How to deal with ethanol in the gas - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 33 Old 01-14-2013, 04:33 PM Thread Starter
dfitzemt's Avatar
How do you guys deal with ethanol in the gas. I don't have any access to ethanol free gas. It really seems to do a number on carburetors.
The only solution I have come up with thus far is to turn off the fuel and run the engines dry before storing them for any length of time.
I was wondering if there is an additive or mixture that any of you have tried and works in lowering the ethanol content in gasoline
If the women don't find you handsome, they should at least find you handy.
dfitzemt is offline
post #2 of 33 Old 01-14-2013, 05:24 PM
johndeere's Avatar
Images: 7
Re: How to deal with ethanol in the gas
Nothing at all I have no problems.I do add Stabil just as I have for the last 25 years.
I have several small engines to many to count right now and some set for a year at a time.
johndeere is offline
post #3 of 33 Old 01-14-2013, 05:58 PM
Ditto in Wisconain we have had 10% ethanol in fuel since 1982 and other than using Stabil in the gas which I did before the ethanol fuel started I don't do anything new. Roger
rhenning is offline
post #4 of 33 Old 01-14-2013, 06:05 PM
Run ahead of the pack
stladrill's Avatar
Images: 6
That subject was beat to dead on the forum, many different opinion....
Do a search, you'll have for days to read.
stladrill is offline
post #5 of 33 Old 01-14-2013, 08:30 PM
Nouveau Redneck's Avatar
I have had better success with Seafoam than Stabil. Stabil only seems to work for about 6 months for me. I have an old Troy-Bilt Super Tomahawk chipper/shredder that I have had to dismantle the carb and thoroughly clean it a couple of times when it sat for between 6 months and a year. After switching to Seafoam, I haven't had a problem, and the Super Tomahawk has sat for over a year a couple of time since I switched, and it started and ran fine.
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
post #6 of 33 Old 01-14-2013, 09:24 PM
walterjay's Avatar
Seafoam, Stabil, Startron... take your pick.
walterjay is offline
post #7 of 33 Old 01-15-2013, 03:56 AM
USMC
slkpk's Avatar
Images: 21
I've used Seafoam and Stabil without any problems. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #8 of 33 Old 01-15-2013, 08:25 AM
A little Marvel Mystery Oil helps I think and will help lube the valves too.
gburnett is offline
post #9 of 33 Old 01-15-2013, 09:23 AM
If you want to get technical when I buy fuel in my 4 gallons at a time container I add 1 ounce of Stabil, 1 ounce of Seafoam, 1 ounce of MMO amd am trying this winter 1 ounce of 2 cycle mixing oil. I am also experimenting with the new blue version of Stabil as I picked some up on close out this fall. The reason for all of that is not the ethonal but the fact the actual quality of gasoline has changed a great deal over the last 30 years and is no where near as good as it was. Roger
rhenning is offline
post #10 of 33 Old 01-15-2013, 11:12 AM
If you store out-of-season engines with the carburetor completely dry, it won't matter what's in the fuel, as there won't be any of it in the carburetor.
rscurtis is offline
post #11 of 33 Old 01-15-2013, 11:29 AM
3v0
What did you say ?
3v0's Avatar
Images: 10
Originally Posted by rhenning View Post
... The reason for all of that is not the ethonal but the fact the actual quality of gasoline has changed a great deal over the last 30 years and is no where near as good as it was. Roger
This is my take on it too.
Kubota BX2200 FEL, 1975 Essick VR30RE Road Roller, Kwik Way Dirt Master Backhoe
1982 Red Cub 682, 1973 John Deere 112,
1974 Gilson Bros Super 8
ZombieEngines
3v0 is offline
post #12 of 33 Old 01-15-2013, 01:18 PM
Look on the Seafoam site and check the msds...seafoam contains isopropyl alcohol...adding alcohol to try and cure an alcohol problem doesn't make a bit of sense.
TooTall999 is offline
post #13 of 33 Old 01-15-2013, 01:23 PM
3v0
What did you say ?
3v0's Avatar
Images: 10
Maybe because alcohol is not the problem.
ZombieEngines
3v0 is offline
post #14 of 33 Old 01-15-2013, 01:35 PM
SonnyT's Avatar
Images: 26
Not so much from the alcohol by itself, but that the fact that it pulls moisture out of the air and you end up with water in your gas.
Startron/ Stabil/ etc just better stabilizes the alcohol so it doesn't draw water as readily.
RIP Sonny T.
1954-2015
SonnyT is offline
post #15 of 33 Old 01-15-2013, 01:58 PM
walterjay's Avatar
I have used Stabil and Startron. Startron appears to be working better, as it has smoothed out a surging push mower.
