptain krunch's Avatar
I read that pulling a tractor with a hydrostatic transmission, could ruin the hydro. Is there any truth to this?
Wheel Horse 212-6 Off Road Mower In Progress!
(and now on hold)
400cc, inline twin , 36hp go kart in progress!
kaptain krunch is offline
post #2 of 16 Old 09-05-2009, 08:01 PM
The Travelin' Mod
davidg's Avatar
Re: Pulling a tractor with a hydrostatic transmission, bad?
you cna pull the bypass lever and pull it to get it back to the shop. but i would not recommend pulling one several miles, bypass or not.
Check out our new HOMEPAGE
davidg is offline
post #3 of 16 Old 09-06-2009, 02:18 AM
Boyd's Avatar
Images: 10
Thats what we were told on the farm.
Toro 5xi and NH GT18/20/22 owners can join my new Toro 5xi page on Facebook. My Horses: Toro 520xi & 522xi. Toro 5xi prototype hood. WTB: for Toro Xi series 52" deck 78370/78375 and a mule drive for a 79365 single stage snowblower. For sale: Toro 5xi Belly Blade & Toro 60" deck from a 724z.
Boyd is offline
post #4 of 16 Old 09-06-2009, 02:55 AM
15,000+ Posts & Climbing
If you pull a hydrostatic tractor without engaging the by-pass or shifting the two speed rear axle into neutral (if equiped), you in effect are trying to run the hydraulic system backwards and the oil tries to go the wrong way through the hydraulic motor and pumps which effectively become check valves stopping the flow. Net result is very high pressure in parts of the case designed for low or zero pressure. You are trying to turn the tires against a very high ratio reduction unit with a lock on the other end.
Comparable scenario in automotive terms, pull a manual shift four wheel drive truck with the transmission in bull low, the transfer case in four wheel drive, low range and a large V-8 engine.
Bottom line, hydro is ruined because the case is broke, and so are you when you buy the replacement.
TUDOR is offline
post #5 of 16 Old 09-06-2009, 07:52 AM
Artpb's Avatar
Local Public works department towed a Wheelhorse with a hydro down main street with a truck. The pump exploded and damaged a few cars parked along the street. Stated they where only doing 25 mph!
Artpb is offline
post #6 of 16 Old 09-06-2009, 08:11 AM
5000 posts and climbing
m.jodrey's Avatar
Where does one find the by-pass on a 1973 bolens h16, I haven't found one ,and you can't shift them into neutral either.
Maynard
m.jodrey is offline
post #7 of 16 Old 09-06-2009, 09:19 AM
Well that's just pure stupid. Gov. employees.
Scott
murphycc is offline
post #8 of 16 Old 09-06-2009, 09:29 AM
Dude11's Avatar
Maynard
Ain't got a clue--But my money says it's there.They all have them,sometimes you need a manual to locate it.I'm sure someone here will know.
Dude11
Dude11 is offline
post #9 of 16 Old 09-06-2009, 09:58 AM
Your H-16 does not have a by-pass valve. If you must tow it , try releasing the idler for the drive belts or as I was told, disconnect the drive shaft. You do not want to tow the tractor any faster than about 2 miles an hour. Any faster will damage the hydrostat pump and motor.
Dave
DLF_IN is offline
post #10 of 16 Old 09-06-2009, 01:49 PM
No by-pass? Jack it up and put a set of dollies under it, like the tow trucks use. Or a 'P' handle furniture dolly hooked on the draw bar. Just get the back wheels off the ground.
How far do you have to pull it? (See post #4.)
TUDOR is offline
post #11 of 16 Old 09-06-2009, 02:33 PM
cleatusj's Avatar
I just pulled my wheel horse out of the mud three times, just eased the hydro handle into reverse then pulled with outer tractor. When I got it out it wasn't pulling enough to run over me and other tractor.
I'm the guy purist/restorers don't like.
Keith .
cleatusj is offline
post #12 of 16 Old 09-06-2009, 07:23 PM
m.jodrey's Avatar
Not that I have to tow mine , but I like the wheels dolly idea.Thanks guys.
Maynard
m.jodrey is offline
post #13 of 16 Old 09-06-2009, 07:29 PM
standard issue neuralyzer
LLigetfa's Avatar
Here you go.
Tow Dolly
LLigetfa is offline
post #14 of 16 Old 09-11-2009, 12:27 PM
ejstith's Avatar
LOL !! I thought he was talkin' about using a Hydro for a "Pullin' Tractor" ... My nephews, who are into pullin' garden tractors, says a hydo won't work for a puller ... Seems to me it would be but I don't really know .. Anybody know of any hydro pullers ???
ejstith is offline
post #15 of 16 Old 09-11-2009, 04:05 PM
Simplicity Benn
Benn's Avatar
Images: 10
yea i thought thats what he meant at first too...anyways yea i think i have heard of hydro pullin tractors but i think the standard trans would do alot better.
Ben
case 195
MTD 990
Allis chalmers B-212
Allis chalmers B-10
Benn is offline
