How to clean up battery acid? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 05-30-2011, 11:04 PM Thread Starter
Brians445JD's Avatar
My son knocked over a tractor battery and it spilled on garage floor. Poured some cola on it, then put some floor dry on it. Now their is a big whit spot on floor. Anyone know how to clean it up?
John Deere 1026R
H120 loader, 60" auto connect deck, 51" Tiller, 48" box blade, 5' grader blade, 7' landscape rake.
John Deere 445
54" front blade and 3pt. hitch.
Ok Ok, I'll admit it. I'm addicted to yellow and green.
No I'm not prejudist, I like all makes/sizes of tractors equally.
Brians445JD is offline
post #2 of 14 Old 05-30-2011, 11:09 PM
Ken in NJ's Avatar
Re: How to clean up battery acid?
I'd dampen it and sprinkle some baking soda on it .. to neutralize any left over acid in the concrete
Acid will do a number on concrete .. that mark/stain will be there for ever I'm thinking
Ken in NJ is offline
post #3 of 14 Old 05-30-2011, 11:15 PM
Ever Working
Baking soda, then just wa**** down with water.
Caish is offline
post #4 of 14 Old 05-31-2011, 08:05 AM
wally2q's Avatar
btw: coca cola has a mild acid in it too, so pouring it onto an acid spill will not help.
baking soda as mentioned... in an emergency - if you "just spilled" the acid, the #1 answer is lots and lots of water.
all inorganic acids are water soluble, and the more water you add, the more "diluted" it becomes... just flood the area....
wally2q is offline
post #5 of 14 Old 05-31-2011, 11:32 AM
JRJ
The owners manual
JRJ's Avatar
I'm afraid you are going have a white spot on the concrete from now on, I also spilled some battery acid on my garage floor.
Dick
GT275
GT235
JRJ is offline
post #6 of 14 Old 05-31-2011, 01:15 PM
what they said, but please crank up your paranoia about the washed off acid. Put up a temp *** or something equivalent, the cleanup drool from a battery acid spill can be as bad as spilled acid.
Wiregeek - complex solutions to simple problems.
1979 Craftsman 19.9 GT1977 Ford Granada 302
2004 Chevy Silverado 5.31991 Suzuki Quad Runner 250
Wiregeek is offline
post #7 of 14 Old 05-31-2011, 02:29 PM Thread Starter
Thanks for the tips. I can live with the white spot as long as nothing is left behind that would hurt the kids. put some baking soda on it and plenty of water. Thanks again, this is a great site for info...
John Deere 1026R
John Deere 445
post #8 of 14 Old 05-31-2011, 08:50 PM
Rog02's Avatar
Your sweating bullets about nothing. The lime in the concrete has already neutralized the acid. The white spot is from the sulfuric acid etching the surface. It's white now and will continue to be white until sufficient oil and dirt accumulate to cover it.
Back in the "bad old days" we used to intentionally up end a couple of old batteries in each bay of the shop occasionally to clean the floors. It would leave the floor clean and the etched surface acted as an anti skid surface. We quit doing that when that owner finally purchased a power washer.
Just hose it down and dilute it with lots of water. Don't worry about it. Besides for your information they use muratic acid to clean brick and masonry with only a thorough rinse to neutralize it.
Roger
Old, Tired, and Grumpy
Rog02 is offline
post #9 of 14 Old 05-31-2011, 09:03 PM
DoubleD's Avatar
The floor will be fine , but if the little guy get's it on his hand , clothes, etc. .Wash him up with white vinegar real quick. Before his brain gets itchy and desides skratch it through his nose. WHAT? It's the fastest way , the ear wax blocks the other way in.
DoubleD is offline
post #10 of 14 Old 05-31-2011, 09:04 PM
Muriatic acid is used to clean concrete,block and brick all the time and it is deluted Sulfuric Acid.All new brick houses have gallons of it on the ground where they clean the excess mortar off the brick.If you cleaned the floor with muriatic acid the rest of it would probably match the spot.
gburnett is offline
post #11 of 14 Old 05-31-2011, 09:27 PM
TAHOE99's Avatar
Actually, Muriatic acid is a form of hydrochloric acid, not sulfuric.
Either way, soaked the area with copious amounts of water which will dilute/neutralize it, white spot will stay. Once diluted, there are no worries about little one getting poisoned or burnt. Baking soda is best neutralizer followed with water....works great to clean those corroded battery terminals too.
http://www.mytractorforum.com/showth...460&highlight=
just a bunch of GT's, no JD of course
TAHOE99 is offline
post #12 of 14 Old 05-31-2011, 09:39 PM
uncle al's Avatar
Images: 6
What about the battery, can it be saved, I did the same thing over the weekend, but it was outside. Most of the acid on one side is gone, can I put distilled water in or do I need acid.
Ban the deed not the breed BSL doesn't work
uncle al is offline
post #13 of 14 Old 05-31-2011, 09:46 PM
The voice of reason !
ranchkingron's Avatar
This is just a WAG but I would say acid rather than distiled water, reason being you don't have enough acid in the empty cells to convert the water into acid, Im sure someone better qualified will discount this probably.
Ron
Sometimes a cigar is just a cigar. Sigmund Freud
ranchkingron is offline
post #14 of 14 Old 05-31-2011, 11:08 PM
Rog02's Avatar
Ron
Oh contrare !
A guaranteed way to destroy a battery is to refill it with fresh acid. The "sponge" is already saturated with acid so the addition of fresh acid will only screw up the PH.
Top off the affected cells with distilled water and slow charge until you get equal hydrometer readings. Sometimes it works, sometimes not, but the service life of the battery has been compromised either way.
Roger
Rog02 is offline
