need help with throttle linkage on Bolens 1050 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 08-27-2009, 09:41 PM Thread Starter
Need a diagram, or photo, of linkage rod and springs connecting the governor and carburetor. (Wisconsin engine) The engine will not idle all the way down with the throttle control pushed all the way in. I have the cable adjusted so it is pushing the pivot arm as far as possible. The governor arm comes to a closed position, at idle speed, but it is not holding the throttle closed. Also, if I pull the throttle control out, just a little, it races the engine nearly wide open. I think something is out of place or missing. Found a broken spring on the floor, but I've been working on a lot of different projects today, so I'm not sure if the spring belongs to the Bolens
Bill56 is offline
post #2 of 6 Old 08-28-2009, 01:26 AM
Grandpas-Panzer's Avatar
Re: need help with throttle linkage on Bolens 1050
I've been working on my 1050 today, all original.
I can take pictures in the morning and post them if it'll help. I have to pull the air cleaner and tube off to put in the new points and condenser, so I can see to set the points. Which will show the linkage connections better when it's all out of the way.
Grandpas-Panzer is offline
post #3 of 6 Old 08-28-2009, 03:41 AM Thread Starter
Thanks, that will help a lot.
Bill56 is offline
post #4 of 6 Old 08-28-2009, 11:19 AM
Hope these pics help. I had to shrink them for the site. If you'd like to see the full size pics, message me with your email.
ID:	75606   Click image for larger version
ID:	75607   Click image for larger version
ID:	75608   Click image for larger version
post #5 of 6 Old 08-28-2009, 03:23 PM Thread Starter
Thanks for the pictures. I won't get a chance to work on this till Monday. I did take a quick look to compare your pictures to what is on my tractor. I can see, right off, that my spring is in a different hole on the governor arm. Yours' is in the third hole from the top, mine is in the third hole from the bottom. Maybe moving the spring will cure the problem.
Bill56 is offline
post #6 of 6 Old 09-01-2009, 06:02 PM Thread Starter
I finally got back to this project today. I moved the spring to the same position as in the picture, but still can not get the engine to come down to an idle. All the linkages are moving freely. It seems like the governor is not working.
If I disconnect all the linkages, except for the rod between the governor and the carburetor, Shouldn't the governor be holding the engine at an idle once the engine is running?
Bill56 is offline
