Burning Diesel Fuel in a Kerosene Heater - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 10-20-2008, 09:28 AM Thread Starter
Landscaping Nut
HiPocket's Avatar
Is it any worse for the heater or the lungs to burn Diesel Fuel in a kerosene heater.
Its not easy to find straight kerosene but diesel is more common.
Thanks Eric
HiPocket is offline
post #2 of 14 Old 10-20-2008, 09:37 AM
Banned!
Re: Burning Diesel Fuel in a Kerosene Heater
In my opinion, not a good idea. In fact, I don't even know if it will work. Kerosene is something like gasoline, it doesn't need to be vaporized for it to burn clean. Diesel works best when sprayed in a fine mist from a nozzle under pressure. Pour diesel into a bucket and try to light it. You can't. But if you put a rag in it as a wick, then the diesel on the rag will burn because the rag allows oxygen to combine easily with the diesel. If I were you, I'd stick with the kerosene. After all, the stove was tested and certified for use with that fuel only. Using anything else may pose a health and safety issue. The life you save, may be your own.
Caseguytoo is offline
post #3 of 14 Old 10-20-2008, 09:42 AM
sniffing diesel fumes
Smog's Avatar
Images: 17
I get straight pure kerosene in all hardware store; look in the paint department.
kerosene is a purified derivative of diesel.
Smog is offline
post #4 of 14 Old 10-20-2008, 10:16 AM
Just Have a Little Faith!
Even dirty kerosene isn't good. It contaminates the wick and eventually the wick needs to be discarded. Diesel has to be even worse.
LilysDad is offline
post #5 of 14 Old 10-20-2008, 10:52 AM Thread Starter
Landscaping Nut
HiPocket's Avatar
I'll go on a hunt for kero. I wanted to make sure as I have diesel for my tractor already on hand and kero is another trip.
Thanks.
HiPocket is offline
post #6 of 14 Old 10-20-2008, 11:23 AM
Smog's Avatar
Images: 17
Originally Posted by HiPocket View Post
I go on a hunt for kero. I wanted to make sure as I have diesel for my tractor already on hand and kero is another trip.
Thanks.
if you can get cheap kerosene, most diesel engines can burn it
Smog is offline
post #7 of 14 Old 10-20-2008, 11:30 AM
I have used it in my "reddy heater",and so has a friend in his torpedo heaters,granted it does burn a bit less cleanly and does smell a bit worse as far as the fumes go,but using pure Kerosene in them doesn't seem to be all that much better..diesel seems to give more trouble getting them "lit", and they'll smoke like crazy if it gels up at low temps too...some heaters will "puff out" when diesel is used, and smoke you right out of your shop!..
My friend uses some anti-gel additive in his torpedo heater with diesel fuel,claims it makes it burn more cleanly and prevents clogging,and smoking--but I noticed the fumes are much worse with Anti-Gel in the diesel fuel..makes your eyes water and takes your breath away..
Of course,the correct fuel is Kerosene or jet fuel for a torpedo heater--but finding Kerosene here is a chore,only a few places sell it and they are far away,plus its 6 bucks a gallon,IF you find any!--but I can buy diesel fuel 500' away from my home,for 3.55 a gallon!..
I use my torpedo heater only sparingly,so I dont mind using diesel in it..but I'll admit its not the BEST fuel I could be using in it either!..some brands of heaters seem to tolerate diesel fuel better than others do..some will only smoke and refuse to light properly,others will light up OK,but start smoking and blowing out and smoking shortly after heating up some..others seem to be able to burn anything that resembles kerosene and never give any grief!..
I wouldn't use disel in a kerosene wick style heater or hurricane lamp though..
Robert
Tractor-Holic is offline
post #8 of 14 Old 10-20-2008, 11:44 AM
munderhill's Avatar
Images: 7
We have a HOTSY steam cleaner/pressure washer here @ work and run whatever we get, off road diesel/on road diesel/fuel oil/kerosene. I've been told many times off road diesel, fuel oil and kerosene are the same red dyed fuel.
The new on road diesel is different as it supposedly has a lower sulfer content. 15PPM as opposed to 500PPM. Not sure if it really is what they say as my VW diesel still belches the same amount of black soot as it did before the switch, (under power).
I personally can't smell the differnce between any of them, raw or burnt and would doubt most folks could unless told so, just my opinion. All of the above fuels will run fine in a Diesel combustion engine, speaking from personal experience with my VW's and brothers JD3320.
We had a small kerosene heater years ago and burned diesel in it for same the reason your asking, never had a problem.
MU
munderhill is offline
post #9 of 14 Old 10-20-2008, 12:33 PM
Just passing through
Upper5Percent's Avatar
Thanks Eric
YES...
http://www.macraesbluebook.com/searc...th-Carolina-NC
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #10 of 14 Old 10-20-2008, 03:31 PM
Mrwiggles2's Avatar
Images: 9
Thanks Eric
Hi Eric,
I wouldn't do it. Kero heaters are designed to run very efficiently on 1K kerosene and burn cleanly if properly maintained. If they were meant to run on diesel fuel they would.
Craig
Buffalo, NY
You Tube Channel Link Below. Videos on my tractors, how-to and just good stuff!
http://www.youtube.com/user/mrwiggles2?feature=mhee
1989 Wheel Horse 416-8 16hp Onan
1989 Wheel Horse 520-H 20hp Onan
Mrwiggles2 is offline
post #11 of 14 Old 10-20-2008, 05:08 PM
STUMPGRINDER's Avatar
Thanks.
Hi
Tractor supply sells kerosene in 5-gallon cans, thats what
i use in my heater, hope this helps..
Bob and Jan
STUMPGRINDER is offline
post #12 of 14 Old 10-20-2008, 05:19 PM
Ask a local gas station manager. Not the teenage clerk, but the manager. Some rural gas stations have k-1 in a pump. You may have to go to a farm supply or fertilizer dealer for it too. it's around, you just have to ask. All else fails, call your local fuel distributor's office.
jschahl is offline
post #13 of 14 Old 10-20-2008, 07:48 PM Thread Starter
Landscaping Nut
HiPocket's Avatar
I moved two months ago out of the city. I'm sure there some in Oak Ridge, NC
Theres a TS there Stumpgrinder.
HiPocket is offline
post #14 of 14 Old 10-20-2008, 08:31 PM
Mrwiggles2's Avatar
Images: 9
I'd imagine so. K-1 I've seen at TSC, Home Depot and others. I get mine out of a pump at a local gas station, was about $4.50 a gallon.
Craig
Buffalo, NY
