Tire Dry-Rot Repair - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 07-14-2012, 06:05 PM Thread Starter
Cam-Shaft's Avatar
Tire Dry-Rot Repair
I picked up some tires which hold air, but have some heavy cracking. Would it be OK to use black urethane to fill the cracks, then spray tuck bed liner over it?
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
Bolens HT-23S power steering, Cruise control, Transmission cooler.
Bolens HT-20 w/ARK 500 FEL and 3pt hitch
Bolens 1050 pulling tractor (Wisconsin THD)
Bolens 800, rebuilt engine.
Cam-Shaft is offline
post #2 of 20 Old 07-14-2012, 07:46 PM
My Orange Jane Deere
orange j d's Avatar
Re: Tire Dry-Rot Repair
Go for it, it will ether work and look good or it will fall off. What you got to lose. Take some before and after pictures and keep us post on the out come.
Sent from my FREE MTF APP PROVIDED BY MY FRIENDS AT MTF*****
Remember: Marriage is the number one cause of divorce.
orange j d is offline
post #3 of 20 Old 07-14-2012, 08:03 PM
flash5153's Avatar
If you figure this one out,, patten your method and you will be a millionaire.
Well,,Ok,,maybe not a millionaire but at least I would know how fix them.lol
Only thing I know that will work is a tube or sometimes if not too bad,,,,green slime will cure it,,or fix a flat.
Seems like just maybe black gasket maker might work but you would have to let it dry before putting air pressure to it. It won't hold much PSI,,so if it is real bad it won't work. But I have seen leaks like this where the air is barely coming out,,there's not PSI there.
I have never tried it ,,just a thought.
Make sure no one is around when you do it!!!!
But if it works????? hmmm???
flash5153 is offline
post #4 of 20 Old 07-14-2012, 08:05 PM
Evo26pm's Avatar
Talking Re: Tire Dry-Rot Repair
If you have tires that are dry rotten then the best solution is to put tubes in them then you be fine. Tubes are cheaper to buy the buying brand new tire.
LIVE ACTION
79' Sears GT 19.9
68' Suburban 12
Exmark Lazer Z 60"
Exmark Turf Tracer 48"
Evo26pm is offline
post #5 of 20 Old 07-14-2012, 08:06 PM
Evo26pm's Avatar
Aw and just for note the urethane and bed liner won't work on it. I knew a guy that actually tired that. Lol
LIVE ACTION
79' Sears GT 19.9
68' Suburban 12
Exmark Lazer Z 60"
Evo26pm is offline
post #6 of 20 Old 07-14-2012, 08:11 PM
orange j d's Avatar
Go back a reread. He never said anything about fixing a flat. He said they DO NOT LEAK they hold air. He just wants to make them look nice. *** some peoples kids.
post #7 of 20 Old 07-14-2012, 08:16 PM
Evo26pm's Avatar
Yes I under stood what he was meaning but just saying for future reference and if you are wanting them to look good then ppl would actually pay the money and get new tires!
LIVE ACTION
79' Sears GT 19.9
68' Suburban 12
Exmark Lazer Z 60"
Evo26pm is offline
post #8 of 20 Old 07-14-2012, 08:20 PM
flash5153's Avatar
DOH!!! Got me,,,,,I missed that part.
Heck ya it will work!!! Can paint a mural on them if all you want is beauty!!! lol
post #9 of 20 Old 07-14-2012, 08:39 PM
grnspot110's Avatar
Images: 21
Try Miller Tire's "Tire Paint", it won't fill cracks, but will make old tires look better!
http://www.millertire.com/products/t...ck-tire-paint/
John Deere: 1953-40S, 1970-70 I, 1980-314, 1993-755 w/60" deck, 2000-F725, 2004-790 w/300 Loader, 1980-Power King 2418 & 2007-"TS" Gator. & 1980-4' x 8' Snowco Trailer
grnspot110 is online now
post #10 of 20 Old 07-14-2012, 08:40 PM Thread Starter
Cam-Shaft's Avatar
All I was hoping to do was keep water out of the cracks...
post #11 of 20 Old 07-15-2012, 10:50 AM
Tubes can be pinched in dry rot cracks if they are large enough cracks,and the tube may be eventually punctured....I have made a "boot" from an old tube to put in a tire before tubing it ,to prevent this from happening...
I have used "shoe-goo" or "Goop" sealant/adhesive on some badly cracked sidewalls on tires I had,that still had excellent tread and only leaked slowly,over a few days time they would go nearly flat...so far thats the only stuff I tried that seemed to adhere well to rubber and didn't peel right off ..
I used a drill with a wire brush to ruff up the rubber around the cracks and folded the tire to open the cracks up more then forced the goop in with a putty knife,and I put a thin layer on the entire sidewall....inside & out!...
I learned to wait several days before inflating the tires,otherwise the goop will blow a big bubble, and come off ,or pop!...I ended up using tubes in the tires after assumung they wouldn't hold up well with goop alone...I used acetone to clean the rubber well before applying it too....never tried Goodyear "Pliobond" on this application,or rubber cement,maybe that would work too.....nothing beats new tires though..
Tractor-Holic is offline
post #12 of 20 Old 07-15-2012, 12:29 PM
Canawler's Avatar
I would think that truck bed liner would be just a bit too stiff and would flake or fall off as the tire flexes.
Maybe a rubberized undercoating???
---Jim
It's only money, you make more every day.
'74 Agway/MTD 990
'93 Troy-bilt GTX18
'74 Allis Chalmers Homesteader 8 (X2)
?? Simplicity Broadmoor 717
?? Pennsylvania Meteor 1010
Canawler is offline
post #13 of 20 Old 07-15-2012, 01:34 PM Thread Starter
Cam-Shaft's Avatar
thanks for the ideas.. I'm going to look around and see what I find.
post #14 of 20 Old 07-15-2012, 02:33 PM
orange j d's Avatar
Well if you find something good that works let me know, the ol lady is getting a lot of dry rot spots I will use it on her.
post #15 of 20 Old 07-17-2012, 09:53 PM
I have some badly cracked ATV tires and I just put Slime in them to seal up any holes that have developed or may develop. I know your's hold air now, but who knows in the future. Plus, you would probably destroy the tires trying to get tubes in them now.
For strictly looks, in the movie The Last Indian (about breaking the land speed record on an Indian motorcycle) the character gets red flagged by the safety guy as his tires have cracks in them. He solves the problem by rubbing shoe polish into the cracks.
Engine_Tech is offline
